Results 1 to 28 of 28
    Senior Member Three Rings Indskyz's Avatar
    May 31 2016
    Virginia Beach
    3.0T engine differences
    Is there a difference between the 3.0T long blocks of a 2010 A6 auto and a 2011 S4 manual?
    I heard there mY be a difference in the crankshafts, but as I work for an engine manufacturer that would crazy to think they have different long blocks for the same base engine that goes in multiple cars.
    I have to replace my engine is why I'm asking.
    2010 A6 Prestige 3.0T
    GIAC Stage 2+ 93 & 100 Octane files
    AWE 57.55mm / JHM 179mm Dual Pulley (3.110 Ratio)
    PLM 26"x7"x2" additional HX
    Roc Euro Intake
    2.5" Custom Cat-back Exhaust w/Magnoflow Resonated X-Pipe and Mufflers
    Gutted CATs
    ST Coil Overs, H&R Rear Sway Bar
    19"x8.5 Avant Garde M590s Antique Bronze
    Spyder Tail Lights
    Jul 17 2011
    Sin City, USA
    As I am aware, there is no physical differences in the blocks of both motors.
    '09 C6.5 A6
    May 31 2016
    Virginia Beach
    Great to hear. I ended up having metal in my oil and the engine was starting to seize. Had a bad misfire in cylinder number 5. Piston is coming apart I believe as the metal was aluminum.
    I'll know more soon. I've already removed the engine from the S4. Now need to pull the one from my A6. Gonna do timing chains/tensioners and guides while I'm in there along with new Tstat water pump and carbon cleaning of the intake valves.
    I plan on rebuilding my motor after so i have a swing engine.
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    No physical diff at all? but something is different. Maybe it’s just tuned in the s4 as there is a 33 HP difference from the factory.
    I don’t know though
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by DC Dawg View Post
    I don’t know though
    All I said was the block is the same. I do not know about the internals (pistons, crank, cams, etc) but I doubt there is any there as well. The 3.0t was born in the A6 and then adapted to the S4 so it probably just boils down to tuning.
    '09 C6.5 A6
    Veteran Member Three Rings B. Rock's Avatar
    Jul 27 2008
    09 3.0T A6 Avant
    That sounds like a pretty unfortunate failure. German manufacturing efficiency would make me think that the blocks are for sure the same, but I've been wrong before.
    09 A6 Avant 3.0t
    06 E350 4x4 Cummins swapped
    01 WJ rock toy
    Dec 31 2018
    Chevy Chase MD
    I’m sorry that came out wrong. I was not questioning you , I was honestly asking a question based on the HP differences only.
    Jul 17 2011
    Sin City, USA
    No apologies and I didn’t take it in any way negative. We all learn here by asking questions.
    '09 C6.5 A6
    Aug 24 2014
    Newport Beach, CA
    I think the most differences will be with sensors and some wiring differences.
    2024 M3 Comp xDrive
    May 31 2016
    Virginia Beach
    Quote Originally Posted by christianb5s4 View Post
    What sensors? Wiring harness is def different, but I'm using my harness and ECU
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    Jan 24 2010
    Paramus,NJ USA
    Cams are different for sure. But other than that physically they are the same. 2010 a6 will have CCAA engine code with 290 vs a 333 from the s4. As far as I know its software and cams nothing else. I had a 2010 CCAA torn down to nothing just look up my thread if you have any questions.
    Ziddy Autowerks
    May 31 2016
    Virginia Beach
    Quote Originally Posted by EuroxS4 View Post
    Cams are definitely the same. I think the tune alone netted the HP.
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    Jan 24 2010
    Paramus,NJ USA
    My mistake I was using 2015 s5 engine I have for comparison. In that case I would assume tune only.
    Ziddy Autowerks
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    To my knowledge the crank and supercharger are different from each other, but take that with a grain of salt.
    Blocks should be the same. How many miles are you at?
    Sent from my PH-1 using Audizine mobile app
    May 31 2016
    Virginia Beach
    I verified the crank and SC already. They are the same too. I was really comcerned about the crank reluctor wheel.
    I'm at 117,000
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    Senior Member Two Rings alexdell's Avatar
    Jul 29 2011
    Central NJ
    I picked up a used S/C from a 2015 Q5 3.0T donor vehicle. My plan is to get it ported & slap it on my A6 with the DP set up. I know that the superchargers are compatible but I thought I read somewhere that the early gen s/c like the ones in the C6.5 3.0T does not perform as well as the newer s/c like the ones found in the B8.5 or C7's. Can someone confirm or refute this?
    IG: @puzoyAlex
    C6.5 A6 Avant Ibis White | KW V3's| H&R F+R Sways| XLR8 Dual Pulleys| EPL Stage 2 tune| S4Matty Ported SC+TB| APR CPS| JHM Downpipes| SkiGuard Roofbox|
    gone ---> B8.5 S4 Sepang Blue (6MT) |APR Stage 2+ UC|
    Established Member Two Rings NJAUDI1's Avatar
    Sep 24 2006
    07 S4 A/T, 07 RS4 6MT, 11 S4 6MT
    Quote Originally Posted by alexdell View Post
    Did you end up doing this?
    May 31 2016
    Virginia Beach
    Quote Originally Posted by NJAUDI1 View Post
    I know that the Charge Air Coolers inside the S/C are a different revision for the Q5. Maybe more efficient. They may have also opened up some of the ports in the S/C, but overall, it is the same. You can get the CAC's for them.
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    May 31 2016
    Virginia Beach
    On another note. I got the engines out.
    The rear timing cover and oil pan spacer have to be swapped out in order to bolt this engine up to the ZF6 vs the MT.
    The A6 reads the crank signal off a reluctor attached to the flywheel. The S4 uses the reluctor on the crankshaft. The crankshaft supersedes to the same part so I will just read the sensor still off the flywheel when I swap it over.
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    Mar 30 2018
    Sweden
    Very interesting project! Look forward to some further updates if you could - I’m sure it might help a few folks out in future too.
    2007 A6 Allroad 3.2 FSI
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Not go off-topic here, but what is the difference between the gen 1 3.0T motor (2009 - 2017) and the gen 2 3.0T motor (2018 - present, seen in the current Q7)?
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Jul 29 2011
    Central NJ
    Yes. The shop had to source an evap from a b8 or b8.5 but that was it.
    IG: @puzoyAlex
    Veteran Member Three Rings szinkuti's Avatar
    Oct 06 2008
    Allroad Truck aka Uber UTE
    Grand Prairie, Texas
    Quote Originally Posted by Indskyz View Post
    So aside from this you didn’t have any other issues? I’m about to undertake the same job. Found a C6 running cheap for the engine.
    Mar 03 2015
    first, great effort!
    second, I have a question. Can I direct swap from my 3.2 A6 to a newer 3.0T from A6 as well? Would it be a direct swap, or would involve replacing parts/cutting, welding, atc :D
    I would get gearbox as well from newer one.
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    g-can, it would be cheaper to sell your 3.2 a6 and buy a 3.0t a6 most likely. The amount of effort this would take seems not worth the trouble.
    2007 A6 Avant 3.2L Black/Black, 265k miles
    Mar 03 2015
    Quote Originally Posted by estomax View Post
    cheaper? I have a rare Avant top of the line S line, with loads of work done and stuff replaced, and selling it with a loss, and getting something USED again and fixing all that I fixed on this one seems ridicolous.
    This way I would have a solid body well kept body with newer engine that I could service while its out, like new tensioners, gaskets, etc.
    In Canada these avants are very rare, especially model like mine. Like, Ive seen NONE in this trim. I was literally looking over 2 years to grab one.
    I am willing to spend 5k to get this done. I CANT sell mine and ad 5k to buy one with 3.0T, and not to mention they havent sold maybe 20 avants in canada with 3.0T.
    Jan 16 2009
    that is true, i thought about it as i typed the reply but didn't add the asterisk, if you have a rare combo then i could see it cheaper to swap in a 3.0T, but i suspect it is more than just motor and ecu swap, as a lot of the other control modules might balk at the new ecu and tcu also. Granted i am not a vagcom wiz, so hopefully someone that is will chime in.
    Mar 03 2015
    thats why im looking slowly to find a donor car. SO all parts would be there.
    I just found a whole A6 that has busted suspension, but with 3.2 engine that runs fine, guy would sell whole car for $500, like tranny alone even messed up is worth more :D
    so, there is stuff out there, just patience.
