For some reason my car does not launch/accelerate like it should from a standing start. Here is the story. Last summer I raced my car in some bracket races at Bandimere Speedway in Denver. My car, at the time, was bone stock. 2017 A6 3.0t (simos 16 ecu) premium plus, 7k-12k miles on the odometer. Being bone stock and at 5800 feet altitude, my car ran consistently in the 13.65 to 13.90 range at 102-104mph depending on if the temperature was 55 degrees out or 95 degrees out, humidity, barometric pressure, etc. My technique for launching the car was the same on every run. I put the car in Dynamic mode, shift into Sport mode, turn traction control off, turn the auto shutdown/start off (have this off by default now via VagCom mod), left foot on the brake, right foot mashing the gas (good old fashioned power braking). Once the tree comes down, I take my left foot off the brake and away I go. Oh, and I stage the same way each time as well, thus reducing the variance in my potential rollout to keep my reaction times and elapsed times consistent.
From April to September this worked fine. At the beginning of September I took the car up for a Saturday race. On my first run, I ran 13.72 @ 103.51. Approximately two hours later, I made my second run and ran 14.23 @ 101.43. A full half a second slower even though the temperature only went up 2 degrees and the corrected altitude only went up 500 feet. I automatically assumed I forgot to put the car in sport mode or I left the traction control or something like that. After 40 minutes I made my third run. I double and triple checked everything to make sure I had the correct setup prior to staging the car. This run I ran a 14.25 @ 100.50. Again, a full half a second slower and 3mph down from my initial run (again, there were no drastic changes to the weather or corrected altitude). At this point I started to freak out. Even though I didn’t have any check engine lights, I immediately hooked up my VagCom stuff to scan everything in the car. I was worried I had somehow damaged the transmission, torque converter, something. The scans came back clean. I scanned again the next day, then the next day just to make sure and the scans were all clean. No CEL (or any other warning) ever came on.
Incremental times to compare:
60ft 330’ 660’ 1000’ 1320’
2.144, 5.880, 8.935 @ 80.52, 11.531, 13.720 @ 103.51
2.177, 6.113, 9.312 @ 78.19, 12.000, 14.257 @ 100.50
The 60 foot times aren’t too far apart but the 330’ and eighth mile times there is a huge disparity. Losing 22 hundredths in the first 330 feet, 37 hundredths by half track is just crazy. For the rest of the races I ran in 2018, my car stayed in the 14.11 to 14.30 range. Again, 4 to 5 tenths of a second slower than all the other runs earlier in the year. The car essentially just stopped pulling and making power like it used to. Like some sort of governor was on the car from the get go. Very frustrating.
I logged onto Audizine and searched the forums for others who may have experienced this. I stumbled across the AMAX limit/counter that Audi installs on our cars. After reading all of the AMAX threads, I was pretty confident I had hit the limit of 200 launches and this was my issue. I was no longer freaked out, I knew I would need to get a custom TCU tune to have all the AMAX stuff removed (or at least have the limits raised to a point I would never encounter them again).
Fast forward to April 2019. Car just went over 14k miles. I jumped straight to APR stage 2 with the single supercharger pulley, new NGK plugs, using the 91 octane file, since 91 is the highest we have here in Denver). As for the TCU, I worked with Melen (many of you have worked with him as well) to get my TCU tuned via the HP Tuners software/hardware. He raised my shift points to 7100 (I specifically asked not to go all the way up to the new 7400 redline) and he addressed my AMAX limit/settings. Finally, now my car would be back to the way it was launching before, plus a bunch of new horsepower/torque and RPMs to work with. I was excited to say the least.
I went to a test and tune event at Bandimere towards the end of April. I made a total of 5 runs. The first run at 5:15pm was 13.198 @ 106.81. Disappointing for sure. The second and third runs were throw aways as I tried the car in manual mode instead of sport, and just regular drive mode to see if there was a difference. My fourth run (back to my normal setup and launching technique) at 7:48pm was 13.203 @ 107.04, and the fifth run at 8:47pm was 13.189 @ 107.08. I made 3 runs between 13.18 and 13.20. Nice consistency, but consistently slow, lol. For comparison, under similar weather conditions last year, I ran between 13.70-13.77. There is obviously still something holding my car back. It just doesn’t move in the first 330 feet like it should. I had the HP Tuners logging turned on for each run and during those three aforementioned runs, my 0-60mph time is pretty much right at 5 flat. Even at this mile high altitude there is no way an APR stage 2 single pulley, plus custom TCU tune, should be going 0-60mph in 5 seconds (Any Denver guys able to confirm your 0-60mph times with similar mods/tunes?). I pulled some VagCom logs on some additional runs on a different test and tune night for Melen to take a look at and he didn’t see any smoking gun. My car should be in the 12.70s, 12.80s easily even at this altitude, with the ECU and TCU modifications I’ve done.
Anyone have any idea what is going on here? I have some HP tuner graphs and some VagCom logs if anyone wants to take a look. Oh and it’s not something simple like heat soak (the IATs are fine), I accidentally left 400lbs worth of stuff in my trunk, bad gas (I fill up at the same place with Top Tier gas), tire pressures/spinning the tires (the pressure is only 1lb different this summer to last summer) things like that. Also had the 20k mile check up and oil change in January even though I was only at 13k miles.
My theory is there is a setting(s)/limit(s), either within the ECU or the TCU, that I triggered when I went over my 200 launch limit last summer. Even though APR and Melen flashed my ECU and TCU, respectively, I feel somehow this setting/limit carried over. Anyone else ever experience or heard of anything like this?
Thanks for reading and let me know if you have any ideas/theories.
