Results 1 to 16 of 16
    Nov 07 2018
    DMV
    3.0 Random misfires after timing belt replacement
    I just did a timing belt replacement along with water pump, thermostat, front main seal, tensioners, two vacuum lines (the brittle plastic ones), and power steering hose. I drove it fine the first day about 3 miles round trip. Today after about 2 miles OBD threw a random misfire code along with misfires on 5 cylinders. It's idling a little rough around 760rpm when before it would sit around 800rpm. Still drives OK outside of idle.
    Any ideas on what to check first? I have a VCDS cable coming in the mail as well, should I wait for that to arrive before doing anything else?
    Veteran Member Three Rings 2004a4b630QT's Avatar
    Mar 30 2015
    '04 A4 3.0 QTip
    Sounds like a vacuum leak. Check your vacuum lines. Make sure you didn't break any of the connection points or leave anything unplugged. Also try swapping ignition coils to see if the misfire is coil related or not. The 3.0 coils are a failure point. Check for oil in spark plug well too for cyl5.
    Nov 07 2018
    DMV
    It's 5 different cylinders, not just cyl5. I'll double check my vacuum work, maybe it worked loose after running. If it makes any difference I filled the gas tank with 93 Oct right before the check engine light. Does anyone know if I can use VCDS to narrow down the issue if my vacuum lines aren't the problem?
    Mar 30 2015
    '04 A4 3.0 QTip
    Yeah you can use it check your timing. I'm not sure which measuring block but it's been mentioned more than once on the forum
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    You can check the cam angle/phase with VCDS to see if timing is normal. You could also check the air/fuel ratio just to make sure it isn't running lean.
    Sent from my Pixel 3 XL
    Jun 30 2008
    Erie, Pennsylvania
    ^ I second this. Check cam phase with VCDS. On the 3.0, I like to check it after I'm done with the t-belt regardless, just to make sure it's all in spec.
    Senior Member Three Rings jj94tt's Avatar
    Feb 24 2011
    Pittsburgh
    I had a random cylinder misfire problem that went away (knock on wood) when I replaced gaskets during an intake refresh. I don't remember if the intake manifold comes off during a t-belt job, but if so, I wouldn't reuse gaskets.
    Also, this has been discussed before, but if the intake changeover valve is not working properly, maybe that could be contributing to your problem.
    I am not exactly sure what fixed it for me because I did all of the following:
    new changeover valve
    new plugs
    cleaned injectors with new o-rings
    new tb gasket
    new manifold gaskets
    cleaned manifold ports
    new valve cover gaskets
    *note* did NOT replace any coils
    2005 A4 B6 3.0L 6MT USP Ocean Blue
    USP CLUB MEMBER #230
    Oct 07 2018
    New Haven , CT
    I just went through the same exact issue and drove me insane. couldn't figure it out for 2 months until literally this weekend found one of the vacuum lines that I believe went to the PCV and one of the brittle plastic tubing that go to the PCV off the back of valve cover cracked so slightly that you couldn't hear it or see it . Would cause a random misfire code that would only go flash when cruising in gear and letting off the gas. and when coming to a stop the idle would drop ever so slightly than go back up..Had the same symptoms and thought I had the timing off a tooth and didn't want to redo it . when removing the valve covers the lines are so brittle . So yeah hopefully that's your issue also..... good luck
    Nov 07 2018
    DMV
    Quote Originally Posted by jj94tt View Post
    new plugs
    new tb gasket
    I did replace the gaskets on the timing covers, intake manifold didn't come off. I'll have to look into that intake manifold valve and how to tell if it's working correctly, thanks for the heads-up.
    Nov 07 2018
    DMV
    Quote Originally Posted by WerkzINC View Post
    I did replace two brittle plastic lines. The first ran from a T split next to the power steering pump and ran along between the intake manifold and the timing cover and came up underneath the vacuum system tray and connected to a T fitting between the check valve and another part. The second one I replaced ran from the same T fitting by the power steering pump and behind a plate that attaches to the block underneath the camshaft gears. That one connected to a line near the power steering reservoir behind the driver side headlight. I double checked both of those replacements, I'll make sure to triple check them again.
    It seems to drive fine whenever I'm moving. I noticed today that it was having a bit of trouble starting, though I don't remember if it was from a cold start or not. I'm planning on dropping by a parts store and having the battery checked.
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    When I bought my 3.0 used, right away it had a couple of driveability problems; one was a sudden temporary lessening of torque, as if I was letting up on the throttle when I wasn't doing that. That was the brake light switch going bad.
    The second was similar to what the OP describes; I would call it a surging, which may have resulted in misfire codes. I'm not sure because away from my notebook now. That was caused by a failing crankcase pressure control valve.
    Veteran Member Four Rings euronyc's Avatar
    Sep 22 2009
    many
    NEWYORK SUFFOLK LONGISLAND
    codes?
    Nov 07 2018
    DMV
    Quote Originally Posted by euronyc View Post
    codes?
    The first time was p0300, p0301, p0302, p0303, p0304, p0306. That was the second start after reassembling the engine, engine was warm. After clearing codes it came back as p0300, p0301, p0302, p0303. That was the 4th start, engine was warm. I haven't driven it since. I suspect it's on startup since the first time it would detect a random misfire it wouldn't throw a CEL, but it would the second time. I'm planning on driving it around some more later today and setup my VCDS cable and get more detailed info, I'll post here when I have more information.
    Nov 07 2018
    DMV
    Quote Originally Posted by Turbo510 View Post
    I'm not having any driveability issues, i did a few 2nd gear pulls and it felt good. I had planned to getting around to checking the PCV in the future anyways in an effort to reduce oil consumption, maybe I should bump that up in priority.
    Nov 07 2018
    DMV
    Sunday,28,April,2019,00:10:02:32302
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
    Data version: 20190114 DS296.0
    www.Ross-Tech.com
    VIN: X License Plate:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: X Mileage: 262300km-162985miles
    Address 01: Engine Labels: 06C-909-559-ASN.lbl
    Part No SW: 8E1 909 559 B HW: 8E0 909 059 A
    Component: 3.0L V6/5V G 0030
    Revision: 00000000 Serial number: AUZ6Z0D0235028
    Coding: 0013711
    Shop #: WSC 63351 000 00000
    VCID: 3537205BF956944F7DB-5160
    7 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 - - Intermittent - MIL ON
    16685 - Cylinder 1
    P0301 - 008 - Misfire Detected - Intermittent - MIL ON
    16688 - Cylinder 4
    P0304 - 008 - Misfire Detected - Intermittent - MIL ON
    16687 - Cylinder 3
    P0303 - 008 - Misfire Detected - Intermittent - MIL ON
    16686 - Cylinder 2
    P0302 - 008 - Misfire Detected - Intermittent - MIL ON
    16690 - Cylinder 6
    P0306 - 008 - Misfire Detected - Intermittent
    16689 - Cylinder 5
    P0305 - 008 - Misfire Detected - Intermittent
    Readiness: 0010 0001
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 4529
    Coding: 04495
    Shop #: WSC 06435
    VCID: 2615F71731F0EFD7C41-51CE
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-10 - - - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1424
    Coding: 00000
    Shop #: WSC 63351
    VCID: 6393AE0302425AFFE3F-513C
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    30-00 - Open or Short to Plus
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 00011
    Shop #: WSC 00000
    VCID: 3537205BFC56944F7DB-4B00
    1 Fault Found:
    01800 - Light Switch (E1)
    27-00 - Implausible Signal
    Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
    Part No: 8E0 035 593 A
    Component: SDAR XM 0010
    VCID: 270BFA1336CAF6DFFF7-5066
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    35-00 - -
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 K
    Component: Airbag 8.4EP 1001
    Coding: 0010607
    VCID: 3FDB4273CB6A5E1FA77-5184
    No fault code found.
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 02041
    Shop #: WSC 63351
    VCID: 3E253F77C9605717AC1-4B00
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 P
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01231
    Shop #: WSC 11264
    VCID: 36352757E1509F57741-5160
    WAULT68E95A043287 AUZ6Z0D0235028
    Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
    Part No: 8E0 959 760
    Component: Sitzmemory R2 F 0F04
    Coding: 00002
    Shop #: WSC 63351
    VCID: 71BFD44BC88EF86F613-4B3C
    Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1612
    Coding: 11788
    Shop #: WSC 63351
    VCID: 72BDDB47CDB8C377989-4B00
    Subsystem 1 - Part No: 8E1959801
    Component: Tőrsteuer.FS BRM 0205
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0205
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0205
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0205
    2 Faults Found:
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    00955 - Key 1
    Address 55: Headlight Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63351
    VCID: 04518D9FE73CFDC7BA5-4B3C
    1 Fault Found:
    00776 - Level Control System Sensor; Left Front (G78)
    31-00 - Open or Short to Ground
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 H
    Component: symphony II PM6 0410
    Coding: 01205
    Shop #: WSC 26112
    VCID: 2C01053F2F2CD587125-5066
    End----------(Elapsed Time: 05:15, VBatt start/end: 12.2V/12.1V)-----------
    This is what VCDS gave me. I drove it about an hour total today with no performance problems. I'm still in the process of learning how to check my timing using VCDS, if anyone knows of quick how to for the 3.0 that would be awesome.
    Nov 07 2018
    DMV
    I took the car on a road trip yesterday to go see a race, 4.5 hours each way. Before I left I cleared the codes using a bluetooth OBD-2. After 9 hours of driving and multiple stops for gas and food it didn't throw a CEL once. Maybe the issue resolved itself? The only things I did to prepare for the trip is to double check that the vacuum lines were attached and added a half quart of oil.
