- Fault Code 02432: Left parking brake motor voltage supply
- Fault Code: 03288: Brake pad replacement mode active
At the moment, the parking brake switch flashes red, and the yellow parking brake malfunction icon is illuminated in the drivers information center. I am able to open and close the parking brake using the output test feature as a work around.
The work did not take long to complete, but it was not connected to a battery charger during the processes.
For fault code 02432, I plan to inspect the cables, remove and inspect the connector, and reconnect. Hopefully, that solves the problem.
For fault code 03288, I will connected the car to battery charger, and hopefully, that will allow me to redo the open, close, and calibrate the rear.
Any suggestions or solutions would be helpful.
Just in case the replacement parts info is below.
- Zimmerman rotors
- Hawk 5.0 brake pads
Thanks,
Randy
