Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 361 to 400 of 476
  1. #361
    Mar 18 2021
    Chicago
    Another rookie question... Does cutting the signal wire cause any codes or CEL?
  2. #362
    Apr 08 2014
    Quote Originally Posted by Sendit_S4 View Post
    Another rookie questions... Does cutting the signal wire cause any codes or CEL?
    Code=Yes
    CEL=No
    I’ve tuned my own car and removed the code, which is P190C.
  3. #363
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    Quote Originally Posted by irish07 View Post
    Code=Yes
    CEL=No
    This. Saw it yesterday... It shows up under the Engine component in VCDS. This is what they call a "Soft Code" because it shows up but doesn't trigger a light on the dash.
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
  4. #364
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Yes. See other post above this. I installed a switch for that middle wire. I leave the circuit closed (signal working) except when making Dragy runs or multiple back to back full throttle pulls. Then, I flip the switch to "off" which lets the pump run all the time the engine is running - 100% duty cycle. I'm still on the OEM CWA 50, so I'm not sure running the pump 100% makes much difference.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
  5. #365
    Mar 13 2013
    Chicago Western burbs, Il
    Quote Originally Posted by ProSkier View Post
    Was the CWA50 PWM controlled for your test or was it running all the time? And how about for the CWA100-3? Thank you for sharing your data.
    Answering an old question about my test results comparing CWA50 to CWA100-3 both pumps were PWM controlled. I haven't tested 100% vs PWM as I've been happy with IAT's in current config. Would still like to figure out how ti get rid of soft code, a little confusing as PWM works.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
  6. #366
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Quote Originally Posted by MSq5 View Post
    I've done the exact same thing with the switch and despite reading previous posts here stating Unitronic already runs at 100%, I see a big difference running the pump at 100%... stays cooler longer, able to be within 10 to 15 degrees of ambient...
    Strange...
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
  7. #367
    May 27 2019
    London, England
    So after 2 years of fitting the CWA100 to my 2009 B8, I now have the P190C soft code come up for no reason.
    Any idea on how I can stop this happening? I used the Tecomotive kit
    2009 S4 B8 Avant Phantom Black | EPL Stage 2 DP & TCU | Eventuri Intake | MercRacing Cooler divorced with CWA 100.3 | Forge SC pulley & JHM 187mm Crank PR 3.26 | Full Milltek exhuast with DPs & X pipe | Driving Passion rear diffuser, hydro dipped Ferrari Carbon | Yellowspeed 356mm 2 piece Front BBK | 19" Le mans wheels| Fully dechromed & tinted | CR 15 strut brace | All lights upgraded by EM Tuning
  8. #368
    Jan 04 2021
    BMW x3 28i/ CBR F4i/ YZ125
    CALI
    Pierburg experts please help:
    I went to the junkyard and pulled a pump off an early 2010-2011? A6.
    The pump has 4F0 965 567 on it. Also, 7.01360.11.0
    From research CWA-100 has part # 4H0 965 567 So I am wondering if this may be an early revision??
    Can you tell me if this pump is anyway better than the current CWA50 on my s4?
    Thank you
  9. #369
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    Quote Originally Posted by BrokeBichB8 View Post
    Thank you
    Here is a good resource for information on those pumps.
    https://www.tecomotive.com/en/products/CWA100.html
    Sent from my SM-N986U using Audizine Forum mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
  10. #370
    Jan 04 2021
    CALI
    Quote Originally Posted by RoofRails View Post
    Bro thank you for kindness but I have studied that page till my eyes bled. I am wondering if there is any way A6 pumps were designed with more flow/power for bigger vehicle? I thought possible when I couldnt find the part number. I was just hoping if there was any way to decipher the power of the pump from part #. When I research the part number I cannot find a replacement and I wonder why. Thanks
  11. #371
    Apr 29 2018
    I see. I believe the answer you are looking for is No... The CWA - 50 pump you grabbed off of a A6 is no different then the one on a S4 as far as flow is concerned.
  12. #372
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    We bought this for my buddys SQ5 and AITs are horrible way higher than stock, I feel like the pumps not running at all. I though I read here somewhere that the harness may need to repined on some cars? But can’t find it :/
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
  13. #373
    Apr 29 2018
    Quote Originally Posted by ANMS4 View Post
    The pin out is always the same but double check it because someone could have screwed up the harness that came with it. If it's pinned correctly then remove the signal wire and the pump should go into emergency (100%) mode.
  14. #374
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    The CWA100 upgraded supercharge coolant pump thread...everything CWA100...
    Here is the harness from the CWA100-3 that I purchased from Tecomotive. The flat end of the large connector that connects to the pump itself is towards the top of all of these pictures. The top (purple, signal) and middle (red, +12V power) wires cross from one end to the other.
  15. #375
    Dec 18 2012
    Framingham MA
    ^^ thanx guys
  16. #376
    Sep 16 2020
    West Michigan
    Question: how does one test the pump using VCDS? I have a feeling that my original CWA50 is not functioning correctly. Shouldn't it make some noise?
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
  17. #377
    Jan 11 2018
    Florida
    Quote Originally Posted by sepheroth86 View Post
    Not sure about VCDS other than looking for sky high IATs on a datalog. It should but it might not be loud enough for old ears. You should be able to at least feel a vibration when you touch it and lock/unlock the car or open a door.
  18. #378
    Jul 31 2016
    PA
    Under engine, output tests, there is one for the charge cooler pump. It will basically just run the pump at a few different speeds and you can hear it respond and watch the PWM signal change at the same time if you monitor as well.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
  19. #379
    Veteran Member Three Rings englishbay's Avatar
    Sep 30 2009
    Vancouver, Canada
    I ordered a pump from mercracing it is DOA. Anyone else have problems with the pump not getting a signal? The Audi cable that mercracing provides was test to be ok, the pump just wouldn't run. Sent a request for an RMA from mercracing but haven't heard back yet.
    B8.5 S4 DSG | APR UC/TCU | APR Intercooler System | APR Intake | Bilstein PSS10s | Ethanol Sensor
  20. #380
    Jul 31 2016
    PA
    Quote Originally Posted by englishbay View Post
    Did you try running it without the signal wire? And verify the wiring was pinned correctly?
  21. #381
    Apr 29 2018
    Make 100% certain the pin out on the connectors are correct. Scroll back into this thread for pictures of what they should be. When I recieved mine the positive and ground wires were incorrectly pinned and the pump wouldn't run. Once we swapped them out it was golden. After that definitely de-pin the signal wire. Some vehicles work with the signal wire hooked up and some don't. It's worth a try before sending it back.
  22. #382
    Sep 30 2009
    Vancouver, Canada
    Quote Originally Posted by djn876 View Post
    Thanks I will try that, the mechanic did check the harness, but we will double check running without the signal wire
  23. #383
    Jan 04 2021
    CALI
    Just bought the proper plug off amazon and repinned the ends of the wires for my CWA 100. Below is a picture of my stock CWA50 plug with wires shown. I kinda had a hard time making sure the pinout was correct prior to cutting. But from documents, middle wire (blue/yellow) is signal and was left disconnected Brown I assumed to be ground per usual. Yellow/Red was hot 12v. I am doing PCV, water pump, thermostat at this time so gonna be changing coolant ratio as well and hoping for SOME ICY IATS lol
  24. #384
    Mar 31 2008
    eS-4
    CAL*SO
    im running 98% water and a splash of water wetter for color. on the freeway cruising i can get it down to 17* above ambient. still using the cwa50 @100% duty
  25. #385
    Sep 30 2009
    Vancouver, Canada
    The mechanic got the pump working by cutting the signal wire. So glad that I don't have to return it. Now I have a fault code tho for the signal wire. Anyone been able to use VDS or some other tool to get rid of the fault? Luckily its not a check engine light.
  26. #386
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    It's a soft code that will always be there, but won't trigger a cel
    Sent from my Llama using Tapatalk
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
  27. #387
    Sep 30 2009
    Vancouver, Canada
    Quote Originally Posted by AudiC7Owners View Post
    Great thanks
  28. #388
    Jul 31 2016
    PA
    Yup, code ain't going anywhere. If it makes you feel better, mine will run and vary speed based on the PWM signal, but I still get the soft code.
  29. #389
    Junior Member One Ring
    Jun 22 2019
    CA
    Hey guys, ended up snagging a used cwa100-2 for a great price.
    Where can i get a plug&play harness from in the US? Hoping they're in stock. Thanks!
  30. #390
    Nov 21 2019
    Antioch Ca
    So the cwa100-2 is 4 pin to the audio 3 pin. So one of the ground pins on the pump isn't used or do we double the ground coming from the Audi harness?
  31. #391
    Jan 04 2021
    CALI
    Quote Originally Posted by low612 View Post
    I read that one of the pins is like a return communication line?? someone might be able to explain it better, but guys on the mustang forum just run it wide open two wire.
  32. #392
    Nov 21 2019
    Antioch Ca
    Yeah , I'm guessing just use ground ,pwm,and 12v power from cat and going to pump. Which would eliminate using the signal pin on pump.
  33. #393
    Nov 27 2017
    Los Angeles, CA
    Hey guys very interesting thread!
    Quick question... I am buying a CWA150 with connector kit to install on my dual pulley 2016 Q5 3.0T w/merc quad pass hx.
    I am confused about what is needed to make this work. Can I install it essentially plug and play where the original pump is after verifying the pins (and possibly cutting the signal wire if it doesn't work on my vehicle)? As a single pump I shouldn't need any additional brackets or hose connections? Also I am reading that the current draw is 15a and the original wiring is fused for 15a so I am wondering if I can get away without a relay if I use the OEM PWM signal. Is there some other method to reduce the duty cycle or current draw slightly just in case?
    2016 Q5 3.0T | Shorties Racing Ported Blower | Merc Racing Quad Pass HX | Fluidampr 183 | CTS Turbo 57 | EPL DP and TCU Tunes | R8 coil packs | Adaptive Damping Suspension with KW H.A.S. | Comfort Pkg w/Perforated Milano Ventilated Leather | Sport Int Package | B&O | ECS diffuser w/4" quad tips | Whispbars | Yakima HighRoad | TSW Chrono 21x10.5 et32 with 3mm/12mm H&R spacers | 295/35/21 DWS06 | Custom dual x-pipe exhaust with IE DPs, E350 V10 CARB cats, Magnaflow 11386, Vibrant UQs, S5 mufflers
  34. #394
    Established Member Two Rings michael.kaemmer's Avatar
    Apr 26 2020
    Germany
    Beware of pressure rates from CWA150!
    High pressure no more volume!
    Different connector. ECU will most probably not control pump via PWM correctly as 150 needs signal to slower speed or to start. So not sure. Try using without PWM signal so pump will run in emergency mode.
    DS1 stage 2 on direct waste gate control plus TCU tune, Inter Cooler Spacer 1", upgraded throttle body 49mm bores, SRM short inlet pipe plus RS airbox, Sport RS exhaust, Race sparks and RS break rotors
    DS1 stage 2 with DWGC, TCU tune, CWA 150 Inter Cooler pump, upgrade TS throttle body, SRM short intakes plus RS air box, RS sport exhaust, Race sparks and RS break rotors
  35. #395
    Apr 26 2020
    Germany
    Quote Originally Posted by stapan View Post
    Look at Tecomotive.de to find control unit to run this pump with lower amps.
  36. #396
    Nov 27 2017
    Los Angeles, CA
    Quote Originally Posted by michael.kaemmer View Post
    I thought its ok with Merc Quad Pass? Am I making a mistake by trying to use it? Please help me understand as I am a newbie when it comes to this subject.
  37. #397
    Nov 29 2018
    Edmonton
    Just run it without the PWM and be happy.
    Sent from my GM1917 using Audizine Forum mobile app
  38. #398
    Junior Member Two Rings
    Sep 16 2021
    Niu N1S E-Scooter for fun-issues :D
    Frankfurt/Hessen/Germany
    Am I getting it right that you've just repinned the original plug? Does it fit the connector on the cwa100-3 ?
    '09 B8 S4 Avant​ - Phantom Black (CGWC) | ARtechnics Stage 2 dual pulley (3.100) | ARtechnics DSG Tune | 200cell ISP cats | APR Airbox (closed) | APR Intake | APR HX |ECS Transmission Mount | JHM Diff. inserts | ECS Fuel Relocation
    next to come: KW v3 coilovers
  39. #399
    Apr 08 2014
    Quote Originally Posted by acid88 View Post
    No, cwa50 pins/connector are getting cut off. New leads get soldered or crimped and then inserted into the cwa100 connector.
  40. #400
    Senior Member Three Rings Slvrbul8's Avatar
    Apr 14 2021
    300zxTT and E46 BMW 330i
    Roanoke, Va
    Is this the plug and play kit or is there still possible wire cutting that needs to happen?
    https://tecomotive.com/store/en/bund...-3-adapter-kit
