Results 1 to 16 of 16
    Veteran Member Three Rings SickAvant's Avatar
    Nov 12 2006
    FL350 Oddysey, Sick fun! Google it!
    Burbank, CA
    Water Pump Replacement.
    Looks like I am going to have to replace my water pump, it is leaking like a MOFO!. Any suggestions on what else I should get done, while its apart? All suggestions are welcomed. My car has 93k, 12' Avant 2.0T .. Thanks
    Jan 03 2013
    Baltimore
    If you are going to pull the IM to do the water pump that's a good opportunity to do a valve and intake carbon cleaning.
    Sent from my Pixel 3 using Tapatalk
    Feb 15 2016
    Cambridge,Ontario
    you can do the water pump without pulling IM , but if i was, i would do as above and even consider throwing in 4 new injectors and seals.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 14 2018
    Irving, TX
    Need to replace the water pump and thermostat housing, which are connected and can be purchased together. The actual leak is very likely the plastic housing, and not the water pump itself. I had such a hard time with this DIY, because it's a bear to remove the bolt that gets the water pump belt off. The water pump kit I got was after market. The pump gasket was cheap and just leaked after install. Had to reinstall my original pump with the new thermostat housing. And... it was hard but did so without having to remove the water pump belt (and that terrible bolt Audi put in - there's a special tool for it). It's been good for over a year, but was a stressful job because of that darn bolt. I stripped the heck out of it. Hopefully you get through that ok, because it's better to replace the housing, pump, and belt when in there. Many have success doing the job, but mine went about an odd way.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Go with one of the new metal housing water pumps, it will save you alot of headaches d own the road. https://www.fcpeuro.com/products/aud...af-06h121026dd
    If you do replace the injectors, only because its easier to remove the intake to get more hand room. BOSCH 62819 can be had for about $54 dollars a piece, you need 4, comes with all the seals.
    Nov 12 2006
    Burbank, CA
    Carbon Cleaning, injectors, spark plugs , coil packs, alll have already been done..
    Nov 12 2006
    Burbank, CA
    Quote Originally Posted by Spawne32 View Post
    Thanks for all the info. I don't think I will be doing the job myself, unfortunately I'm unable to I'm a paraplegic and its abitch for me to work the car.. it sucks that I have to pay someone to do all the work on my car, because if i could I would tear the whole car apart myself... Oh well I guess it can all be worse.. Thanks again for all the info..
    Aug 30 2018
    Quote Originally Posted by SickAvant View Post
    Don’t stress about that - trust me most of the time nothing goes easy and the stuff you see on TV and youtube excludes endless cleaning, stripped bolts, impossible to reach items that makes DIY a frustrating nightmare sometimes..
    Veteran Member Three Rings A4Triple Blk's Avatar
    Jun 10 2008
    Past - 2004 A4 1.8T Quattro 6 Spd
    LI
    Quote Originally Posted by ps2cho View Post
    This. This times 1000. OP, did you have a B6 ever? I feel like I recognize your name from the B6 forums and the avatar lol.
    B8 2011 A4 Premium+ 6 speed
    Used to B6 it
    Apr 30 2018
    Orange County, CA.
    The water pump is a big job. I've done some pretty big car repairs and this one ranks up there with one of the hardest and longest i've done. There are several "unknowns" I ran into.
    Jan 04 2018
    Modesto
    Are the coolant pump and water pump the same thing? Why not have it replaced under the recall?
    Nov 20 2016
    Quote Originally Posted by muffinman92 View Post
    No, if you look down by the power steering pump, just below the alternator, you will find the "after run coolant pump" which cools the turbo down after engine shutdown.
    Aug 17 2015
    California
    Do all model years have this, 2009-2016?
    Nov 20 2016
    Quote Originally Posted by A4x View Post
    They should, I'm an 09 and I very clearly have it, theres two different part numbers depending on the production date if you look on ECS.
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    My 11 has it but I thought it was at the back of the engine. Will have to check.
    2011 A4 Avant
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by jfo View Post
    Correct my 14 is back of the engine too
    Sent from my SM-G973W using Audizine mobile app
    1976 Yamaha XS 360
