Results 1 to 11 of 11
    Jul 25 2009
    Bellevue, WA
    Weights for 20" OEM B8.5 Q5 wheels?
    Hey, I've been searching and didn't find anything.
    Just bought a 2016 SQ5 with 20s. They are the split spoke. I also have a line on some 20" peelers. Wondering if anyone knows the weights of the different OEM 19s for the Gen1 Q5s? I love lightweight wheels but the OEM look is pretty strong as well. Just wanting to understand the starting point before I go shopping for aftermarket.
    '16 SQ5 ROW/BilsteinB8 CH-R 9s; 997.2 spasm 6spd; '18 Macan S. Many, many audis in the past...
    Mar 12 2017
    N.C. USA
    Don't know anything about weights,but I put the 20" stock wheels on my 2016 Q5 & then had them powder coated gloss black. They are very strong-just came back from a 1500 mi trip on some very bad roads that I thought would test any wheels strength & no problems. Was not impressed with the split spoke design in silver,but they look very good in black on my glacier white Q5 with H&R sport springs. Glad I had 45 ratio sidewalls for the beating my wheels & tires took.
    2020 Q5 prem plus Matador red/Beige
    Jul 31 2017
    Brooklyn NY
    Quote Originally Posted by scottst View Post
    Here's some numbers I have scribbled down for some Audi wheels, note the SQ5s are real pigs:
    Standard 19" Double Spoke on Q5 are 29.5 lb
    Standard 20" Y Spoke on SQ5 are 34.2 lb
    Standard 21" on SQ5 are 35.3 lb
    20" Peelers ET 33 are 32.6 lb
    20" V-Spoke ET 33 are 31.3 lb
    20" Rotors ET 26 are 31.1 lb
    20" Forged 7 Double Spoke 20x9 ET 35 are 26.0 lb
    Feb 18 2019
    Colorado
    Ive got my 20" peelers sitting in the garage, I can weigh one if you want to know the exact weight. They will be my winter wheels next year so just sitting there for now.
    '16 SQ5 Lava Grey Pearl - Prestige Black Out - 034 Xbrace,RSB,Endlinks (AWESOME) - APR Open Intake/034 Intake Hose - AWE Exhaust -Stealth Hitch -
    '07 B7 Black Titanium S-Line A4 with 6 speed MT, JHM Test Pipe and Exhaust, KW v1 Coil-overs, JHM Stage 2 tune
    Jan 08 2016
    Los Angeles, California
    Quote Originally Posted by Silver_Bullet View Post
    What are the OEM forged wheels you refer to at the bottom of the list?
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    Jul 25 2009
    Bellevue, WA
    Thank you! Great to have this information. I am currently running v-spokes, I think. I sold my old Peelers off of our s-line Q5 because I thought they were pigs. Turns out my new 20s are 1lb lighter <ha>. Should have kept the peelers around.
    Jul 31 2017
    Brooklyn NY
    Quote Originally Posted by Pittdawg View Post
    4G8 601 025 BA, it's an RS7 wheel, nice and relatively light and an actual forged Audi wheel.
    They are all disappointingly heavy! The SQ5s are the worst. But they also don't bend so easily like some of the aftermarket wheels.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Which one above is the 20” 5 spoke OEM used in the summer tire package on my ‘17 S-Line? Would like to know the weight.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Jul 31 2017
    Brooklyn NY
    Quote Originally Posted by MSq5 View Post
    Hey MSQ5 do you have a part number? I think I found your wheel 8R0 601 025 CJ is 32.4 lb. Vorsteiners 20x10 ET30 are running closer to 22 lb - maybe that should be on your upgrade path!
    I had to dig a bit to find where I sourced those weights - I ended up having it bookmarked - it is a German company that does the OEM wheels. It is the mother load for all your Audi OEM wheel weights. There can be multiple iterations of a particular wheel design so make sure you check against your actual part numbers.
    https://www.original-felgen.com/audi/q5/8r/
    Feb 14 2017
    Gulfport, MS
    Yep. Thanks. That’s the one, unfortunately. 14.7 kg, about 32.4 pounds. 😩. But, right there in the middle range of the OEM 20” wheels on the list.
    I would have thought the open 5 spoke design would have been lighter. At least they are easy to clean! I’ll pull one and weigh wheel/tire and deduct the known tire weight.
    I see an upgrade in my future.
    Jul 31 2017
    Brooklyn NY
    I was originally going to get a set of the 20" SQ5s because I figured they must be reasonably light on an S car and lighter than the 21s. Then I realized they were also super pigs. Tsk Tsk Audi putting heavier junkier wheels on a sports variant, you'd never see an M car do this.
    A lot of those 20x10 ET30 Vorsteiner variants are listed at 21.8 lb. MOPS is going to sell me a set it's just a matter of time!
