Originally Posted by
canadianA4B7
Cool if you wanna know what does fit with what easily I already have some info. The hardest thing is stuffing the k04 turbine into anything other then a k04 hotside. I’m pretty sure there was some clipping done to turbines in the past and attempted machining of the hotside but there’s just not enough meat in the k03 to safely machine enough out of it.
That’s cool. I could pick up a K04 housing cheap enough. My main concern is fixing the manifold/flapper play. If I have to bore out the hole for the flapper fix from turbolabs to fix it properly, not just throw a bandaid on it, that’s easy enough to locate and drill or ream. I can have any size reamer or carbide mill made real cheap or it can be bored out or drilled and I can hold pretty tight tollerences with the equipment I have access to. Or it can be welded up and drilled. I use a very precise micro welder for my day job and he fixes casting molds and very complex jigs on a daily basis.
As long as I have a working exhaust housing and wastegate flapper, the hard and not easily replaced part is done. I can make a decision based off of what I find.
And are you sure you can’t stuff K04 guts in a K03 housing? A couple of the turbo rebuild shops offer it as a K03 upgrade. As a matter of fact, vvenom800tt is sending his K03 out for a K04 upgrade. G Pop Shop quoted him $750 for a K04 spec K03 rebuild.
