Results 1 to 9 of 9
Thread: Ecu tuning
    Active Member One Ring Greenc281's Avatar
    Sep 21 2018
    Pennsylvania
    Ecu tuning
    Can anyone recommend tuning software/equipment for 98 Audi a4 b5 1.8t quattro aeb with stage 1 giac tune? I recently replaced turbo and decided to add headers while taking turbo out and I beleive now the tune needs to be adjusted. It was recommended to send ecu to someone for a stage 2 flash but I would like to invest in equipment to tune on the fly as I'm nervous to spend money for something that might not fix my problem
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    MPPS v16+ or more. However self tuning is not easy. You will need to spend atleast 2-4 months reading stuff to understand the technical side about it then gaining experience is another thing. You need to read an ICE book, get the ME7 Funktionrahsmen, Self studies, and hella other pdfs.
    I am a self tuner so you can trust me on this. It is not an easy process :) However if you really wanna get into it I can help.
    Sep 21 2018
    Pennsylvania
    Any help or direction would be greatly appreciated, this is my first"tuner" car project and no one around me has the ability to tune it unfortunately so I am ready to learn more about doing it myself
    Sep 21 2018
    Pennsylvania
    I guess my biggest question is where to start
    Veteran Member Three Rings b5v6's Avatar
    May 08 2004
    '05 Volvo S60R, B5 A4 1.8TQM Avant, '06 Toyota Tundra
    San Diego, CA
    Quote Originally Posted by Greenc281 View Post
    You're in PA? There are plenty of places scattered throughout the east coast they'll tune a B5.
    Sent from my Moto Z (2) using Tapatalk
    99 A4 1.8TQM Avant
    Stroked/Built/Elim71r/NS intake gasket/port matched head and mani/Big PNP/ECS pulley/FMIC/Relocated DV
    Full 3" stainless/relocated cat/Vibrant res & muf
    Neuspeed/Bilsteins/AWE DTS/17" Enkei/Bridgestones
    TT carriers/A8 rotors (front)/B5S4 (rear)/Goodridge hoses/PBR ceramic pads
    Rieger RS4 bumper/Painted rear valance/Valeo one-piece
    Facelift/Pioneer DA120 Apple Carplay/Infinity Reference (front/rear) (Bose deleted)
    awaiting: side skirts/paint job
    Sep 21 2018
    Pennsylvania
    That's what I thought, talked to 6 different shops who said software was too old
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    It took me about 4 months(mostly spent defeating the immobilizer) to understand and safely nefmoto a 2.7t and they're far more documented. If you do it check your checksums before flashing! Like 3 times. It would be hard to really know where to start unless you find a base map already altered similarly. Look on nefmoto's forum... It's been asked. That Australian guy on here... Totally forget his name tunes 1.8t's I believe outside of what is normal. Tuner pro, gellato, msps, like 5 exe's is what you'll need to read, alter, blow it up, try and tune it again ;)
    Nov 14 2011
    NW
    Do you have a wideband and have you checked your injector duty cycle?
    You have a 400bb me3/5 ecu. Vs me7.x which is what's all documented
    And 800bb. I believe that difference only means 400 is 512kb's flash vs 1mb.. But.. It's been a while.
    Mar 15 2018
    Europe
    Quote Originally Posted by vrmm View Post
    there is not much difference between 512 kb and 1024 kb flashes . The ME7 FR applies to all of the ecu's that run the same.
    Cheapest way is getting a blue FTDI cable and nefmoto, that will read your flash. However I would much invest in a MPPS v16 replica as it can do many many more cars than just ME7. After you have that you gonna read a couple ICE and Turbocharging books.
    Street Turbocharging is a must.
    https://www.amazon.com/Street-Turboc.../dp/1557884889
    After that you gonna get the ME7 FR and the translated version of the some modules , this is absolute necessary, then you go s4wiki.com/tuning and read this like 5 times.
    After that if you are lucky you gonna find a mappack for your ECU , if not you'll have to find the maps yourself :P ( I had to :P) , I cant be asked to write it all down right now as I am quite tired maybe in the future.
    I'm coming up on my 5th iteration of my small frame t3/t4 atmo to turbo conversion self tune :)
