Results 1 to 27 of 27
    Junior Member Two Rings
    Feb 22 2019
    PNW
    Yes another Q5 suspension question.
    I’ve searched online, the forums and facebook pages. But still not set on what the best suspension setup for the Q5 is (I know a lot is personal preference)
    So here is where I’m coming from.... I had a honda element on BC extreme drop coilovers. Rode fairly well but a bit harsh at times.
    Recently bought the Q5 and WOW suspension on german cars is another level. My goal is is to firm the Q5 up and lower it without taking away from the initial suplleness. Here’s what I’m looking at as options... oh and I have the “drive select” so I’ll have to do the module bypasses or deletes.
    1.H&R adjustable height springs on Bilstein struts (SQ5). I would look at KW HAS but it looks like they don’t work on Bilstein.
    https://www.ecstuning.com/b-bilstein...8t0413031afkt/
    https://www.ecstuning.com/b-h-and-r-...gs/23001-1~hr/
    2. Or Koni shocks/struts with adjustable springs.
    https://www.ecstuning.com/b-koni-par...01279sport~ko/
    3. Full coilovers KW V1 (I’d look at higher ended V2 but having to pull the coilovers to adjust damping seems to make it pointless)
    https://www.ecstuning.com/b-kw-suspe...it/10210103kt/
    4. Full coilovers KW street comfort
    https://www.ecstuning.com/b-kw-suspe...it/18010090kt/
    5. Also considered saving up a little more and going with the full electronic adjustable KW coilver setup because it’s nice to have the adjustments for daily driving. But reading mixed reviews on them.
    https://www.kwsuspensions.net/produc...8/DDC/39010041
    6. Whatever other options you guys recommend.
    Dec 14 2018
    2014 MINI
    Gallatin TN
    Quote Originally Posted by Pnwski View Post
    With all those you lose your ride select , with KW HAS you keep it. Ride comfort will depend on how low you go. I am around 29" ftg and its a smidge bouncy but still a very good ride. 1/2 " higher it rode better , 1" higher rode better than stock but I hate the gap so willing to give up some for the look :)
    2014 Q5 Premium Plus TDI with extended MMI NAV / B&O Audio
    MODS: H&R Street Performance coilovers , TSW Bathurst 20x10 et25 wheels
    , 295/40/20 Toyo Proxes STIII tires and APR tuned
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    I’m running Koni adjustables with H&R Sport springs on my 2016 SQ5.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    If you can find and afford them, the Bilstein B16 is hard to beat. They have a wide range of ride height, easily adjustable dampening, and a better-than-stock ride.
    Feb 22 2019
    PNW
    Quote Originally Posted by bigjamesdean View Post
    Would be great if those would work. But unfortunately in my experience, any kind of lowering spring on an oem strut/shock ends up either killing the strut/shock very early or the ride quality is compromised, or worse.... both. Of course if the oem adjustable suspension wasn't so expensive it would definitely be worth the gamble. Which seams from even what you said, it is slightly bouncy when low. Ideally I'd like to have a planted ride with no bounce. I wish you lived close so I could check it out thought. I'd really like it to work. Ha.
    Feb 22 2019
    PNW
    Quote Originally Posted by bajan01 View Post
    SOOOO nice. I think that's where or close to where I want to end up height wise. But I'd like the option to go slightly lower, not that I'd keep it there. But have the option, because everything looks different in pics. But it sure does look like that could be it.
    Is the adjustment on the Koni's reachable while on the Q? Or is it remove to adjust? I know in the past Koni has been one of the top notch shocks/struts. Perfect world I'd probably do KW HAS springs if they'd work. But from the little parts I've read it seems they only work on OEM struts.
    Feb 22 2019
    PNW
    Quote Originally Posted by SQive View Post
    Do you know a part number? I've struggled to actually find what B16 (PSS10) fits the Q5. Finding some people talking about using them from other vehicles.
    Jan 11 2018
    Florida
    Remove to adjust.
    Established Member Two Rings Trurite's Avatar
    May 25 2012
    87%20RX-7%20Turbo%20II
    Round%20Rock%2C%20TX
    I went with BC Racing extreme lows and love the ride. Sitting at 28.5 fender to ground on stock wheels still, and will go lower when wheels get put on. Adjustable dampning without removing. Have dampening set perfect for my ride taste. Plus value for money at 1k for the set. Plenty money left over for adjustable upper arms.
    Sent from my SM-G955U using Tapatalk
    2015 Q5 3.0T EPL Stage 2 Single Pulley (RIP)
    2016 Q5 3.0T EPL Stage 2 Dual Pulley/ZF TCU Tune, Air Lift Performance with Accuair CVT and Management, Red-Star Test Pipes, Magnaflow Catback
    Feb 22 2019
    PNW
    Remove to adjust.
    What's you're fender to ground measurement?
    Jan 11 2018
    Florida
    76.28cm front, 77.47cm rear
    255/45/R20 tires
    Feb 22 2019
    PNW
    Quote Originally Posted by Trurite View Post
    HMMMMM interesting... Any rub or harsh bottoming? Did you lower it with shock body or spring perch? They say not to adjust ride height via springs, it's only for preload. but I know guys that have done it that way. I had these on my honda element... they didn't seem progressive enough and I adjusted everything how they recommended, even had damping adjusted to full firmness. From the pics it doesn't look like you went with the upgraded swift springs. I'm pretty curious on this setup... but also hesitant because how it felt on my other car.
    May 25 2012
    I did not go with swift because I was not sure how I would like the spring rates. Went with bc racing choice to try. Was willing to purchase different springs if needed. I think they are 14k up front and 8k in rear. Will have to look it up. As for lowering i did it from the perch. Still sitting at 28.5 with about another 2.5 to 3 inches left on the perch. No need to adjust from the spring. Which yes affect pre load. Dampening is set to 22 clicks up front and 15 clicks in rear. Nice and firm, no bounce. Will change with wheels and tires but can always adjust more or change spring rates. I also plan to tow my RX7 next spring so I will be replacing the rear springs with bags to compensate.
    Aug 26 2018
    Boston MA
    #48-221832 is the part number for the PSS10's. They don't make a kit for the S/Q5, but the C7 kit fits B8/8.5 and is what a handful of guys on this forum are running. But beware... Bilstein changes their ETAs faster than Mops changes out his wheels.
    Speaking of Mops, you should consider ordering them through him if you decide to go with the Bilsteins. Maybe if we turn this into a group buy, Bilstein will get off their butts and start shipping our coilovers.
    Apr 26 2014
    DFW
    I got them from Mops, so shoot him a PM and ask.
    255/45/R20 tires
    Dude, did you use a micrometer?
    The Bilsteins are adjustable via reach-around, literally.
    Those BC's sound like a deal.
    Let us know how they work out.
    Dec 14 2018
    2014 MINI
    Gallatin TN
    How can you have all that wheel gap and be a inch lower than I am ???
    May 25 2012
    Called super stock gap!!! Its terrible... my soul hurts everytime I go to work and Im on stock. Soon... very soon.
    Dec 14 2018
    2014 MINI
    Gallatin TN
    ya but tire diameter should not change with different wheels etc so gap wont change :)
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    I think it's just an optical illusion created by the big difference in offset, and you're seeing the gap more diagonally.
    '23 S4 Prestige - Chronos Grey
    '24 Q4 55 e-tron Glacier White
    '24 Q5e District Green
    TOTALLED: '21 Q5 P+ - Glacier White (wife's)
    SOLD: 21 S4 - Mythos Black
    SOLD: '19 SQ5 - Quantum Gray
    TOTALED: 21 SQ5 - Ultra Blue
    SOLD: '19 e-tron - Typhoon Gray
    SOLD: '16 SQ5 - Sepang Blue w/Black Optics
    IG: @gravysq5
    Dec 14 2018
    2014 MINI
    Gallatin TN
    Quote Originally Posted by buggravy View Post
    That makes sense but still think his measurement is off , for me to get to his height I would have to tuck a 1/2” of tire
    May 25 2012
    @bigjames you were right. Went out and remeasured. At 29 not 28.5.
    Feb 22 2019
    PNW
    So doing more reading on the H&R springs. I’m starting to wonder if these will also only work on stock struts, like the KW HAS springs.
    Feb 22 2019
    PNW
    Is there any reason you went with the H&R coilovers over the KW versions?
    Feb 22 2019
    PNW
    Curious if anyone knows if there’s a functional difference or its just fit and finish between these two edc modules?
    http://https://www.kwsuspensions.com...-68510144.html
    http://https://scalesuspension.com/s...lete-unit.html
    Dec 14 2018
    2014 MINI
    Gallatin TN
    About a 1000.00 worth hehe :)
    Established Member Two Rings Ronnitude's Avatar
    Feb 06 2020
    Chicago, IL
    So, what did you end up going with??? I literally have the same questions about lowering my A6 haha...found this post and i'm like YES!
    Established Member Two Rings Mr Sharp's Avatar
    Dec 03 2019
    DFW
    Now that it's been some months, how are these holding up?
    Thanks.
    Mr Sharp
    New to me 2012 Audi Q5 P+ | LED interior + license | Spulen spacers | {more to come...}
    Originally Posted by {someone here}
    You may be Mr. Sharp, but you are very un-sharp about this engine.
