Results 1 to 14 of 14
    Senior Member Two Rings 522sixth's Avatar
    Sep 16 2018
    Las Vegas, NV
    Denso AC Compressor - How much oil should be in it and the system?
    I searched through about 4 pages of AC Compressor related threads and could not find this info anywhere.
    The manual I have has over 100 pages of AC Systems for different models. Not sure why...
    It's a Denso AC Compressor. It's completely devoid of oil. New Condensor, Rec/Drier and O-Tube. Flushing the Evap right now
    How much PAG-46 Oil should I add to the compressor and the rest of the system components?
    Thanks in advance for any help
    Sep 16 2018
    Las Vegas, NV
    Quote Originally Posted by 522sixth View Post
    So I did some more research and found 130cc for the compressor or 4.4 oz on the denso website. Still haven't found the total system capacity tho.
    Sent from my SM-G955U using Audizine mobile app
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    Sixth,
    Found this on alldataDIY
    Sent from my SM-G960F using Tapatalk
    Sep 16 2018
    Las Vegas, NV
    Quote Originally Posted by DarrenOman View Post
    Sixth,
    Thank you! I did some heavy reading in the manual last night and found 130cc as the system capacity for the entire refrigerant circuit (RS4 but same compressor part number). The info I see from Alldata suggests nearly double the amount. Now I'm really torn on what to do. Just got up to make some coffee and put this back together.
    Nov 03 2014
    2009 Gray A3
    California
    I was just at the Audi parts counter. He looked up the oil which comes in 250ml cans, but couldn't find an actual amount. I mentioned you had seen 130ml and he thought it sounded familiar.
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    Yeah that sounds about right.
    Headers to Milltek non-res catback, LWFW, LWCP, JHM synchros, 034 Mounts & end links, BC Racing Coilovers, Stern adjustable UCAs, RS4 Hotchkis anti-sway, JHM 93 tune and short shifter trio, Brembo 18Z, 19" RS4 reps.
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Even though they are the same compressors the systems are different in regards to capacity of Freon gas for example. I remember from the A/C re-fill machine database at Audi that the A4 and S4 have a 650g Freon capacity and the RS4 only 400g of Freon. So in regards to oil the S4 system most likely takes more than the RS4.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Jul 05 2016
    Ontario, Canada
    At the start of production, the compressor types in the first line of the table were supplied with a refrigerant oil quantity of 180 cu.cm . These compressors can be recognized from the index of the part number (8E0 260 805 with one index or with double index up to "AH"). In Model Year 2004 (as of approx. 01.04), a gradual change was made to other types of compressor with a refrigerant oil quantity of 120 cu.cm or 130 cu.cm . These compressors can be recognized from the index of the part number 8E0 260 805 (with double index as of " AJ") or 4F0 260 805 (and index "E" for vehicles with 8-cyl. engine) Parts List .
    The reason for the different oil quantities in the compressor for an otherwise identical refrigerant circuit is the design of the actual compressor. Attention is to be paid to these oil quantities.. Too much oil in the circuit results in higher pressures and reduced system cooling output; insufficient oil can cause lubrication problems in the compressor.
    The compressor may have been installed at the factory with a rating plate indicating the part number and the quantity of refrigerant oil in the compressor.
    Jul 15 2015
    Rochester NY
    I put in about 130cc, after draining. AC has been working as expected for the past 20k
    Jul 05 2016
    Ontario, Canada
    It's 130... the 120 is for the A4
    Sep 16 2018
    Las Vegas, NV
    Quote Originally Posted by roboto_1337 View Post
    Thank you all very much!
    Did you use 19oz of refrigerant for a complete recharge?
    Jul 05 2016
    Ontario, Canada
    I put the oil in, but had my mechanic add the 134a... it was whatever the bentley prescribed...
    Jul 05 2016
    Ontario, Canada
    Capacity 480 ±50g (16.9 ±1.8 oz) there should also be a placard on the inside of the hood that will tell you how much the system is designed for.
    Sep 16 2018
    Las Vegas, NV
    Capacity480 ±50g (16.9 ±1.8 oz) there should also be a placard on the inside of the hood that will tell you how much the system is designed for.
    Perfect. Thank you!
