Hi,
I recently upgraded my cellphone from a Samsung Galaxy S7 to an S10+ (Android) and I just discovered something yesterday regarding audio from Google Maps (and maybe Waze too, although I have not tested it yet). With my phone connected to the MMI system over bluetooth and I launched Google Maps for directions on how to get somewhere, I would not hear the audio/turn by turn directions at all. Not through the phone, not over the MMI.....nothing! The moving map works fine, which resulted in me having to hold the phone and follow the map. I thought it was because my S7 was old(er), but I am getting the same behavior on this new S10+. Audio in the maps app is not muted and when I raise the volume on the phone, the media/MMI slider bar appears in red, almost as if it's telling me there's a problem. This raised a (red) flag for me. I started poking around in Google Maps settings, tapped on Navigation Settings and in there is a switch called Play Voice Over Bluetooth. I found that if I set that switch to off, then I am able to hear the turn by turn directions through the phone. I never really wanted to hear the directions through the MMI system, I just wanted to hear them from the phone. If I drill down into the MMI bluetooth settings though, both Handsfree and Audio are turned on. So my two questions are, should the phone bluetooth connection to the MMI play the turn by turn directions over the car speakers? If so, why isn't it?
Thank you.
