Results 1 to 12 of 12
    Active Member Two Rings NC_'s Avatar
    Mar 10 2019
    South Bend, IN
    A3 8V S-Line Spacers
    Hi all. Recently lowered my 2018 A3 with Emmanuele springs and love it. Now I’m considering spacers. My FTG is right at 25” all around, and I’m wondering if I can get away with 15mm up front and 20mm in the rear.
    I’ve read high and low and even on the VW forums. Everyone seems to be talking stock S3 19” wheels. Mine are OEM 18x8 ET46 with 225 tires - just curious if anyone is running this setup?
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Yep, should be no problem.. I ran 15/20 on my factory 19's (S3) on 034 springs with room to spare. Doesn't matter 18 or 19, the overall diameter should be the same. Also, the 18"s ride better than the 19's. I took off my factory 19" and run 18's - 18x9 ET30 with the RS3 stagger of 255/235 (no spacers now)
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Junior Member Two Rings
    May 01 2018
    Orlando/FL
    Anyone else with pics? I am debating on adding spacers as well.
    Veteran Member Three Rings S3_Miles's Avatar
    Jun 13 2018
    Paso Robles CA
    I have Neuspeed RSe102 that are ET45, so I run a 10mm rear and an 8mm front (and this was after trial and error of both a 20mm and 15mm rear first, and a 10mm front)
    Dec 10 2004
    R8_LS400
    Dallas, TX
    This is with 10/15 spacers
    Mar 10 2019
    South Bend, IN
    Quote Originally Posted by S3_Miles View Post
    Did you rub with the 15mm or 20mm in rear?
    Established Member Two Rings Hard-Knocks's Avatar
    Jan 04 2017
    Raleigh, North Carolina
    12.5 front and 17.5 rear looks perfect to me with OEM wheels. Will be taking these off soon for new wheels and selling the matching lug bolts and spacers. Car not lowered.
    Jun 13 2018
    Paso Robles CA
    Quote Originally Posted by NC_ View Post
    No rubbing, but the post immediately above this one may be the right way to go if they are OEM wheels
    Established Member Two Rings jesse_gabriel's Avatar
    Dec 09 2015
    california
    Very helpful thread as I am about to install emd spring and want to do spacers as well
    Mar 10 2019
    South Bend, IN
    Quote Originally Posted by jesse_gabriel View Post
    You won’t regret it! The EMD springs look awesome and ride like a dream. Can’t say enough good about them! 15/20mm spacers have worked out perfectly.
    Senior Member Three Rings JimmyS3's Avatar
    Aug 13 2016
    Pennsylvania
    I'm on 034 springs 20 spacers all around no issues
    :: 2018 S4 ::
    - 034motorsport - APR - CTS - EMD - ECS - MBRP
    Mar 10 2019
    South Bend, IN
    Quote Originally Posted by JimmyS3 View Post
    Yeah I wonder if I should’ve done 20mm in the front. Maybe when I go to aftermarket wheels.. hmmm..
