Results 1 to 27 of 27
Thread: Sony XAV-AX100
    Established Member Two Rings toby.becker's Avatar
    May 18 2017
    2003 Land Rover Discovery II
    Kansas
    Sony XAV-AX100
    Undergoing a head unit swap and looking for additional info on the install for the Sony XAV-AX100. I ordered the install kit from Crutchfield and the install directions are lacking to say the least.
    Has anyone done this swap before? My searches have come up with absolutely nothing. My main question is - which connections from the wiring harness match up with the Crutchfield wiring harness, and is the connection port in the rear of the head unit needed/used? Haven't looked at it too extensively because it is damn near April and still snowing in Kansas
    Mainly looking for people with experience with this unit on this platform to provide information.
    May 18 2017
    Kansas
    Bump
    Instagram - b5_becker
    Veteran Member Three Rings csobel's Avatar
    Mar 25 2018
    Portland, OR
    Interested as well... I’m going to be ordering one soon.
    May 18 2017
    Kansas
    Quote Originally Posted by csobel View Post
    It's a nice unit for the price, just not sure how to go about the install without having to make a custom harness
    Jun 07 2005
    Shepherdstown, WV
    I cant imagine they have done this different than any other sony radio, what did Crutchfield supply to you with the install kit?
    There should be a sony harness and a crutchfield harness( likely a metra) https://www.crutchfield.com/g_103000...s.html?tp=2977
    In Bose equipped cars it should come with a metra harness that has RCAs (it might just be one kit actually), those RCAs will plug into the amp out connections on the radio itself. You'll just need to then attach the power, ground, amp/antenna wires from the metra harness to the other harness. For the amp (look at that link above) you'll just take the factory amp connection at the radio and plug it into that red block.. other end to the rca outs on the new radio like noted above.. done. The other block you'll ignore all the line level speaker wires (the LF+ LF- etc etc) and only do the power/ground wires.
    If you don't have a factory amp you'll ditch the red harness with the rcas. You will then take the wiring from the sony radio (its basically universal on all aftermarket radios) and the black harness above and you will splice LF+ on metra to LF+ on sony harness.. repeat repeat repeat. Crimp caps are best for this due to how harnesses sit in the dash, they look like twist caps you'd use in home wiring but are crimps.
    you will end up with a harness that looks like this (just use the crimp caps not butt connectors, and if you solder I will delete this post) if you have non BOSE (came out of a car I parted) You plug the one end into the radio and one end into the factory connectors no making of any sort of custom harness. If you do have bose it will look like this only you don' have to waste crimps doing all the speaker wires (can't hurt just to prevent any sort of shorting/interference)
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    May 18 2017
    Kansas
    This is what I'm looking at. The 3 from the metra harness seem to plug in pretty straight forward, but that leaves me with 3 additional plug ins with no where to plug then in. Also seems to be a power source on the back of the head unit but nothing to plug into that. 20190404_183650.jpeg
    Jun 07 2005
    Shepherdstown, WV
    What are you calling the 3 extra plugs?
    Does the black metra connection fit 2 plugs? Some do I forget if that is how these work. It may be notched or slightly wider on half for one black plug.
    Are you including the two red on the side? Those aren't stock so they can come out.
    Plug what you can into the metra harness and post what's left.
    May 18 2017
    Kansas
    Yes was counting the 2 on the side. I'll post pics of what's left/not plugged in tonight.
    Senior Member Two Rings WEBER's Avatar
    Jul 01 2008
    Imola B5 S4 ,90 CQ 20vt KTM Superduke
    Portland, OR
    It may be a little late, but installed mine with the harness and install kit from enfig. Super easy, made for the stereo and awesome quality.
    https://enfigcarstereo.com/radio-ins...year=2000-2001
    2001.5 S4 Imola
    May 18 2017
    Kansas
    This is what I'm looking at now. One red connection that doesn't seem to go anywhere and still not getting power to the head unit. Pls send help. Snapchat-1037859407.jpgSnapchat-1086278613.jpgSnapchat-627823638.jpg
    Jun 07 2005
    Shepherdstown, WV
    You don't have the harness plugged into the radio that came with the radio. That's why you have no power. All you have is sound to the amp plugged in.
    Why is rher a black connector in the red one?
    Take a photo of exactly what came in the radio box and the harness crutchfield sent you on a table out of the car.
    You seem to be not understanding some very basic stuff of how this install works and just randomly plugging things in.
    Jun 07 2005
    Shepherdstown, WV
    You don't have the harness plugged into the radio that came with the radio do you? If so did you actually crimp those connections I don't see any. . That's why you have no power if you didn't do that.
    Why is rher a black connector in the red one? Ha e you looked at the label with the wiring printed in the stock radio?
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Quote Originally Posted by chris86vw View Post
    Haha this pretty much summed up exactly what I was thinking to myself while I was looking at the photos.
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    ive said it before, ill say it again. this poor car
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
    May 18 2017
    Kansas
    Quote Originally Posted by slowSfaux View Post
    There was no harness that came with the radio. Theres a factory harness and the one I got from crutchfield that *should* work
    May 18 2017
    Kansas
    Quote Originally Posted by m_haiser View Post
    Blow me
    Jun 07 2005
    Shepherdstown, WV
    Quote Originally Posted by toby.becker View Post
    Check the box and actually read the directions
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Quote Originally Posted by WEBER View Post
    Do you have any pictures of yours installed? Any shots at night? Interested to see how it works with the rest of the interior.
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Updates?
    Jul 01 2008
    Portland, OR
    Quote Originally Posted by wbrunner23 View Post
    Almost forgot about you!
    2001.5 S4 Imola
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    I kinda wish it would fill more horizontal space, but it looks pretty good, WEBER. If the Home, >>, & << buttons were in red, it would be perfect.
    Tell me about the faceplate, please
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Faceplate kinda looks like the one Enfig sells?
    https://enfigcarstereo.com/ENFIG_RMK5_A4B5DD.html
    2001 Corvette (C5) Z06
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Have the XAV AX 200 in mine. If you update the firmware you are able to change the RGB lighting on those units.
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Quote Originally Posted by Alex1188 View Post
    Nice - show me some pics please, Alex
    Mar 10 2013
    |CURRENT|01.5 S4|
    |TOTALLED|09 B8 A4 QUATTRO|EURODYNE|FRANKENTURBO F23L|
    |PAST TURBOS|IHI JH5|PROTOTYPE BW K03 BILLET WHEEL|
    - OEM IHI K03 APR STAGE 2+ V1.0-1/4 MILE TIME [email protected](-85DA)
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Nice - thanks, Alex
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    I have the AX5000 and love it. Best radio I have ever owned.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
