Figured I should start a build since I have been slacking on it.
Here is the planned build:
Motor
Motoza tuned
DM Forged Rods
Mahle Powerpack Pistons 83mm
ARP head studs, main studs, cam tower bolts, and crank bolt
Calico coated rod and main bearings
IE timing gear pin kit
Ferrea valvetrain
Twinscroll EFR 7163
Turbosmart wastegate
Mint Performance twinscroll manifold, downpipe, intake, compressor outlet and TB pipe
New OEM oil pump
CTS Turbo silicone intercooler hoses
AWE exhaust
Evolution Racewerks SMIC
S3 injectors
IE HPFP internals
155bar PRV
CTS Turbo throttle body spacer
Snow Performance w/m solenoid
AEM WMI
K&N Air Filter
Torqbyte PM4
JHM pick your pump kit
Walbro 450
Drivetrain
JHM stage 1 clutch and LWFW
USP metal slave cylinder w/ braided clutch line
JHM short throw shifter
034 motorsport street density motor mounts
Density line transmission mount
Suspension and Brakes
JHM 2 piece front rotors
Hawk HPS pads
Goodridge braided brake lines
H&R sport springs
Bilstein shocks
RS4 rear swaybar
Misc.
45mm Prosport oil pressure gauge
Draft42 oil pressure sender relocation kit
ECS 45mm vent pod
Newsouth steering column pod
Podi dual display boost/AFR gauge
Borg Warner turbo shaft speed sensor
Ebay defrost vent gauge pod
PTP EFR turbo blanket and Lava exhaust wrap
I'll get some pictures in here soon. Currently waiting on the w/m solenoid to stop her from siphoning and get her running a bit better. Have a short list of things that need fixing, leaking intercooler piping, leaking valve cover gasket, she's underboosting and not even hitting wastegate pressure and the water meth.
