Results 1 to 40 of 51
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Another SC intercooler leak after only 3,300 miles
    So as the title says I just went through a leaking intercooler repair and only 3,300 miles ago! It was a mess as I needed a full carbon clean because I drove too long with the leak. Coolant was everywhere and even the injectors needed to be pulled to get cleaned. New o rings were installed and even the intake manifold pulled for a proper cleaning. I took advantage of the SC getting pulled and had a S4Matty blower installed with new intercoolers I bought from AudiUSAParts.com with part number that's ends in "R".
    Had all this done at 46,600 miles and now I have 49,900. Cyl 3 plug looks bad and coolant reservoir is low (pics attached) Plugs were installed at about 37,500 miles. BKR8EIX gapped to .025"
    On top of that cyl 1 plug had gas on it which I'm told is an injector failure!
    I have a AWE coldfront without the pump which is a divorced set up. I'm thinking my issue is having a divorced system and too much pressure building up. Just seems like I should not have another cracked intercooler already. Not sure how the possible injector failure plays into it or if there is anything else going on. I had a friend take a log about a week ago and noticed cyl 3 and 5 had some correction. This could have been taken right before or after the issue started, not sure.
    Is the solution as simple as having a vented cap? This is a huge PITA and it's my daily driver. Any possible suggestions would be appreciated!
    Marco
    Sent from my SM-G965U using Audizine mobile app
    Jul 21 2004
    South Florida
    I dont want to add to your confusion on how to try and reduce the chances of serial IC failures but just to offer a datapoint...
    I've had 3 different 3.0T cars. Two of them have been dual pulley with divorced hx setups. The Revo reservoir is pretty much identical to your AWE one. Ive run the car hard to redline just about daily doing 20mph to 100mph WOT runs on backroads I take daily. A fair amount of drag strip duty which involves heat soaking the car to all hell in the staging lanes then beating the piss out of it down the track.
    Ive yet to have an IC failure or a cat failure.
    Am I jinxing myself by typing this? Not sure. I definitely fear it will happen any day but thus far, nothing.
    Why am I lucky and others not? Maybe it really is luck. Maybe there's something else besides just divorced vs not divorced setups and adding pressure reliefs. Not sure.
    I can say that I have run any pulley ratio from 2.85 to 3.5 on these setups but 90% of my time has been on a 3.16 pulley ratio. That may help limiting the amount of boost through these cores. It may also help that I am religious about monitoring IATs. I keep IATs on my gauge screen at all times. It would only be a rare instance of testing a new cooling setup where I would see IAT above 70C. Almost never. Maybe it helps that I generally am successful in keeping IAT at 65C or well below even during all the torturing of the car. Not sure on that one either. I also live in south florida. So is it easier on the metal IC cores to always be going from warm weather to HOT iats vs people up north who could be going from 30 degree cold metal cores to 150 degree IATs. Not sure either. I know Loe used to go through IC cores like they were candy and he lives in FL too so not sure. Just helping to think out loud with you.
    It may very well be dumb luck on which cores can take DP power and for how long.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    Quote Originally Posted by bhvrdr View Post
    Mike
    We should meet up Mike, I'm living rn on South FL, Coral Gables and do some runs
    Sent from my Pixel 3 XL using Tapatalk
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Jul 21 2004
    South Florida
    Quote Originally Posted by maty360414 View Post
    Awesome. Im moving this month nearby but going nuts with it so this summer definitely.... lets hit pbir on a Friday testntune
    Sent from my SM-G935V using Tapatalk
    2018 Audi S5
    Gone-
    Oct 13 2015
    SoFlo
    What is PBir? Palm Beach? That's so far from where I am. Wanna do some Mexico runs
    May 05 2018
    South Florida
    Im close to coral gables as well. If yall meet up let me know.
    Oct 13 2015
    SoFlo
    Quote Originally Posted by killer_s4 View Post
    I can meet with you since your close
    Mar 20 2018
    Hanover, Maryland
    This is why i did the self bleeding intercoolers that dump back into my divorced reservoir
    Established Member Two Rings fx_warrior's Avatar
    Sep 18 2013
    Bronx NY
    Could of sworn I read in one of the facebook groups that the new IC's are a problem and to get the older ones, which ever parts numbers those may be.
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Quote Originally Posted by TruS4 View Post
    Self-bleeding heat exchanger you mean?
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Thanks Mike. I don't know but my luck is no bueno lol
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by fx_warrior View Post
    Could be, my original ones lasted me 24k miles on DP. Only thing I changed was ported blower with those "R" revision intercoolers. I only have a 183mm crank pulley 3.17 ratio
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    I was told the opposite, and to get the R’s cause they are better made. Does anyone have a definite answer on what is the best revision?
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    it's due to pressure build up in the system when the pump shuts off. If you install a bypass line, you'll see fluid jump up into the line. I've been running for almost 4 months without issue ever since I installed a bypass line on my reservoir (i recently had my S/C removed + cores for inspection). The fluid contained in it goes back into the reservoir as soon as the pump turns on.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Apr 26 2017
    GLS 450
    Nashville, TN
    Quote Originally Posted by Loe View Post
    My AMS system keeps the pump on for a little, after the engine is turned off. Do you think this helps any?
    Previous
    Feb 21 2017
    Denver
    Can you expand on this? A bypass from where to where? Any chance you could write a short DIY?
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Thank you Loe! This sounds like a promising fix, how do you hook up this bypass line?
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Quote Originally Posted by brs2c View Post
    I have the same question also its not divorced so that may help as well?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Quote Originally Posted by cspcrx View Post
    I think a divorced system may also provide this pressure release benefit...depending on what reservoir you run. My divorced reservoir is more like a surge tank and I don’t believe it’s completely air tight. It doesn’t have to be because the s/c coolant loop won’t get that hot on its own where the coolant has to be pressurized to avoid boiling.
    I’ve been running this way for almost 30k now...
    Jan 04 2013
    Phoenix, az
    I’ve had my AMS system in place for also 40k miles with no issues but I don’t push my car as hard as others. Doesn’t seem like there is a common denominator with those who see them fail.
    Aug 09 2015
    Sarasota, FL
    i'll take a picture some time this week and post what I did, but what a relief (pun intended)
    Oct 14 2012
    Empty...for now...
    SE PA
    What are the symptoms of leaking SC intercooler(s) other than some amount of coolant loss detected at the reservoir? For a couple years, approx. 25k miles, I have been dealing with rough/hunting idle, decreased gas mileage, decreased power output, poor throttle response, some mysterious coolant loss and some oil consumption. Some people say all signs point to PCV failure, others say it's due to excessive carbon buildup on the intake valves. I am taking the car to a shop next week to have the PCV and thermostat replaced, as well as to have the intake valves cleaned. I have asked them to inspect the SC intercoolers for leaks while they have the SC removed.
    The few times I have scanned for fault codes I have found none. Do my symptoms sound indicative of SC intercooler leak? Would a leaking SC intercooler be evident via pressure test of the coolant system? Basically time is money and I only really want to take the car into the shop for a 2 day service one time, so if I can kill multiple birds with one stone on this visit it would be ideal.
    EDIT - For reference my car is a 2015 S4 with 56000 miles, with original PCV, tstat and waterpump installed. I have not carbon cleaned the intake valves previously.
    SOLD 2015 Daytona Gray S4
    Jul 14 2017
    Maine
    My AWE cold front divorced set up runs for like 5 mins after I shut the car off and it runs anytime I do anything (like open a door, etc) which is overkill but I'm approaching 50K miles (tuned for 40K) with no coolant issues / leaks.
    2015 Audi S4 APR Ultra charger with Dual Pulley 3.18 ratio, APR DSG tune, AWE touring exhaust with resonated down pipes, Red Star Test Pipes, ECS intake, AWE Coldfront (all), H&R sway bars, ECS rear diff mounts, ECS Control Arm Brace, CR-15 Front Brace
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Bummer Marco, what the heck are you running HCL .
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Haha looking forward to that. Don't want to fix my car until I have a fix for it!
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by SteveYem View Post
    Easiest way to find out is look at cyl 3 plug, always leaks onto it
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by scls4 View Post
    I don't have the pump, maybe I should think of getting it?
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by RWD2quattro View Post
    Dude, the only thing I changed was ported blower. Been running the same set up for a long time. 183mm crank, NGK Iridium plugs, AWE coldfront without the pump
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by ModItNow View Post
    Would I be looking for a pool of coolant, or some residue? If the latter, what does the residue look like?
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Residue on the actual spark plug
    Jan 04 2013
    Phoenix, az
    my AMS does this as well. Not five minutes but a minute or two for sure.
    Jul 21 2004
    South Florida
    The ams unit acts like you cut the pwm signal i believe. Youll see a softcode for coolant pump. This is same as how my pump behaves with the pwm cut. No issues for me either.
    2018 Audi S5
    Gone-
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Sounds like I might need a pump, in what location do you install this? Or should I try the pump mod first?
    Dec 29 2011
    The Bay
    Pump mod is the least expensive (cut a wire) but you will always have a soft code but you can install a switch for on/off, up to you. If you install a switch, you can leave pump running for a few minutes after shutdown to help with cool down. Call EPL and see if they can ramp up coolant pump speed on start up or keep on for a few minutes during shutdown. My AMS pump starts up anytime I touch the car and shuts down after 3 minutes, I think the byproduct of that cycle helps prevent IC failures. By the way, I'm still on my original IC's going on 94K miles.
    Senior Member Two Rings m1k3d3's Avatar
    Jan 31 2017
    Philly
    Isn't the factory cap designed to release that pressure at a certain point?
    2015 S4 Sepang Blue | 6MT | Tech | B&O | Leather | Carbon Atlas | Black Optics | Sport Diff
    ECS Kohlefaser Luft-Technik | Bilstein PSS10 | ECS 10 & 12.5 mm spacers | USP Stainless Steel Clutch Line | Suntek CXP 35% | 034 Drivetrain Mounts | RS4 Grille
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Damn 94k! Yeah makes sense, I bet having the coolant circulating through for a few minutes after helps with cooling everything down. Maybe I'll look into the pump that AWE uses since I have that system.
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by m1k3d3 View Post
    No sure but we have a divorced system (SC separated from the engine coolant loop) so we would be looking at something custom. What Loe did (bypass line connected to the reservoir) sounds promising
    Mar 05 2015
    Exway x1 pro
    Bay Area
    May 12 2008
    The main cooling system, sure. But not the divorced s/c cooling loop.
    Sep 03 2018
    AB, Canada
    That plug certainly looks a bit off. Were you able to take off a plug that was far away from #3 to compare?
    The orange bits on the ground electrode would make me think the coolant has contaminated the combustion chamber.
