Results 1 to 17 of 17
    Junior Member Two Rings
    Mar 31 2019
    2015 Mercedes GL450
    Alaska
    Anyone tried Travall Dog Guard for the Q5?
    If anyone uses this product, can you share how well it works, and whether the "feet" cause visible wear to the plastic window sill trim?
    https://youtu.be/Lzq0xFg4T1k
    Thanks,
    Kevin
    Sent from my SM-N960U using Audizine mobile app
    Feb 18 2019
    Colorado
    Quote Originally Posted by au_k9 View Post
    Thanks,
    Kevin
    I dont have one in my SQ5 yet, but I had a Travall in my last SUV and it was great, definetly the best one I have found. I did have to use some loctite as the nuts came out a bit on the rods. But no, it was in the car for 5 years and never caused any damage not even a scratch.
    Ill be getting a new one for my SQ5 just not got that far yet.
    '16 SQ5 Lava Grey Pearl - Prestige Black Out - 034 Xbrace,RSB,Endlinks (AWESOME) - APR Open Intake/034 Intake Hose - AWE Exhaust -Stealth Hitch -
    '07 B7 Black Titanium S-Line A4 with 6 speed MT, JHM Test Pipe and Exhaust, KW v1 Coil-overs, JHM Stage 2 tune
    Established Member Two Rings simplesez's Avatar
    Mar 29 2018
    Colorado
    I bought and use one. Got it through Amazon. It is really high quality. No issues with the little feet.
    Mar 29 2019
    So Cal
    No. But I am looking at the OEM Euro dog “cage”
    2014 Audi SQ5
    EPL Stage I ECU | 034 Silicone Intake | AFe Dry Pro Filter w/ Airbox Mod | Snow Screen Removed
    EPL TCU upgrade | 034 Transmission Mount Insert | Supreme 15mm/20mm spacers
    Hoen H11 Fogs | DeAutoLED Interiors & Reverse Lights | OEM Q5 Rubber Floor Mats | Armrest Organizer
    Mar 31 2019
    2015 Mercedes GL450
    Alaska
    Thank you all. I found an Audi branded dog barrier on eBay thanks to another forum member. It was relatively inexpensive, so I decided to go with that. Hopefully I won't regret it.
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    Any have a link to that OEM dog barrier? I'm curious what it looks like as I've been thinking about the Travall one as well. Does this barrier basically prevent the dog from slobbering all over my rear head rests? If so...sign me up. LOL.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Feb 18 2019
    Colorado
    Quote Originally Posted by phillyquattro View Post
    It keeps them in the rear compartment where you would have a plastic liner or whatnot, and they can not get over the seats into the back seat. They are only half height so if you drop the rear seats they and you can still go under the barrier. I loved it in my last car.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I think he's referring to this:
    8R0861691B4PK
    San Francisco, CA
    Quote Originally Posted by PNW Avant View Post
    8R0861691B4PK
    Thanks! Glad I asked as that thing does not look good nor does it appear formidable enough for my dog. It does however look like it would be easy to take in and out of the vehicle so that's a pro for sure.
    2019 GT3 Touring
    IG: brandongray
    Mar 31 2019
    2015 Mercedes GL450
    Alaska
    8R0861691B4PK
    Yes, that's the one I ordered. Thanks for pointing out the eBay ad.
    So far, I haven't been able to find any installation or use videos. Hopefully it's not too fussy to install and remove. I'm not counting on it, but it would be great if it can be used either behind the rear seats or behind the front seats. (Our dogs are large)
    I wouldn't have been willing to pay Audi's $585 retail price for this, but for under $100 shipped for a supposedly new one, it seemed worth it.
    Kevin
    Mar 29 2018
    Colorado
    Installation takes two seconds. There are existing holes in the headliner that it slides into. Then latch the bottom.
    Mar 31 2019
    2015 Mercedes GL450
    Alaska
    Quote Originally Posted by simplesez View Post
    Thank you.
    If I understand correctly, those would be the keyhole shaped holes behind each row of seats.
    Does that mean the barrier can be used in either location?
    It's on its way from Germany, so I don't have it yet, but I can't see where I would secure the bottom to behind the front seats.
    Mar 29 2018
    Colorado
    Looks like it goes to the D rings on the floor. They are shiny and chrome plated, you can't miss them.
    Mar 31 2019
    2015 Mercedes GL450
    Alaska
    Thank you.
    I understand about the tie down rings in the cargo area, but was hoping to also be able to use this between first and second rows, since there seem to be corresponding mounting points in the roof behind the first row (driver and passenger) seats. Maybe there will be something I can connect the bottom straps to under the seats. It wouldn't need to look pretty, and it would only be for occasional use.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    With the seats down, I think there are hooks on the seat back. Then hook to the holes in the roof you mentioned.
    Mar 31 2019
    2015 Mercedes GL450
    Alaska
    Thank you. I'll check that out. I'm really looking forward to trying this thing out when it arrives. My wife it looking forward to not transporting the dog in her GL. 🤪
    I hope to get a fabric or vinyl cargo area liner that will provide more protection than the all weather cargo liner. We had one in a Volvo wagon that covered the seatbacks and the sides of the cargo area. We put our Weathertech mat on top of that. It worked great, but in that car the dog barrier was a Volvo branded metal grate that attached to the roof and folded up out of the way when not needed. I had hoped something like that would have been available for the Q, but apparently not. With this Audi barrier, we may need to cut slits through a fabric liner to allow access to the tie down rings.
    Update: there are tie downs near the top of the second row seat backs. Very cool.
    Senior Member Two Rings jeromium's Avatar
    Apr 19 2020
    2014 Subaru Crosstrek
    I'm considering buying one of those Travall barriers to contain my dog. But, I'd like to do that in conjunction with some sort of cargo liner to keep pet hair out of the carpet. My dog's short hair sticks to carpet like blue. I learned about this Canvasback liner from another thread, and it seems great, except it covers the hooks you have to attach the barrier to. Peeling up the liner in those areas would expose some carpeting and while that's better than nothing, it might appear messy as well. Anyone have another solution to pet-proof their cargo area?
    Also seeing how the barrier attaches to those hooks – it seems they could have come up with a cleaner design that might be less dangerous to pets. I'd probably fashion some sort of rubber or foam protector to go around those J-hooks.
    2017 Q5 3.0T (Moonlight Blue/Black Optic/Chestnut Brown) BBS CI-R Satin Bronze | KW Street Comfort
    2014 Subaru XV Crosstrek Limited (Desert Khaki/Black)
    IG @moonlightbub_q5
