Results 1 to 19 of 19
    Active Member Two Rings olehenri's Avatar
    Feb 26 2019
    Norway
    RS Honeycomb grille on A4 B8 Allroad.
    Hi!
    I have a RS Grille that i want to mount on my Allroad, is there any one here that have done that without any mod to the grille?
    Was a little annoyed after when i was told that it probably will not fit my allroad after i got it without cutting some tabs etc..
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    Not going to fit. Going to need some significant modification.
    You'd be the first to try it, let us know how it works out if you do decide to do it.
    Feb 26 2019
    Norway
    Quote Originally Posted by BrewDude View Post
    I will not be the first, many have done it but i was wondering if anyone has made it without cutting some bottom and side tabs on it.
    Mar 13 2009
    04 R32 FT450
    KLAS
    Quote Originally Posted by olehenri View Post
    No one on here has done it.
    Sent from my ONEPLUS 6T McLaren using Tapatalk
    Aug 01 2016
    Pewaukee, WI
    If it was possible to do without modification you would see many others with an RS style grill on an Allroad.
    There is only one person that I know of who has done it (the name escapes me, but he's on here). It required significant modification to make work.
    Daily Driver: 2013 Allroad Premium Plus (OEM+ Build Thread)
    Summer/Fun Car: 2005 Jetta GLI (OEM+ Build Thread)
    Aug 01 2016
    Pewaukee, WI
    @audacious4
    Veteran Member Four Rings AUDacIouS4's Avatar
    Mar 11 2016
    981 Cayman GTS/ 2018 Ford F150 FX4 2.7
    Orange County CA
    You need to cut the bumper cover because the RS grille for an A4/S4 is wider at the top and has a slighlty different angle on the sides. If you take your time it can be done. Caveat: you need to get creative with mounting tabs as the ones on the bumper get cut off when enlarging the opening for the new grille. 3m tape and zip ties are your friend.
    Sent from my SM-N950U using Tapatalk
    Veteran Member Four Rings Danaldson's Avatar
    Aug 28 2014
    Calgary, Canada.
    why would you wanna remove the best looking grille there is!
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by Danaldson View Post
    You mean this one? Oh wait, that's not an Allroad! I always get these two confused?Screenshot_20190417-112234_Chrome.jpeg
    Sent from my SM-N950U using Audizine mobile app
    Aug 28 2014
    Calgary, Canada.
    Quote Originally Posted by AUDacIouS4 View Post
    surprise those get you confused they look completely different.
    Feb 26 2019
    Norway
    Because i like the Honeycomb better than the oem one
    Senior Member Three Rings alhutch's Avatar
    Jun 03 2017
    Portland, OR
    I wonder if the fact he has a pre-facelift B8 Allroad (Norway) will make his path easier?
    2013 Allroad - Volcano Red
    Feb 26 2019
    Norway
    Yes, i have the B8 Allroad, not the facelift.
    I have spoken to a couple guys that have done it and have got some input to where i need to cut (bottom and middle clips)
    May 10 2019
    Uk
    Any tips on what you used for cutting? Im thinking a dremmel might be the best bet. Thought id check with you as youve actually achieved this. And as far as ive found are the only one that has.
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by darth rayvon View Post
    I used a jigsaw with a metal blade(small teeth) for cutting. What I did was applied a strip of painters tape as close to the cut line as possible, this helps make a clean edge by reducing the blades tendency to create burrs. I have a dremel that I used afterward to clean the cut edge with and made a tiny chamfer along the cut to minimize any future chipping. I made a template out of cardboard as best I could to lay over the bumper cover and draw my rough cut line. Its best to try and make your first cutout slightly smaller than the grille insert and work from there. you can always remove material, but you cant put it back if you remove too much.
    Now is a good time to think about your mounting options. On the sides, there will be a 5" long lip that remains to use, I epoxied this area. Other places, along corners, I drilled small 1/4" holes and ran a zip tie from the bumper cover to the grill. This will make more sense when you have everything disassembled in front of you.
    Lots of typing....I think I am going to regret not having made a tutorial for this, I didnt think many would attempt it. Take your time, I used a bunch of woodworking clamps to hold everything together while the epoxy set.
    You can see some zip tie wizardry I made along the sides.
    Along the bottom, I re-used the OEM plate that runs along the entire lenght. Its attached by a few screws and sandwiches the OEM grille to the bumper cover, get creative and repurpose this piece, you'll have to trim it a bit.
    Other than that, I'm not going to lie, its a bit of a PITA, Well worth the time and effort though!20181219_121017.jpeg20190512_122441.jpeg
    May 10 2019
    Uk
    Awesome!! Cheers man. I think ill be documenting as i go. Im guessing not THAT many have tried, but many who want to.
    Jan 01 2013
    Vancouver BC
    did you end up taking photos of your steps?
    Active Member Two Rings Allroad23's Avatar
    Sep 16 2020
    NorCal
    Came out nice
    Awesome explanation my friend. I just bought a 14 Allroad and want to replace it with a different all Black grill. Thought about painting it all black or RS4 grill.
    I am willing to try the mod but wanna make it fits as far as the shape.....cutting the tabs to securing it is the challenge I am willing to tackle.
    Updated:
    I actually painted my stock Allroad grill for a start....I like it much more than the stock chrome look....
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    +1 funny how that search button works
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
