Results 1 to 12 of 12
    Active Member Two Rings Isstatu1's Avatar
    Feb 23 2019
    New Jersey
    Battery Charging
    I don't drive my 3.2 much so I wanted to maintain the battery charged in it. Does the battery have to be taken out of the car to be charged, or can I just hook up the charger to the jumper location under the hood and leave the battery plugged in as it normally is?
    May 20 2010
    If your charger has a trickle mode, you can just leave it in the car. That's how battery tenders work. Should be low amperage setting.
    Just be sure it's actually keeping it charged (sometimes I have to move my cables a bit to get a good connection)
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Feb 23 2019
    New Jersey
    Gotcha. I have a trickle maintainer/charger. Should I connect it to the battery or to the jump terminals?
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    Quote Originally Posted by Isstatu1 View Post
    Good question I would assume either would be fine.
    Battery would be ideal because then you don’t have to leave the hood open.
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    You can go to the battery, the front terminals or even to a 12V constant. The cigarette plug under the armrest is on all the time, so you could plug into that (if your charger has a 12V plug; you could fabricate one too).
    I personally have a "save a battery" 50 Watt charger that I leave a ring terminal set permanently tied to battery with the cord out to the trunk. That way, I just run an extension to my trunk and plug in when needed.
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Mar 27 2019
    When I trickle charge I do it under my hood
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    I've got one with a trickle charger, an overnight charge, and a several hundred watt (I believe) charge that's capable of starting the car through a wall outlet. In my experience, you can trickle charge either straight to the battery, OR through the terminals under the hood
    Sent from my PH-1 using Audizine mobile app
    Mar 27 2019
    Quote Originally Posted by a1dan_87 View Post
    Either one works ^ it’s what you prefer
    Jul 17 2011
    Sin City, USA
    Personally, I would use the terminals under the hood. This requires the power to pass through the power control module (connected to the positive terminal in the trunk). This module will regulate flow into and out of the battery. Connecting directly to the terminal in the trunk bypasses the module. Effectively removing a safety feature of the electrical system. That’s just my .02.
    '09 C6.5 A6
    Feb 19 2013
    I don't think there's an shunt in there to reading charge current, but I could be wrong.
    My dad's A8 has been using a charger directly to battery for about a decade with no ill effects.
    This is similar to what I have on my battery:
    https://www.amazon.com/Terminal-Conn.../dp/B079ZTBHYK
    Dead:
    Veteran Member Three Rings B. Rock's Avatar
    Jul 27 2008
    09 3.0T A6 Avant
    Do you guys have chargers with smaller cables than mine? Both my jumper and charger cables are very very close to touching if you're not careful, and have touched, since the + and - terminals under the hood are so damn close together.
    09 A6 Avant 3.0t
    06 E350 4x4 Cummins swapped
    01 WJ rock toy
    Aug 24 2014
    Newport Beach, CA
    This is what I use, not so much on the A6 but more so on my S4 which is hooked up to the trickle charger whenever I'm not driving it. You can get the quick disconnect which is what I have or the regular hookups that are extremely low profile and work on the A6.
    Charger (comes with low profile hookups): https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Quick Disconnect: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Extension Cable: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2024 M3 Comp xDrive
