I've had an intermittent engine starting issue ever since I've had the car but it seems to get better and worse seemingly randomly. I usually leave the key in and wait till the immo light turns off before starting the car, since if it starts flashing the engine wont stay on. There may be times where I wont have an issue for months, while other times I'll have it happen a couple times a day.
I recently got a vcds cable and the only code relating to the immobilizer was"Engine start blocked by immobilizer P1570". The car only came with one key so I have not been able to see if the valet key works better or not.
I've heard that the reader coil wires can become loose and I have noticed moving the steering wheel exacerbates the problems. how would I fix this if it was the problem? Are there other common immobilizer issues that may be relevant? I'd like to avoid getting a new key if possible as I've heard it's not the cheapest at the dealerships...
Thanks for the help!
