I’ve read on here more than once that there is not only a belief they are the same sway bar, but also online most parts catalogs suggest they are by part number.
I’m here to tell you they in fact are different. The S3 is thicker both visually and by caliper, but additionally they have different part numbers.
Here are the photos:
Part number out of my 2016 A3 Quattro: 5Q0 511 305 BD
Part number out of my 2015 S3: 5Q0 511 305 BE
Diameter differences -
5Q0 511 305 BD: 21mm
5Q0 511 305 BE: 22mm
Considering the dimensions of some aftermarket bars out there, an upgrade to the OEM S3 discard bar for the A3 guys might be a frugal alternative to add some better rear handling. It’s 1mm, sure but that can make some difference. The neuspeed bar I run on my S3 is 25mm and the EMMotion bar from Emmanuele on my A3 is 23.8mm
The upside to the aftermarket bars is you can run different positions and adjust the firmness, along with the diameter overall being thicker. I suppose if you had access to a drill or better, drill press you could drill another set of holes in the oem S3 Bar that were closer to the center to give added firmness.
Just so everyone knows I would not do this myself. The point of the post was to answer some DMs I got around comparisons between the two PFL 8V cars. I got more than once about Rear sways comparing EMD to Neu, etc
