Results 1 to 22 of 22
    Apr 25 2019
    clinton maryland U.S.A.
    Battery replacement for B8 A4 quattro 2.0l
    the mechanic charges me almost $500 for replacement and programming for new battery. Is there any thing that i need to know or how to do it DIY?
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    I got a Interstate battery that was correct size for my car and replaced myself, since I have a Ross-Tech cable I was able to go into module for battery and update serial number by one digit and good to go.
    You could install new battery that meets specifications for your car and not recode anything and it will work but your system will think it is still the old battery
    Apr 25 2019
    Thank you rcprato
    Established Member Two Rings TLR_0125's Avatar
    Apr 23 2019
    East Coast
    I installed a new battery on my b8.5 and didn’t have to do any coding.
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    $500?!? At that price you an buy a battery and a vcds cable and you'd still end up spending less. The dealer doesn't even charge that much. Sorry to say but you got seriously screwed.
    Reprogramming takes 10 minutes at most.
    2011 A4 Avant Prestige S-Line
    Established Member Two Rings AudiInMPLS's Avatar
    Apr 20 2018
    2018 Forester Touring
    Minneapolis
    Quote Originally Posted by rcprato View Post
    what's the harm if it still thinks it's the old battery?
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    Quote Originally Posted by AudiInMPLS View Post
    Re-coding tells the Energy Management S/W that a new battery has been installed, and therefore, it has a different discharge rate/state than the battery which has been (previously) installed for X years. It is an algorithm to determine how the alternator charges the battery.
    You can use an aftermarket battery in-place of the OEM battery, however, re-coding should still take place. With regard to re-coding (with a VAG-COM), since an aftermarket battery will not have a S/N, the existing S/N should be incremented numerically (a "dummy" S/N) so the Energy Management S/W sees a new battery has been installed.
    As for the OEM battery, depending on the battery P/N, some OEM batteries are cost competitive with their aftermarket counterparts. I'm on my 3rd Audi, and I typically get around 8 years on the OEM battery.
    From GenuineAudiParts (I picked a 2010 A4):
    https://genuineaudiparts.com/parts/2...bgroup=BATTERY
    Check your P/N to determine the OEM CCA rating (380 - 580 CCA) in this example.
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, DTE Systems PowerControl X & Pedalbox Pedal Tuner, AskCarbon Steering Wheel, ROW Tailights
    2021 SQ5 S/B Prestige - Daytona Gray/Black
    Apr 20 2018
    Minneapolis
    FFS, a guy cannot just work on a car with a wrench anymore!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I picked up and installed a new battery yesterday. Usually I purchase OEM batteries from the local VW dealer for a competitive price. However, this thread Clicky click® inspired me to do a little research. This battery Clicky click® matched the specs of my OEM battery right down to the part number, manufacturer and BEM code. When I coded it in VCDS I only had to change one line of code.
    The price was $165 plus there was a 25% discount code if I bought within 72 hours. I purchased it online with a local pickup from the store down the street. After returning the core my total price ended up being $132.
    Established Member Two Rings the-quattro-man's Avatar
    May 16 2018
    Sunshine State
    ^Have the same battery - fits and works great.
    Feb 15 2016
    Cambridge,Ontario
    a battery is a freakin battery ! when did we turn into complete morons and decided it had to be something special and panic over it ? Jesus Christ !!!
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    I buy my batteries at advance auto, usually AGM Platinum or Gold autocrafts, because they are made by the same company that makes the OEM batteries, johnson controls. I use a 25% off coupon code on retailmenot, and pick up in store. I've done the cold reset shortcut by just changing a digit in the part number, but i was told that it automatically resets when it detects a new battery after a certain number of hours.
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    No one is panicking. The OP just asked a simple question. Audi designed it this way; and there is a by the book procedure. One can choose to follow it or not.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Veteran Member Three Rings S-Liner's Avatar
    Oct 21 2014
    Illinois
    I went OEM from the dealer and paid $220 outright, installed myself.
    '10 A4 Avant Prestige Plus S-Line w/sport pkg
    My Oil consumption results..."Oil consumption measurement found to be using 3.26 quarts per 1000 miles"
    Jun 04 2016
    A
    The other day I was desperate as I had a flat battery.
    Went to the local battery shop and they didn't program.
    from memory it was the LN6 Delkor AGM battery that costed me $635. (I think it was a 1000amp?)
    but yeah, what happens when the ECU thinks its the old battery?, will it eventually display a replace or check/replace battery alert in the MMI?
    Jul 02 2017
    Knoxville TN
    $635!!! Wtf
    Jun 04 2016
    A
    Yeah bro. Shit in Australia is expensive....
    Senior Member Two Rings LmG7119's Avatar
    Jun 03 2014
    MNN
    Quote Originally Posted by Spawne32 View Post
    How do I know which part number is for my allroad? Advance auto has like 5 same batteries compatible with my car with different PR-XXX.
    The dealer has one for $240 plus 10% discount for Audi club. Their battery carries 5 years full replacement.
    2013 Allroad Premium Plus UM stage 1
    2003 Allroad EPL Stage1+ straight downpipes catless(sold at 187K miles)
    Nov 20 2016
    Quote Originally Posted by lepa71 View Post
    There is no specific part number, you can run the biggest battery they offer, which I think is the H9, the bracket accepts 3 different sizes, H7, H8 and H9. The different factory equipped batteries had alot to do with the options, for instance cars with auto start stop had the larger H9's in AGM, but any of these will work for your car. I think I put a autocraft gold H8 in mine and it was originally the smaller H7, id have to check the receipt, I know it was the larger of the two.
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by doublespeeded View Post
    You didn't say it was in Australia. That's about $445 US which is better but still a lot.
    Jun 03 2014
    MNN
    Does it make sense to get AGM? Mine is the original from late 2012. I think I'm pushing it. The local store has AutoCraft Platinum AGM Battery, Group Size H8, 900 CCA but 950 is out of stock. Price is the same for both.
    Nov 20 2016
    I mean it's really a matter of budget, AGM batteries are better quality, more durable and do better in the cold weather. With the correct coupon code you can get it pretty cheap as well at advance. Worth the investment in my opinion.
