previously, i had the following:
JHM TP, stock downpipes, AWE Touring: sounded pretty badass, but it was loud and raspy
i then added the MF 11385. sounded great for a few weeks then i blew out the muffler.
Summit racing was great and replaced the part under warranty with no BS. tapping both the new and old 11385 it was clear one was more "hollow" than the other
i replaced that with a SOLO Performance STL 51. this was not an X pipe, but it sounded pretty damn good, but had a few rattles inside the muffler and was still too loud.
i live in a condo and had to put the garage door down when i started the car then open it after cold start in the mornings
with both the MF11385 and the Solo STL51, i dealt with significant vibration from the downpipes (or so i assume). i had 2 sets of mopar dampers on each downpipe and didn't do enough for it to go away
i then ordered the ECS resonated system in hopes of having a slightly-louder-than-stock tone with the valves closed, and something fairly aggressive with the valves open. well, it was certainly quiet with the valves closed, but it sounded terrible and tinny... a Camry sounds better (4cyl even). with the valves open it was loud AF. so loud, that when i first floored it leaving my friends place after install, i only made it to about 4500 rpms before letting off. needless to say i was really disappointed.
with that being said, i wasn't overly surprised at the volume and had already purchased an additional ECS resonator (the same one located towards the back) and the non res section purely for the piping. James at ECS alluded to the fact that they could be combined to fit the system in place of the x pipe (I bought a cat with an offset center to see if it would fit, but it’s too long)
so, after some cutting, i was able to get the resonator in (see last pic)
sound with the valves closed: much better than before in terms of tone, volume was stock like, but the drone is significant
valves open: barely less "racecar" than before. drones wicked bad. huge bummer
also, i'm not sure if i already blew out that muffler too, but my exhaust tips and rear end were covered in packing material
in 90% of my setups (catless) the car has a very significant vibration around 2500 to 3000 RPMS. yes, i have read the "vibration" thread and have checked the hangers and added the mopar dampers. i have even moved them around, but it is far too significant of a vibration to do much. also, i have read the "header wrap" thread and even bought a couple of rolls to try, but the drone, rasp and vibration is far, far too significant for that to work. i'm sure it helps a little but i simply don't believe it will do enough. plus, its too loud anyway
so, now what? i'm probably going back to stage 2 and installing cats again. i'm open to suggestions and thoughts on the vibrations/NVH (i do need to get my front DS wheel bearing/CV boot checked out, again..) but at this point i'm tired of the trial and error. plus, i'd like to be able to trade in my car if i find something else i'd like to buy and i'm sure being catless is a deal breaker, if they find out
i'd like to wrap up by saying that i don’t really have any complaints with the ECS system. the clamps aren't great and a few of the pipes needed some muscling to fit together, but i love the idea of a valved system and its a great price point. fitment is also great, and there is plenty of clearance in all areas to avoid rubbing/banging again the underbody.
customer service was great as well. i bought the system through S4_dad on IG (through Custom Auto Dreams i believe) and they were fantastic to deal with. one of the tips was marred when i opened up the box. they took care of it ASAP and overnighted a new one to be without issue. i damaged a rear hanger in another incident (don't ask) and they overnighted me one once i sent payment since i had a tight timeline
i have a few crappy videos i will post, but no flybys. maybe next week if enough people are interested.
