A/S6 https://europrice.us/taillight-packa...lift-led-sedan
A/S/RS7 https://europrice.us/taillight-packa...t-facelift-led
We have a few threads on the tail lights.
https://www.audizine.com/forum/showt...light-Packages
https://www.audizine.com/forum/showt...ght-Conversion
Tail light color on the 6 is noticeably different, light bars updated and on the 6 a different shape, the "overbite" on the pre-facelift rear is removed so there is a gap if you try to run facelift tails. A few have converted their 6 rears to full facelift, I know Madyspop did it successfully. 7 tail light shapes didnt change with facelift, just color and light bar design. Having installed both the 6 and 7 european tails the 6 is easier, less pins to deal with.
I had the OEM European 6 lights, expensive but the amber in the NA lights just sucked with with turning off the bulb. https://europrice.us/headlights-a6-s...t-facelift-led
Now the hard stuff. OEM Matrix headlights have been incredibly elusive. It's a totally different animal from what I can tell with the tail lights. If you have looked at enough lights you can tell the difference. I've been asking Alex about these since 2016, just the E-codes were expensive, the Matrix stuff is up a level.
A/S/RS6 E-Codes as many refer to them, no amber reflector/light like North American cars.
A/S/RS6 Matrix lights. The horizontal bar on the side marker area is the give away.
A/S/RS7 LED lights, fortunately for 7 owners they don't have to deal with an amber reflector/light in their housings.
A/S/RS7 Matrix lights, the design in the bezel is the give away. The LED lights look more aggressive.
Matrix headlights require windshield camera to be part of the specs, the tech was/is still pretty advanced with looking for signs and other things that would glare/reflect on the driver and of course like High Beam assist not blind on coming traffic.
Recently started nagging Alex about the Matrix lights for the 7. My email thread with him is titled - I know you're going to say no. Hahahha, I was perusing European sites and saw Kufatec items for the Matrix lights.
7 https://www.kufatec.com/de/alle-prod...di-a7-4g-41575
6 https://www.kufatec.com/de/alle-prod...di-a6-4g-41535
Description on the 6 says not for US cars, but the 7 does not have that same line. After trying to get the lights from Kufatec they removed the ability to put these lights in their cart. They clearly do not want to sell them, only install them at their shop. The elusive lights continue to be a strange mystery.
Alex and I didn't quit. He got a set of lights.
I found a harness for retrofitting Matrix lights, was hoping for some coding and instructions that would make it all come together. The harness does connect to the lights correctly but where they tell you to connect the far end does nothing. Their coding changes didn't make the lights work either. https://www.k-electronic-shop.de/AUD...Kabelsatz.html
My coding before theirs, not putting their stuff out there cause it didn't work for me anyhow.
Testing outside of the car, Alex didn't want me to dismantle and end up reversing all the work if we failed.
After Alex dug in, we have light!
Tearing into the car.
Happy with the outcome. Have matching Dynamic sweep all round now and something I've wanted to try to get done for a while. Here's a walk around, sorry for shaky cam I'm not a videographer. These are definitely not plug and play if you get your hands on some.
