Hi All,
I've read all the guides and info available here on cruise control and DIS retrofitting, and I went ahead and did it myself today. I'm having trouble with the coding portion of the process unfortunately, and I cannot figure out what I'm doing wrong.
The problem occurs during the steering module recoding. I can do the coding itself successfully, but since I have upgraded the SCSM to one that supports DIS, I have to perform adaptation on it as well.
So when I do the following:
[16 - Steering Wheel]
[Adaptation -10]
Channel 81
New Value = 00111
Test
Save
Testing goes through fine, but upon pressing Save I get the message 'Bus not OK', then 'Pin'. After, if I check the Steering Wheel Measuring Block Channel 81, I can see that the module has my car's VIN, but also a bunch of seemingly characters after the VIN itself.
I have not seen anyone else encounter this problem and I'm not sure what's causing it. The workshop code of the steering module got changed to 00000 from what it originally was along the way, but I'm not sure if that could be causing the issue. I have mainly been following this guide: https://drive.google.com/file/d/0B6..../view?hl=en_GB and Step 21 in this one is where the issue occurs. I've tried just proceeding with the steering angle calibration and the ABS coding, but fault codes regarding both ABS and ESP still persist, and I think it's due to this adaptation error of the steering module itself.
I have pasted the Auto-Scan results from the car below; if anyone could help me out I'll be forever in your debt :).
VCDS-Lite Version: Release 1.2
Saturday, 23 March 2019, 17:02:51:0
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 03G 906 016 CJ
Component: R4 1,9L EDC G000SG 6413
Coding: 0000071
Shop #: WSC 06435
VCID: 6DAD4AB73489
2 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 000 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 000 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04255
Shop #: WSC 06435
VCID: E5BDB2976C79
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 AA
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63351
VCID: 60B32383F35B
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Controller: 8E0 907 279 C
Component: int. Lastmodul RDW 0606
Coding: 00001
Shop #: WSC 63351
VCID: 321799CBED37
1 Fault Found:
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63351
VCID: 3E0FBDFB296F
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 00042
Shop #: WSC 00000
VCID: 3E0FBDFB296F
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 900 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00001
Shop #: WSC 00050
VCID: 2E2F8DBBF90F
WAUZZZ8E35A026852 AUZ6Z0D0195375
2 Faults Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
Address 46: Central Conv. Labels: 8E0-959-433-MIN.LBL
Controller: 8E0 959 433 AR
Component: Komfortgerát T85 1512
Coding: 06720
Shop #: WSC 63351
VCID: 817586079811
5 Faults Found:
01562 - Right Rear Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
00956 - Key 2
35-00 - -
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01560 - Passenger Door
61-10 - Won't De-Safe - Intermittent
Address 77: Telephone Labels: 8E0-959-433-MIN.LBL
Controller:
Note: Excessive Comm Errors
End --------------------------------------------------------------------------------------------------
