Results 1 to 40 of 54
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    Which battery replacement to go with
    My battery in my 2016 s3 is starting to go and wanted to know a good replacement? I wanted to get something lighter. Does anyone know the OEM specs on our battery? What is anyone's opinion on braille?
    Ps. My battery prematurely went kaput because I rarely drive the car during the week and I have added 2 audio amplifiers so looking for enough juice for them..
    Sent from my SM-N950U1 using Tapatalk
    Aug 06 2012
    san diego
    not sure myself but I am looking for options in the future.
    The front/rear weight distribution of the s3 is a 59/41
    A battery relocation or lightweight upgrade (or both) can shift that by anywhere between 0.5% to 1%. And the outcome could result in a 58/42 weight shift. Maybe? I could be way off.
    Anyways, that does not seem to be your primary concern..
    The new lipo batteries are far lighter, smaller, and more powerful. I will post anything that I can come up with.
    https://www.audizine.com/forum/showt...battery-option
    Dec 25 2004
    Earth
    Replace like for like.
    I found the OE battery from a VW dealership was the best option for a street driven car.
    Battery requires VCDS coding...like for like makes that easy.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by MikTip View Post
    I was also opting for an Optima h6 yellow top....although same weight as OEM, its far superior than the OEM.
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Quote Originally Posted by jiannu View Post
    How are you planning on getting around the coding portion if going non-OE? If you don't properly code for the installed battery, you may end up killing it prematurely...so no point in getting a "better" battery if you can't get the battery management system to properly charge it.
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Dec 25 2004
    Earth
    Right...
    I ran an Optima on my B6 for 11 years...
    Seems no one here runs an Optima on their S3...
    I would love to, but it has to be coded with VCDS...
    The factory batterys are AGM. OPTIMA Batteries are considered SPIRALCELL AGM batteries
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by XMetal View Post
    Just seen a video on coding via obd11(which I have).
    https://m.youtube.com/watch?v=OrbvCHDbmmw
    Dec 25 2004
    Earth
    Nice!
    Dec 25 2004
    Earth
    Nov 02 2017
    CA
    Wow! Didn't even know you can code in different battery technologies with OBD11! Thanks for that info! Now, the only concern is how would you keep heat away from that battery? Lithium batteries don't like heat - much less than AGM
    Dec 25 2004
    Earth
    Optima H6
    Weight: 54.01 lb
    C20 Capacity: 72 Ah
    CCA: 800 Amp
    Factory 000-915-105-DG
    Weight: 40.5.
    Dec 25 2004
    Earth
    Dec 25 2004
    Earth
    The S3 has an after-run feature that operates after the engine is shut down...
    Previous Audi models often came with a OBD/cigarette lighter Solar Battery charger.
    I have the solar battery charger and its plugged in while my car sits 8 hours at work all day.
    Mar 23 2016
    Ontario,Canada
    Interesting......where can I get one? And how does it work? My car is a weekend warrior....will it be enough for all week?
    Apr 10 2019
    I went with Kirkland (Costco) for cost reasons after 4 years. No coding required. My reasons:
    1) A battery works or not. No better or worse except in very unusual circumstances (arctic?)
    2) Audis are very sensitive to low(ish) battery voltage. Will throw a lot of false codes. this happens if you drive short distances and particularly in cold weather.
    3) The hassle and cost of a failed battery is too much relative to the cost of preemptive replacement. The hassle will only happen once, guaranteed.
    4) Change it after 4 years and don't sweat it. About $25/ year for peace of mind.
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by morris39 View Post
    Do u know of any batteries costing $100? OEM spec
    Apr 10 2019
    Group 48 72 Ah from Costco is same rating as the original Varta but not same spec. Varta is AGM, Costco is flooded and made by Interstate. Warranties are different too. I paid ~$100CDN. Expected life as suggested by the warranty should be longer but not certain. My point is that batteries are more or less disposable and their failure is unpredictable beyond 3-4 years. You may well get a long life but maybe not. Do you want to engage in that game? My motorcycle battery needs care & feeding, trickle charging etc. and I do it. But that is time I will spend on a hobby but not on a daily driver.
    Senior Member Two Rings Epic-A3's Avatar
    May 05 2019
    Pennsylvania
    I'm a battery specialist literally. Go with an AGM battery, unless you drive more then an hour each way for work. It handles the heavy electrical demands our cars dish out. Still only gonna see 4 to 5 years, but no corrosion mess at the end of its life.
    Sent from my SM-G950U using Audizine mobile app
    Nov 13 2009
    the OC, SOCAL
    super lite and powerful.
    advantages, can sit for months without self discharge, weight only a few pounds.
    https://4xspower.com/shop/product-category/li-series/
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by 949 View Post
    So confused when I went on their site.....which one is close to OEM specs?
    Nov 13 2009
    the OC, SOCAL
    no idea but you can pick the size thats the closest.
    i dont think they will have one that is spot on.
    just look for the orientation of the posts on your car and measure the HxWxL and compare.
    when its time ill be getting one myself. i plan to up size mine to which ever will fit. well worth the cost.
    i have had optima and some other brands above the stock and each time it was worth it. never have i tried this version.
    Nov 02 2017
    CA
    If the OE is 72Ah, then the closest one would be this, which is rated to 79Ah Pb equivalent, but a Pb CA of only 540A seems to be on the low side => https://4xspower.com/shop/li-series/...ies/li-ps975l/.
    I would just stick with the OE battery to be honest and just change it out every 3 to 4 years and call it the day.
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    Quote Originally Posted by Epic-A3 View Post
    I am under the impression Audi OEM battery for A3/S3 is flooded acid battery to save cost and not AGM. Also, I have read various things about if coding is required for A3/S3 batteries. Any thoughts?
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    My 3.5 yr old car got the battery replaced under warranty. Guess there was a bad batch. I’m sure my long flashing sessions with the accessories on didn’t help. May be worthwhile to check with the dealer before you spend extra $$.
    -cW
    2023 X3 M40i Alpine White
    Nov 02 2017
    CA
    Quote Originally Posted by n8vs3 View Post
    Coding was covered on post #7
    Dec 25 2004
    Earth
    Audi offers several batteries...AGM is one...but yes their are lower cost batteries the dealerships have...
    Mar 23 2016
    Ontario,Canada
    -cW
    Up here in the true North its only 1 year...seems like Audi is on to something as they must know that there batteries are crap!
    Mar 23 2016
    Ontario,Canada
    I went by Costco and could not believe that the one for our cars is $134 minus $10 core exchange....how can u not go wrong?!?!
    Jul 10 2016
    On a side note, does Audi need a memory saver device to retain ECM and radio settings during removal and installation of new battery?
    Mar 23 2016
    Ontario,Canada
    I dont believe so. When my car was in the shop, they had the battery out and it still retained all settings
    Mar 23 2016
    Ontario,Canada
    Costco sells Energizer which are agm. They cost just over $200 which is almost 2x the Kirkland brand. Should I get the agm?
    Senior Member Three Rings rbish56's Avatar
    Nov 16 2018
    LSX swapped 86 cutlass 442
    chicago
    you cant really go wrong with kirkland brand. after 2-3 years and you dont like it return it. you know costco will give you your money back no questions asked. i returned a mattress after using it for 8 months and they refunded me the money before they even picked it up
    Apr 10 2019
    Which one? The cheaper one if you are prepared to replace the battery preemptively as a disposable item and not willing to assume the risk of having an inconvenient/annoying experience. Statistically the AGM will outlast the flooded one but do you want to play the odds? One event can kill a battery albeit unlikely. So it is simple. How much does the price difference matter to you?
    Mar 23 2016
    Ontario,Canada
    Sounds good.... now my dilemma is which one? H6 which is a direct replacement or the smaller one...H5 to save a bit on weight here are the specs for the 2.....
    H6
    Cold Cranking Amps – 730
    Cranking Amps – 910
    Reserve Capacity – 115
    Amp Hours – 70
    H5
    Cold Cranking Amps – 650
    Cranking Amps – 810
    Reserve Capacity – 100
    Amp Hours – 54
    Nov 02 2017
    CA
    H6
    Cranking Amps – 910
    Amp Hours – 70
    H5
    Cranking Amps – 810
    Amp Hours – 54
    Go with the H6, which has more Reserve Capacity and CCA - the extra capacity is nice if you don't drive it that often and the extra CCA will make it easier to start on the colder months compared to the H5. The larger battery is also less strained during start/stop...so in theory, should last a bit longer in the long run. I would really doubt that you will noticed a difference in the weight savings between the 2 (in terms of driving performance). I bet there won't be that much of a price difference either between the 2.
    I always put the largest battery that will fit in the battery tray in all of my cars for the reasons stated above.
    Mar 23 2016
    Ontario,Canada
    Thanks bud!
    Apr 19 2018
    11 Wall St
    Is Varta sold at dealers or in the US? Just pulled one from my 2008, can not find date codes...
    Senior Member Two Rings Why-man5's Avatar
    Dec 23 2016
    Savannah Ga
    At the top of the website, you can select your car. It shows an OE spec battery BCI group 48
    Sep 14 2006
    I'm located in Southern California and I was just told that costco didn't carry the battery for our cars. They have one for 540 CCA, but our oem battery is 640A. Guess I'll try autozone.
    Dec 25 2004
    Earth
    After looking around for a battery...Optima included...I found the local VW dealership had the exact battery and the best price. Especially since ya have to VCDS the battery on install.
