Dear Forum Mates,
The front left power window at my Audi A3 2011 suddenly stopped working and this winter. Probably my wife was pushing the button on the switch when the window was frozen, so the window is stuck in closed position. All other windows and switches work as usual. I took the door card off and tested the motor and the switch. When I hit the button on the switch, something clicks in the control unit (part of the motor assembly), but the motor does not engage. After I took apart the motor assembly and connected the motor directly to the battery, it was running well.
I have no access to VCDS, but maybe you could give me an idea of what could be broken?
I think it is either the switch or that window control unit (microchip).
If it is the control unit, they are not sold separately. Are those interchangeable? Can I put 8P0 959 801 P assembly instead of 8P0 959 801 Q?
Thanks a lot!
