Originally Posted by
Kingzilla17
Jumping in for a questing as you have swapped out the compressor. Ill be swapping this in with a used compressor I just ordered from a fellow member. Question is after you replaced the compressor, what other parts did you replace? I haven't had luck finding a solid DIY for the swap but I would assume its straight forward. My only thing is knowing what other parts I have to swap when I do this. Some say the orifice tube and drier are a must while other dont mention it and say the only requirement is to flush the system before.
The replacement is VERY straightforward, once the front bumper is off. Make sure the system has no refrigerant in it before you start. The compressor was held in by 3 bolts, IIRC, and they are pretty accessible underneath. All the a/c hoses are held in with hex screw and are easy enough to separate off. I used an adjustable on the the low side hardline, where the orifice tube is.
I swapped out all the components that came with the kit, except the o-rings, as they were all fine. So compressor (which I filled with oil before install), the orifice tube, and, lastly the accumulator (to minimize the amount of water absorbed by the desiccant. Be sure to oil the o-rings lightly to assist with install.
Before I did any of that, with the lines opened, I removed the accumulator and orifice tube (which didn't show much of anything in the way debris). I had purchased some a/c line cleaner off Amazon, and used a funnel to pour it into the lines. I let it sit a bit and then blew it out with an air compressor. This got any residual oil, dirt, and debris out of the system. I did it through the lines that connect compressor to condenser, condenser to accumulator, accumulator to orifice tube, and orifice tube to evaporator.
After it was back together, I immediately had a high vacuum pump (from HF) on it (via a/c manifold gauge kit; also from HF), and left it on for about an hour. Got down to -29.x inHg before closing the valves off, taking off the pump, and connecting the cans of refrigerant (cans were weighed beforehand).
Once a can's worth was in (not full), turned on the car, set the a/c to the max cold settings, and emptied most of another can into it until the gauges read correctly.
I don't think the a/c was ever as cold since I had bought the car.
