Results 1 to 8 of 8
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    3.0t custom intake
    Figured I'd start my own thread instead of hijacking someone else's.
    So far, I haven't seen anything super in-depth. Anyways, im ordering pieces for a custom intake, retaining the stock airbox, but replacing the filter and throttle body inlet hose. This is mostly an upgrade for those wanting extra noise, with debatable performance increases (especially at stage 2, custom tunes, other parts, etc [my car is stock])
    Anyways, onto parts. Ive seen others with 3.0tfsi engines, claiming that aFe filter part #10-10121 (Pro 5r to my knowledge) is usable. Taking a look at our stock air filter, it's clear without modification to the breather hose that won't work- as the two are connected. Possibly installing the aFe filter, blocking the breather hose pathway, and installing a "universal" external filter on the breather hose.
    Also. Any aftermarket throttle body hoses seem to be off the table. The plastic nipple for another breather hose is at a different angle (facing passenger side on the S4, straight out on the SQ5, while ours is facing driver's side), eliminating that fit.
    Any thoughts or ideas, or should I just go spend an extra few hundred on an open air USP or roc-euro?
    Sent from my PH-1 using Audizine mobile app
    Mar 07 2018
    Utah
    Here's where you can see where the hose connects to the air filter.IMG_20190423_180020.jpeg
    The eurocode throttle body hose here https://www.ecodetuning.com/EC0407-0...si-109-95.html looks like it may be a more fitted-fit? https://www.ecstuning.com/b-ecs-part...00931ecs02akt/ as well
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    If you just want sound change the filter and gut the airbox.
    Or roc euro which is loud and joyous
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
    Mar 07 2018
    Utah
    Quote Originally Posted by DC Dawg View Post
    I think I'm just gonna save up for roc euro. Took out the foam from the airbox, haven't driven it yet
    Dec 31 2018
    Chevy Chase MD
    Quote Originally Posted by a1dan_87 View Post
    Good call.
    Mar 24 2008
    Sacramento
    My rkx intake tube and afe filter showed up today (used from rkx for 95 shipped). Looks like I'm going to have to trim at least 2" off the airbox side of the rkx hose. The small hose near the throttle body shouldn't have any issue mating to the rkx hose as they included an elbow and if that doesn't work I can use a straight piece. I ordered the sai breather filter from apr (same piece the include with their intake systems) and I hope it fits our sai hose. The apr breather shows up this weekend so I hope to have installed everything by then. Will update
    If this works, not bad for $130ish
    Dec 01 2007
    Orange County, NY 10918
    Its can be done with the right tools and time. We were working on a few but time and life got in the way....unfortunately
    But total parts $130 or so.
    https://www.instagram.com/p/BdjFaJ8g...id=abmfb0p4cmj
    Sent from my SM-G960U using Tapatalk
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Mar 24 2008
    Sacramento
    Got my rkx in with a bit of trimming. Will do a bit if driving and will then post a quick lil DIY with pics
