Results 1 to 40 of 54
    Oct 22 2018
    UK
    Placing car on jack stands
    Hey guys, sorry if this has been asked before, I did try a search and couldn't find any definitive answers with images etc. My question is, if using the pinch welds to jack up on, where are you guys placing the jack stands? If possible, please include pics with your answers.
    B8.5 Glacier White S4
    IG: @theworkerbee_uk
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    I jack the car up on the plastic portion that goes over the frame rail then I put the stand on the metal pinch weld.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Established Member Two Rings Jwill's Avatar
    Mar 23 2018
    Collegeville, PA
    Same for me. Block of wood on-top of jack then jack the car up on that plastic portion that covers the frame. The jack stands I have fit the pinch weld and the shape of the frame perfectly.
    2013 Estoril Blue S4
    | DSG | Prestige | Sport Diff | B&O | Carbon Atlas Inlays | Black Leather w/ Alcantara
    | Modifications: EPL Stage 2 SP w/ TCU Tune | CR-15 Strut Brace | Alu Kreuz | Bilstein B12 Pro Kit | EuroCode Sway Bars | Borla Exhaust | CTS Turbo Intake | Forgestar CF10 w/ Firestone Firehawk Indy 500
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    There is just enough room to place my Schwaben jack stand right next to my jack. However, I just picked up one of these, to specifically address that issue, but haven't used it yet.
    https://safejacks.com/collections/co...ck-single-unit
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Senior Member Three Rings Jk79's Avatar
    Sep 20 2018
    Chicago
    Depends how big the jack is. I have 2. Large has a 4 inch face on it and the small is 2 inch. I will either use the larger jack to raise and support the car at the pinch weld, then place the stand next to it under the plastic covered side of the frame just as a backup. Or if I am raising both sides I will use my smaller jack, which leaves just enough room next to it to also put a stand on the pinch weld before moving the jack to the other side to repeat.
    2018 RS5
    2014 S4 - EPL Stage 2+ (SOLD)
    Oct 22 2018
    UK
    Thanks for the replies guys. Anyone got a picture of the "plastic portion"?
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by sacandagaD View Post
    Please let us know how these work out for you; they have been on my eventual list for a long time, but there always seems to be higher priorities.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Jul 02 2013
    Quote Originally Posted by bakedziti View Post
    Will do, am hoping to use it soon to switch over to summer tires.
    Oct 22 2018
    UK
    Do you know if there's anything similar for those of us in the UK?
    Sep 20 2018
    Chicago
    Quote Originally Posted by theworkerb View Post
    If you look at the side of your car, where you would normally place a jack there is a small arrow shaped mark. Directly below that is the section of the frame rail that is exposed. This is the pinch weld. Standard lift point. That frame rail runs the length of your car but most of it is covered in plastic. Not my pic but this is basically what we're talking about. Arrow on top, jack below right on metal, plastic covering the rest of the rail on the left.
    2018 RS5
    Oct 23 2014
    Buffalo, NY
    Thank you! Can I ask how long you waited for your order, or if they’re still always backorded?
    °2011 A4 | 6MT
    Established Member Two Rings digitalchris's Avatar
    Jul 15 2015
    MD
    Hmm i jacked the car up at the pinch weld using this:
    https://www.amazon.com/2-Pack-Rubber...05582093&psc=1
    but then I placed the jack stands under the wheel supports.... anybody see an issue with that?
    2013 Cabriolet | GIAC Stage 1+ ECU | GIAC Stage 2 TCU | 034 drivetrain inserts and Rear Swaybar w/Endlinks | AWE S-Flow Intake | ST X Coilovers | Rohana RF2 20x10 Anthracite
    Jul 02 2013
    Ordered it last Monday, got it on Friday.
    Jul 02 2013
    Honestly don't know. Maybe shoot them them an email, they answered a shipping question I had pretty quickly
    Oct 22 2018
    UK
    Quote Originally Posted by Jk79 View Post
    Thanks for that. I was more unsure about where to place the Jack stands once I've raised the car using the pinch welds
    Jul 02 2013
    I've got the exact same jack as in that photo. You have to get the jack as far back as you can on the exposed pinch weld, and then put the jack stand in front of it. You can't put it behind it, since the jack lifting handle on the side is in the way. Then do the opposite on the other side of the car, and put it behind the jack, so one will be in front and one will be further back depending on side.
    Sep 20 2018
    Chicago
    Np. I know it was mostly redundant but was trying to show where the plastic part on the frame rail is people were referencing. And/or how much room you’d have next to the jack to put the stand.
    2018 RS5
    Senior Member Two Rings ellwood's Avatar
    Feb 12 2015
    16 SQ5, 21 M340i
    PA
    my technique was as follows. i always started with the stands at a low setting and repeated the process as necessary to get the height i needed
    1) place 2x4's under rear tires (either drive on, or jack up one side at a time)
    2) lift front one side at a time by placing the jack pad on the rearmost part of the front subframe (where the last 2 bolts are)
    3) place front jack stands at factory location on pinch weld
    4) lift the whole rear of the car by placing jack pad on the rear subframe (not the diff), next to where the diff mount is
    5) place rear jack stands at factor locations on pinch weld
    2021 M340i xDrive, 2016 Sepang SQ5, (sold) 2012 Glacier White S4 6MT - APR Stage II
    Oct 22 2018
    UK
    Someone sent this, is this our car?
    Senior Member Two Rings finnicky7's Avatar
    May 21 2017
    Detroit, MI
    That is not our car. The side points look the same though.
    2015 S4 Prestige Volcano Red DSG AEM 2 stage W/M injection EPL 104 Tune, EPL TCU Tune, OEM TB, Jokerz Chaos Ported Blower, AMS Alpha Performance Boost Cooler, EPL 57.6mm SC Pulley, 189mm DP, HPFP, Walbro 255 bucket adder, Roc-Euro Intake, 034 Billet Drivetrain & Subframe Mount Kits, P3+TrackPack, RSE Test pipes, 034 Resonator Delete
    11.3 @122.95
    Senior Member Three Rings KAMP's Avatar
    Sep 18 2018
    2004 Nissan Murano SE AWD
    I have a similar jack and the jack stand doesn’t fit because of the handle. Since that is the case, I unscrewed one of the the handle screws with an Allen wrench and “swiveled” it over to fit the jack stand beside it. Works perfectly fine for me at this point. I can always post a pic if needed.. I should be doing a tire rotation soon anyways.
    Jul 02 2013
    Quote Originally Posted by KAMP View Post
    I see exactly what you mean on mine as well, great idea.
    Oct 22 2018
    UK
    Yes, please do post a pic. Thanks
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Whenever I want to use jack stands on a unibody car, I always locate a sport in the center area of the front and rear of the car in order to lift the car from the front/rear center points. Since I have not done this on my S4, where exactly are those points located on this car?
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Oct 22 2018
    UK
    Quote Originally Posted by SouthernBoy View Post
    Thats my issue, I'm not sure there is one...
    Feb 12 2015
    16 SQ5, 21 M340i
    PA
    check out post #18
    Oct 22 2018
    UK
    Quote Originally Posted by ellwood View Post
    check out post #18
    Ah ok, I've not been under the car yet, does anyone have clear, fool proof pictures showing the location?
    Mar 05 2016
    Attachment 114428
    I was jacking up the car where I cercle ⭕️ and putting the the jack stand at the edge green cercle. With time the plastic liner just ripped off exactly where is the red ⭕️. Will be great to find other lifting point.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Oct 22 2018
    UK
    Quote Originally Posted by TC_S4 View Post
    Attachment 114428
    Dont like the idea of parts ripping off...
    Aug 07 2012
    Vancouver
    I always put a hockey puck on top of my floor jack and lift right on the exposed metal portion of the pinch weld itself. Never had any problems. My jackstand can fit just barely next to my floor jack and support across the pinch weld
    Oct 13 2009
    MN
    Ummm plastic? Guess you boys don’t care too much about destroying the under side of your cars.
    Sep 09 2018
    Pennsylvania
    What jack pads do you all recommend? Pictures are worth a thousand words btw someone take 5 mins and show where you jack it up and place jack stands. Ty
    Sent from Audizine mobile app
    Senior Member Three Rings vpls4's Avatar
    Feb 17 2017
    Tempe, Arizona
    ^Arg
    I recently wrapped my exhaust. I put the $79-$99 grey steel harbor freight low profile jack on the innermost part of the pinch welds. That leaves enough room to put the jack stands (harbor freight 3 ton) on the outermost part of each pinch weld. 2 ton jack stands would probably even fit better as they have a smaller base. For the lift jack pads. I bought some used hokey pucs and used a grinder to cut a groove in it same size as pinch weld
    some guy on here was using this http://www.purems.com/product.php?II=833
    and for safety sake i put the tire on blocks and slid it under there... figure better a little damage to the car than being crushed to death if a jack fails (especially since I had them on blocks, lol)
    '15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake | AMS Alpha Cooler | 034 Street Density Eng Mounts
    EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, Pilot SS | Bilstein PSS10's | RSE Test Pipes | AWE Touring /Res DPs
    Feb 17 2017
    Tempe, Arizona
    Did you use the adapter plate that was mislabeled as 2014-2018 'S1' ?
    Veteran Member Four Rings Envy187's Avatar
    Feb 13 2018
    Quote Originally Posted by vpls4 View Post
    Looks to me like the fella in the red shirt/white Impala across the street wasn't the only one taking a risk that day...
    Feb 12 2017
    Redmond, WA
    Can you elaborate on where exactly these spots are, particularly step 2 and step 4?
    Mar 05 2016
    Can you post some pics for #2 & #4?
    Feb 12 2015
    16 SQ5, 21 M340i
    PA
    Quote Originally Posted by techracer View Post
    sorry i don't have pics on hand, but i'll try to use some of 034 motorsports diy guides to help
    for the front lifting point, check out the pic for step 1 in the following guide. follow the curved control arm to where it meets the front subframe. the bolts i'm talking about are next to the plastic underbody panel
    https://store.034motorsport.com/docs...structions.pdf
    for the rear lifting point, look at the pic for step 2 in the following guide. you can see the rear subframe under the diff... i place the jack pad to the right of where the diff mount is on the rear subframe
    Mar 05 2016
    So lift on the spots circled in green?Attachment 115316Attachment 115317
    Veteran Member Three Rings 03redgti's Avatar
    Dec 20 2010
    lancaster, pa
    anyone else amazed by the amount of people that don't know how to put a car on jack stands??
    2013 S4 | Glacier White | Chestnut Brown Interior 1/13 | Sport Diff | IE Stage 2 | IE Intake | JHM V2 Test Pipes | PLM V2 HE | Custom Magnaflow Exhaust | Solo-Werks S1 | Rohana RF-2 20x10 square | Continental DWS |
