Page 1 of 3 123 LastLast
Results 1 to 40 of 91
    Stage 3 Forum Advertiser Four Rings Info@EuroCode's Avatar
    Dec 24 2008
    Torrance
    Eurocode Tuning | 2.5T EA855 DAZA | Engine Build Megathread | Everything Needed
    As successful as the RS3 and TTRS have been with bolt on performance upgrades and software recalibration, many of our customers are looking for more.
    This thread will serve to provide the community a list of all of the factory part numbers, as well as the factory tools required to disassemble and reassemble the long block for connecting rod, piston and valvetrain upgrades.
    Please feel free to click on any of the photographs to see our competitive pricing for a complete bundle.
    Pictured below is a complete infographic for those who like to visualize what's at stake.
    Here are a few more detailed photos of the hardware required.
    The complete list of part numbers
    07K-103-151-M Front Main Seal, QTY 1
    WHT-008-210 12 Point Socket Head Screw, 6mx16, QTY 9
    N-911-703-01 Socket Head screw, 8mx70, QTY 4
    N-107-655-01 TORX SCREW, QTY 2
    N-108-202-01 Hex Flat head bolt, 8mx25, QTY16
    D-176-501-A1 Silicone adhesive sealant and sealing compound, QTY 2
    N-911-687-01 Hex Bolt, QTY 25
    07K-103-383-AE 2.5L Cylinder Head Gasket, QTY 1
    WHT-007-848-D Cylinder Head Bolts, 10Mx150x120, QTY 12
    N-911-276-02 Screw, QTY 23
    07K-109-345 Gasket, QTY 1
    07K-103-483-C Oil Separator Gasket, QTY 1
    N-912-545-02 Screw, 10Mx1x25, QTY 5
    N-906-650-01 B5-B6 Factory Flywheel to Crank Bolts, QTY 8
    N-910-428-02 Bolt, QTY 1
    06E-103-051-J Seal, QTY 1
    070-109-293-B Seal Ring, QTY 2
    N-900-411-02 Seal, QTY 4
    N-107-104-03 Hex Socket Head Flat Bolt, QTY 15
    N-104-514-05 Bolt, QTY 1
    N-910-697-01 Seal, QTY 3
    WHT-003-463 seal, QTY 1
    N-910-568-01 Engine / transaxle - Engine parts - O-ring, QTY 2
    07K-121-149 Washer Seal, QTY 1
    07K-109-163-A Washer Seal, QTY 1
    N-900-351-03 O-Ring, 21x3mm, QTY 1
    07K-133-379 Intake Plenum Gasket, QTY1
    07K-133-379-G Gasket, QTY1
    07K-145-215-A Vacuum Pump Gasket, QTY1
    N-910-717-01 Cooling Water pump, Water pump Bolt, QTY 6
    The complete list of engine disassembly/assembly tools
    Crankshaft Adapter - T03003A
    Locking Pins - T03006
    Crankshaft Locking Pin - T40069
    Camshaft Lock - T40264
    Camshaft Lock - Adapter -T40264/2A
    Audi oil pan upper to cylinder block plate 2036/1
    Camshaft Spacer - T40191
    Oil Seal Guide Sleeve T03004
    Camshaft adjuster of the exhaust camshaft.-T40297
    Crankshaft Seal Installer Kit - T10122B
    Gauge - Sender Wheel - T10473
    Flywheel Retainer - 3067
    Pry out tool for Crankshaft Seal Replacing Transmission Side -T20143/2
    Piston Ring Pliers VAS211003
    Piston compressor Funnel T40347
    Drive out the seal with the -VW195
    Seal Installer coolant seal installing 3241/4
    Snap-On 24mm open end crowfoot wrench FCOM24A
    Press Piece - 60mm - VW415A
    Injector/Combustion Chamber Seal Tool Set - T10133C
    Tools required to swap OEM valve springs with cylinder head on car
    Valve Keeper Tool Kit VAS5161A
    Valve Keeper Tool Kit - Guide Plate 2.5L TFSI Model:VAS5161A/39
    Cylinder Leakage Tester to pressurize chamber if installing while head is still attached to short block
    EuroCode Tuning, Inc.
    1872 Del Amo Blvd Unit A
    Torrance, CA 90501
    310-294-8108
    Dec 24 2008
    Torrance
    EuroCode/MAHLE TTRS/RS3 TWAS Specific Drop-In Piston/Carillo Rod Combination
    Brought to you by the original #rs3fastmakers, Eurocode is excited to announce the release of our complete drop-in piston/rod combination for the 2.5L evo2 DAZA FL 8V Audi RS3 or 8S TTRS motor.
    Capable of supporting in excess of 1000 horsepower, our upgrade requires no modification to the engine block.
    Included in the combination are Eurocode/Mahle pistons with CP Carrillo connecting rods. Choose from either WMC rod bolts or CARR rod bolts, specifications for each of the components are listed below.
    Eurocode/Mahle Motorsport Drop in Pistons for the FL 8V Audi RS3 or 8S TTRS
    • Proprietary MAHLE skirt coating, designed for use with TWAS cylinder walls, no engine sleeving required
    • 4032 alloy forging, which allows quiet but strong performance for high boost pressures
    • Machined to exact tolerances on purpose-built equipment manufactured by Mahle
    • Coated with a phosphate dry lubricant used to defend against strains caused by initial engine start-up
    • Hard anodized top ring groove to protect against micro-welding, ensuring ring performance in harsh environments
    • Custom H13 material, thick wall wrist pin
    Eurocode/Mahle Motorsport Piston Rings for the FL 8V Audi RS3 or 8S TTRS
    • Coated steel 1.0mm top, 1.2mm Napier 2nd & 2.8mm oil ring set
    • Steel thin ring design which delivers low mass and extended RPM range without loss of ring stability
    • Unequaled strength and fatigue resistance
    CP Carrillo Connecting Rods for the FL 8V Audi RS3 or 8S TTRS
    • Pro H-Beam style
    • Capable up to 1500 HP
    • Balanced to +/- 1 gram
    • Tight tolerances
    • Rigorous quality control
    • 4330 Carrilloloy
    • ISO 9000 certified
    • 144mm length
    • 22mm wrist pin
    • 550 grams for the WMC or 556 grams for the CARR
    • Available with WMC or CARR ⅜” rod bolts
    WMC Rod Bolts
    • High quality, aircraft standard fastener
    • Asymmetrical Threads
    • ⅜” (9.65mm) diameter
    • Supports up to 8,500 RPM and 1250 HP
    CARR Rod Bolts
    • Supports up to 9,000 RPM and 1500 HP
    Eurocode/Mahle Motorsport DAZA 2.5L Pistons for the FL 8V Audi RS3 or 8S TTRS
    CP Carrillo DAZA 2.5L Connecting Rods for the FL 8V Audi RS3 or 8S TTRS
    Torrance, CA 90501
    310-294-8108
    Dec 24 2008
    Torrance
    Ferrea Racing Upgraded Valvetrain Components
    Eurocode Tuning, through our 15+ year partnership with Ferrea Racing, are proud to introduce the ultimate valvetrain upgrade for the 2.5T EA855 DAZA cylinder head.
    Ferrea Super Alloy engine valves represent the highest level of sophistication in valve technology. These valves are designed to handle the extreme heat requirements and punishment of modern high boost, turbocharged engines.
    Please feel free to click on any of the images below for more details and pricing information.
    Valve Specifications
    Intake (10)
    • Head Diameter: 33.9mm
    • Stem Diameter: 5.98mm
    • Overall Length: 104 mm
    • Tip Length: 5mm
    • 20 Degree SuperFlo. Stock Size. Triple Groove.
    Exhaust (10)
    • Head Diameter: 28mm
    • Stem Diameter: 5.97mm
    • Overall Length: 102mm
    • Tip Length: 5mm
    • 24 Degree Flo. Stock size. Triple Groove. Super Alloy
    Ferrea’s Beehive Valve Springs are developed from premium-grade, super-clean PAC alloy materials. These valve springs are progressively coiled with tighter tolerances, heat treated, stress relieved and multistage shot peened for extended life and durability.
    Please feel free to click on any of the images below for more details and pricing.
    Valve Spring Specifications
    • Single Beehive form designed and optimized to reduce valvetrain harmonics, providing greater spring stability, and reduce spring and retainer masses for increased performance and durability (20)
    • Titanium Retainers (20)
    • Intake Seat Locators (10)
    • Exhaust Seat Locators (10)
    For those who are looking for the added benefit of upgraded valve springs, but do not want to remove the cylinder head Eurocode has the perfect solution for you.
    Utilizing just three factory tools (VAS6151A Valve Keeper Tool Kit, VAS5161A/39 Valve Keeper Tool Kit-Guide Plate 2.5L TFSI and a Cylinder Leakage Tester to pressurize the chamber) you can remove the OEM springs and replace with our upgraded Ferrea Valve Spring Kit without removing the cylinder head.
    Torrance, CA 90501
    310-294-8108
    Dec 24 2008
    Torrance
    R74379-9 5CYL NGK Spark Plugs (RS3/TTRS Application)
    Replacement NGK Iridium colder heat range spark plug for high horsepower boosted applications. These are the same plugs that our customers run in their sub 9 second QM setups!
    Torrance, CA 90501
    310-294-8108
    Stage 2 Banner Advertiser Three Rings Brian@Unitronic's Avatar
    Jan 11 2019
    PA
    Thanks for your contribution!
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Stage 2 Banner Advertiser Four Rings Kai@EliteMS's Avatar
    Mar 22 2011
    Lindenhurst NY - Long Island
    Very informative, thanks for posting!
    ELITE MOTORSPORTS
    21 W. SUNRISE HIGHWAY LINDENHURST NY 11757
    www.elitemotorsport.net - www.elitemotorgroupny.com
    P: 631.775.6634
    Follow Us On Facebook
    Follow Us On Instagram #elitemotorsports
    Follow Us On Twitter
    Active Member Three Rings SlowSedans's Avatar
    Oct 27 2018
    R8, RS4, RS3, S4 x 5
    Tahoe
    Great post Kai.
    Established Member Two Rings 5CYL_BTLSHIP's Avatar
    Dec 18 2018
    Austin TX
    Hero
    2018 RS3 - FBO E85, DS1/DoubleD tuned
    Instagram: 5cyl_btlship
    Oct 02 2017
    coolio post, props.
    It would be awesome if you could also include engine part numbers (crank, bearings, etc.) but that's just me being picky ;)
    Senior Member Two Rings RSKYBET's Avatar
    Jan 16 2018
    Midwest
    Fantastic post, well done.
    2017 Audi RS3 1 of 244 (250) and 1 of 33 in Mythos Black
    @surprs3
    Mar 22 2011
    Now start offering a built motor engine program with core swap!
    ELITE MOTORSPORTS
    P: 631.775.6634
    Jan 11 2019
    PA
    thanks for the great parts and even better service David!
    20190410230015_IMG_4055_1 by saxonbrian2, on Flickr
    20190414135711_IMG_4067 by saxonbrian2, on Flickr
    20190415201650_IMG_4070 by saxonbrian2, on Flickr
    20190502113129_IMG_4073 by saxonbrian2, on Flickr
    May 08 2015
    uu
    total cost include install?
    Oct 27 2018
    Tahoe
    Quote Originally Posted by Kai@EliteMS View Post
    Someone really should do this, I would but my shop is too busy as it is.
    May 03 2018
    11th gen Honda Accord Hybrid EX-L
    Jax, FL
    Quote Originally Posted by SlowSedans View Post
    I would not want someone else's engine.
    Who can improve the head further than just valves and springs?
    IROZ? Anyone else?
    Probably why the head was in a box, unless one could not upgrade the head parts and the OP did it for them?
    Oct 02 2017
    Quote Originally Posted by s316 View Post
    on the low end you are looking at $6k I am sure the higher end rods will push this to $7k easy.
    edit to give you an idea...the oem headgasket is $400
    Jul 03 2018
    Charlotte, NC
    Quote Originally Posted by comingabriel View Post
    IROZ? Anyone else?
    Except in the case of cars like the STi or RX-7/RX-8, where replacing the block/case halves/whatever is the cheaper/safer/more reliable option, this is generally how it works when you buy a built short block. Not sure why you wouldn't want someone else's engine - the tuner who built the engine would have done at least the bare minimum to make sure that the block is within spec before assembling. It would be identical to having them build your own.
    I'm also curious on the head... Is the head just designed that well? Or is this just the 'easy' path, and the head flows 'well enough'? Curious what the IMS1000 cars are running for head work.
    Jun 26 2018
    Socal
    Race developments in the U.K. did head porting for iroz
    Oct 27 2018
    Tahoe
    The stock valve springs are fine btw.
    May 03 2018
    Jax, FL
    Quote Originally Posted by Bowser330 View Post
    This is more closer to what I was looking for.
    Jan 11 2019
    PA
    Fine to what? Based upon what testing?
    May 03 2018
    Jax, FL
    Can OEM handle 8500rpm? Just asking...
    Actually, can OP's posted head products run fine at 8500rpm?
    Oct 27 2018
    Tahoe
    Quote Originally Posted by Brian@Unitronic View Post
    They are actually stiffer than what some are replacing them with. They are fine for 30psi and 8500 in my own testing. Additionally, look at the other engines that share them and the head design which rev higher. Our cars came with a low stock rev limit because of the turbo more than anything.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Excellent presentation. I love the pictures.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Apr 04 2012
    2019 RS3 Ara Blu
    I'm still curious what the dyno graph looks like on a downpipe intake and ic with tune car spinning to 8k. I know the stock turbo would fall-off but I would like to see a graph. If it can be plotted with the RPM drop per shift I think it would be interesting to see if that high has more or less meet between gear changes.
    Oct 27 2018
    Tahoe
    It falls significantly. It's best to shift lower on the stock turbo.
    May 03 2018
    Jax, FL
    I think the BT IROZ guys are running more than 30psi?
    Oct 27 2018
    Tahoe
    They are but that is irrelevant. The point is that the springs are up to the task. The ease in reciprocal movement is from the lighter retainers.
    With more boost the valve gets harder to close, so you need more spring. However as I said before, some aftermarket springs being sold for this application are softer than stock.
    Valves are another factor as are keepers but my point stands, the factory springs are good.
    Jan 11 2019
    PA
    What aftermarket valve springs are softer than stock?
    Oct 27 2018
    Tahoe
    I'm not going to say only because it's two different popular offerings (maybe more I dont have data on) from more than two popular resellers. I'm not here to hurt sales of viable products.
    Oct 02 2017
    ferrea and supertech are the only two spring manufacturers I know of.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Looks like Eurocode is offering a CNC porting based upon IG
    https://www.instagram.com/p/BxnoKdqhK40/
    Stage 3 Forum Advertiser Four Rings David@EuroCode's Avatar
    May 26 2004
    They will run at 8500rpm but not without issues, having taken several heads apart that ran at or above 8000rpm with 30+psi, we can say with confidence that we would not recommend doing so. The Ferrea valve springs we offer are designed to function for use at 8000-9500rpm, you can go higher but this is the recommend.
    "If everything seems under control, you're just not going fast enough."
    - Mario Andretti
    May 26 2004
    The stock RS3 springs are NOT stiffer than the Ferrea springs we offer, I have listed information below on the rating for stock vs. Ferrea. We do not recommend running the oem valves at or above 8000rpm. In fact, if you plan on running the car at or above 8000rpm, we also recommend upgrading to the Ferrea replacement valves. Their triple grove keeper area has a different dimension than stock to eliminate the valves from having play when the springs are compressed.
    Stock 75 lbs seat / 155 lbs open
    Ferrea 85 lbs seat / 185 lbs open
    Note: The correct spring pressure is measured with the Ferrea seat locator at install heights for this application.
    The part number for the OEM valves springs are listed below, what OE applications have you found them in that rev at 8000rpm and above?
    Stock RS3/TTRS valve spring part numbers
    Exhaust
    06F-109-623-G
    Intake
    06F-109-623-B
    - Mario Andretti
    May 26 2004
    To clarify, we are not one of the two "popular" re-sellers that are offering "softer" than stock springs. So feel free to name the "two" different popular offerings, no need to name the more than two "popular" re-sellers who sell those softer springs. I'm pretty sure they don't even know they are selling them, the "popular" re-sellers that is. So kindly share with the community this very important information, people are being taken for a ride and they deserve to know if what you are saying is accurate, thanks!
    RS3 Valve spring rate vs. Ferrea info
    - Mario Andretti
    Oct 27 2018
    Tahoe
    Never said you were Serabi.
    My posts are regularly edited or deleted, since 2004 because I tell consumers the truth about modifications or components from within the industry.
    Wastegate Rattle Fix info
    2017 rs3 nardo stage 2+
    2009 r8 phantom black & boosted
    2007 rs4 sprint blue snow car
    2000 s4 single turbo scary fast
    2001 s4 stage 3 street beater
    Oct 02 2017
    so, who are the softer spring manufacturers?
    Jun 04 2019
    jb/malaysia
    Hi david if I wanna rebuild my rs3 engine (daza) which mean the pistons n rods u provided is plug n play without any modification right ? What is the cost ? Can u pm me for the pricing ?
    May 01 2018
    Virginia
    Quote Originally Posted by Patrick_l52 View Post
    The kit is around $3500 for the drop in pistons/rods/rebuild kit. Motor build is usually $3600-4500 labor.
    Nice kit they sell! I am about to purchase mine as soon as they call back :)
    2014 SQ5 DP/104 Octane 11.001 @124.55
    2019 TTE RS3 FBO
    2021 GLC63 S AMG
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Quote Originally Posted by Eat.Sleep.Race View Post
    I haven’t had any trouble getting them on the phone, just call in during business hours and hit technical support and there’s a good chance Dave will pick up. We’ve spoken several times over the past few weeks and he’s been extremely helpful and informative. I just recently received my pistons and rods and am looking to probably do my build in July. EuroCharged Canada just tuned a TTRS with their sport pistons recently and it put down 980whp. Can’t wait
