Results 1 to 40 of 60
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    My experience with exhaust drone, resonators, a j-pipes
    Hey everyone I wanted to share a little bit of my experience when I when down a customized stock exhaust route so perhaps others can learn from my successes and failures. To preface this, I initially wanted 'slightly' more aggressive exhaust sound than stock so I'll try to outline my journey here as well as my impressions of each configuration.
    1) Stock mufflers, stock center resonator with baby resonators deleted:
    I first started the quest by installing non-resonated downpipes on an otherwise stock system. Nice results, a little more aggressive but still quite mellow overall and no drone. Eventually time passed and I determined I wanted more sound.
    2) Stock mufflers, center resonator delete, baby resonator delete:
    I then deleted the center (large) resonator and had 2 straight pipes installed in it's place. This sounded horrible. Terrible rasp and drone to the point where I didn't even want to accelerate because of how awful the car sounded. This was remedied in a hurry.
    3) Stock mufflers, all stock resonators deleted, Magnaflow resonated x-pipe added by downpipes:
    This was much better and sounded just slightly more aggressive than my setup in step 1. No drone or rasp at all, but a little quieter than I ultimately wanted.
    4) Muffler delete, Magnaflow resonated x-pipe
    This setup had a pretty nice sound (IMO) under throttle and wasn't obnoxiously loud, though definitely louder than setup 1 and 3. The rasp was gone. However, it had some wicked drone from ~1700 - 2500 RPM. I added some sound dampening material to the trunk, spare tire well, and behind the back seat which helped a little but wasn't enough.
    5) Magnaflow resonated x-pipe, dual Vibrant bottle resonators
    I had hoped the bottle resonators would absorb some of the resonance but they really didn't do anything at all to help with that. They quieted the car slightly but the overall impact was pretty minimal and I still had more drone than desired.
    6) Magnaflow resonated x-pipe, dual Vibrant bottle resonators, dual J-pipes (branch resonators)
    I finally bit the bullet and decided to try branch resonators. I had these welded into the downpipes and run back parallel to the exhaust until they met the center brace with the goal being to try to get in the 34-35" length range based on calculations of drone frequency and sound wavelengths). They ended up being about 32" because we ran out of room due to the cross-brace but I thought that might be enough. These made a huge difference when the car was cold. There was absolutely no drone whatsoever. However, when it heated up, I was still getting more drone than I wanted because the exhaust gases heated up and the wavelengths got longer, hence the need for the resonators to be a little longer than they were.
    6) Magnaflow resonated x-pipe, Magnaflow non-resonated x-pipe, dual J-pipes, dual Vibrant bottle resonators
    I wondered if a second x-pipe would help to curb some of the resonance if added further back in the system so I had one of the non-resonated pipes put back in the area where the original factory large resonator was (so the straight pipes were replaced by the x). This provided a negligible improvement as well, on par with the addition of the bottle resonators.
    7) Dual Magnaflow resonated x-pipes,dual J-pipes, dual Vibrant bottle resonators
    I found a shop that could manage to squeeze a second resonated x-pipe in where I first had the non-resonated X installed (the location of the factory center resonator). This made a big difference in the overall sound level and did help somewhat with the drone but still didn't eliminate it. I have added some insulation to various areas in the trunk and that has helped as well. Overall the drone is pretty manageable and not evident at cruising speeds unless I encounter a gradual hill where a partial-throttle scenario occurs in the 1800-2200 RPM range.
    You might be reading and thinking that I'm an idiot for trying so many things with stock system as a base and you're entitled to your opinion. Why did I keep trying to make the customized system work? Initially a 'relatively' small cost to have a shop weld in a couple new parts or cut out a couple old parts. I'm thinking I can drop a couple hundred bucks and it should get me close. As time goes on and I've tried more and more it becomes the argument of trying to fix what you now have more invested in or cutting bait and getting a fully engineered system. This coupled with the fact that it seems not even all the aftermarket solutions are drone-free so. Finally, my own curiosity as an engineer lead me to really want to try some different things to see how impactful they really were.
    At the end of the day, I'm pretty happy with the sound now and I learned a few things along the way. All in, I have around $1100 in parts and labor for all these iterations. If I had just skipped right to the system I describe in step 7, I would have been at somewhere around $600 parts and labor. I wanted to post this just to give some details and observations on my own experience so people who are considering this route can perhaps either skip some of the intermediate steps that I took or say screw it and pick up a true aftermarket system if they don't want to deal with the hassle. In the attached image, you can see the dual resonated x-pipes and the branch resonators. The bottle resonators are back where the stock mufflers used to be.
    Cheers!
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
    Veteran Member Four Rings Envy187's Avatar
    Feb 13 2018
    Thank you for that wonderful write-up, JACKAL. That's incredible that purely going the 7th configuration cost you just over half of all the other configurations combined. LOL! This will assist me in future when I plan on dabbling in such things after my warranty is up.
    Mar 28 2017
    Quote Originally Posted by Envy187 View Post
    Thank you - I hope this will help you with your future plans. It is interesting how the costs worked out though. The final configuration broke down into about $350 for parts (all four resonators plus exhaust tips) and some labor to cut parts out and put the new stuff in place.
    Feb 18 2019
    PDX
    Which non-resonated downpipes did you go with for step 1? That's basically what I'm looking for, just slightly more aggressive than stock.
    2013 Phantom Black B8.5 S4 | DSG | Sport Diff | B&O | Bone Stock
    Mar 28 2017
    Quote Originally Posted by SilentEdge View Post
    I used CTS Turbo.
    Mar 31 2008
    eS-4
    CAL*SO
    I love that everyone is on the j pipe/ helmz holtz bandwagon.
    Tried telling everyone last year when polo exhaust first released it that THAT was the way to go. Although everyones homegrown methods are a bit frankenstien'ish, i guess if it works, it works.
    The polo performance exhaust is downpipes> resonated xpipe box> x pipe> helmzholtz/ straight pipe out. zero drone, zero rasp. one and done.
    Senior Member Three Rings vpls4's Avatar
    Feb 17 2017
    Tempe, Arizona
    Quote Originally Posted by JACKAL View Post
    Do you still have your cats?
    Are you going to do any wrapping? Rasp free method
    '15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake | AMS Alpha Cooler | 034 Street Density Eng Mounts
    EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, Pilot SS | Bilstein PSS10's | RSE Test Pipes | AWE Touring /Res DPs
    Feb 18 2019
    PDX
    Thank you, going to order soon!
    Mar 28 2017
    Quote Originally Posted by vpls4 View Post
    Yep, still have the cats. I don't have any rasp now, just a little hint of drone. I had read that thread you noted and I may have missed it but did the wrapping have any impact on drone or just on the rasp? I suppose the added mass could possible help if some of the drone is related to resonance of the exhaust system itself, but I could also see it possibly fighting me since my j-pipes are already a little on the short side to cancel resonance when the car heats up. If I wrap, I will be increasing the gas temperature and the wavelength of the sound waves so those j-pipes would be even less impactful.
    Curious to hear more on this though - I'm certainly willing to give it a shot!
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by Fresh.S4 View Post
    unless your're catless*
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Oct 30 2012
    Oxford, MS
    I also went through many iterations and have j-pipes (mine are at the back above the rear mufflers and aren't as affected by the car being warm /cold. I've read that j-pipes are more effective the closer to the front that they are but there are obviously some tradeoffs.
    I get the engineer mindset (I was an engineer in a former career but I'll always have a bit of engineer in me) and am surprised at the number of people here who can't wrap their head around it.
    Mar 28 2017
    Quote Originally Posted by chilort View Post
    I agree - it's a simple concept that has proven results. Do you have any pics of the j-pipe setup you went with including overall length? I am planning to see if there is any way to get a little more length on my pipes just to help subdue the remaining drone a little more when the exhaust gets warm.
    Mar 06 2013
    Long Island, NY
    So it took you the same amount of money and a lot of headache to find out that you should have just bought an AWE system from the beginning?
    Account Terminated Four Rings
    Mar 22 2016
    73 Jimmy 496 BBC
    Just have a 3” dp to Y built and y put the back. 3” single out the back would probably sound very good haha
    Mar 28 2017
    Quote Originally Posted by BCeagle08 View Post
    Everything is 20/20 in hindsight. I didn’t start the project anticipating spending what I did and going through the iterations I did. Quite obviously if I knew then what I know now I would have taken a different route. Like I said in my original post though, I’m an engineer and part of this whole process was driven simply my curiosity.
    Oct 30 2012
    Oxford, MS
    And install test pipes and see how great that AWE sounds (assuming you actually like the sound of the AWE in the first place -- not everyone does).
    Oct 30 2012
    Oxford, MS
    I need to get some more and better pictures. I had mine made with a few inches of adjustment (not shown - it's the uncapped section at the end of the curve in the pictures in the link below) and have it setup mostly to cut the drone at 70mph. I still get the long low grade annoyance that you mentioned.
    https://www.audizine.com/forum/showt...exhaust-setup?
    Feb 13 2018
    https://www.audizine.com/forum/showt...etup?p=1338555
    For whatever reason, the URL you provided is leading me down a road I don't believe was the intended one.
    Oct 30 2012
    Oxford, MS
    That's odd. I fixed the link.
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    To each their own. My car came with a AWE Touring and resonated downpipes and I sold them and have the 11385 MF for my baby res and center res delete and it definitely sounds better now.
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    It is great that there are a lot of good sounding exhausts for our cars now... BUT still waiting to see someone come up with the magic catless exhaust combo that sounds good across the RPM range.
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Nov 27 2017
    Los Angeles, CA
    For what its worth, I have a dual pulley Q5 3.0T (same engine) and I have found exhaust nirvana pretty cheaply with the following custom setup:
    Magnaflow 12468 in place of baby resonators
    Magnaflow 11385 in place of center resonator
    Doug's Headers 2.5" exhaust cutout between the two Magnaflows, with 3 disk CC insert and a Dynomax mini bullet muffler on the outlet
    Borla 4" 20156 exhaust tips on stock rear mufflers
    There is an electric switch I can use anytime while driving to change the sound. With the cutout closed, the car is dead silent at all times... quieter than stock; almost electric car ish.
    With the cutout fully open, it is very supercar like sound at a good volume (loud but not obnoxious) smooth at all rpms, no weird resonances or droning ever under any conditions.
    I can open it just a little bit if I want in between.
    I drop off the kids in silent mode. Then racecar :)
    I believe a similar setup should work on an S4.
    Pics:
    2016 Q5 3.0T | Shorties Racing Ported Blower | Merc Racing Quad Pass HX | Fluidampr 183 | CTS Turbo 57 | EPL DP and TCU Tunes | R8 coil packs | Adaptive Damping Suspension with KW H.A.S. | Comfort Pkg w/Perforated Milano Ventilated Leather | Sport Int Package | B&O | ECS diffuser w/4" quad tips | Whispbars | Yakima HighRoad | TSW Chrono 21x10.5 et32 with 3mm/12mm H&R spacers | 295/35/21 DWS06 | Custom dual x-pipe exhaust with IE DPs, E350 V10 CARB cats, Magnaflow 11386, Vibrant UQs, S5 mufflers
    Feb 17 2017
    Tempe, Arizona
    No effect whatsoever on the drone, for me anyway. I'll have to record it sometime while driving around.
    I have a bunch of before and after sound clips from outside the car in the Rasp free method
    I read through this thread today and have ordered the (2x Dodge part 52103612AA) that everyone was ordering a while back, will experiment with placement.
    The Unofficial Aftermarket Exhaust 2000 RPM Vibration Thread
    If APR is successful with their Catted Race Pipes then I will definitely be putting cats back in. They should be done testing in a couple weeks.
    Catted or Non Catted APR Race Pipes
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Not sure what you did. I’m happy with my track edition AWE exhaust and non res downpipes. I like loud. Wait until the cats come out.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Feb 06 2018
    Central VA
    Quote Originally Posted by stapan View Post
    Wow that is thinking outside the box. What coating or paint is that on the exhaust?
    2014 S4 Phantom Black Pearl P+ / B&O / Sports Diff / MMi
    Mar 20 2018
    Hanover, Maryland
    Links for j pipes? I cant find them in 2.5"
    Mar 28 2017
    Quote Originally Posted by TruS4 View Post
    I don't know of any OTS pipes that are that long. Synapse offers a few, but 24" is their longest. I just asked the muffler shop to fab some up. They aren't very complicated so any competent shop should be able to whip something up pretty quick.
    Established Member Two Rings mikemailloux's Avatar
    Feb 18 2018
    manchester, nh
    Pics:
    How much did this setup cost of you don't mind me asking
    Sent from my SM-N910V using Audizine mobile app
    Apr 18 2014
    Nashville, TN
    JACKAL, thank you for the write up. Since we are in the same state, I would have liked to listen all your setups.
    So you don't have an experience with ONLY removing the center resonator and replacing that with an X pipe? That is the setup I am thinking right now.
    I know we all drive a $60k S4 and all that, but if you are only looking to just get more volume, spending 1-2 grand on an exhaust system seems silly.
    Ah yes, us engineers tend to overthink, don't we?
    Current - 2021 A6 45 TFSI Premium Plus
    Sold - 2015 S4 manual Premium Plus
    Dec 29 2011
    Vancouver
    Quote Originally Posted by jungy4 View Post
    This is what I'm thinking of doing as well.
    JACKAL, any sound clips for your adventures?
    Active Member Two Rings chris4521's Avatar
    Dec 14 2015
    Toronto, ON
    Quote Originally Posted by Ornithology View Post
    I replaced my center (large) resonator with a magnaflow 11385.
    Didn’t love the results, fair bit of drone under load on the highway and it’s a bit raspy.
    I too am looking for the perfect drone free “OEM+” or sporty sound. Subscribed...
    I am thinking I might try back to back 11385 to stock mufflers next....
    Link to my video:
    Stock cats > stock Baby res > MF11385> stock mufflers
    https://photos.app.goo.gl/aa9B74sNeTVd5abL8
    And JACKAL - great writeup and information in this thread
    B8.5, DSG, EPL Stage 2, CTS HX, ECS Carbon Intake
    08 S4, 2.5" Catless downpipes, 2.5" Fast Intentions non-res, JHM Tune
    13 S4, ECS LT Intake
    Nov 27 2017
    Los Angeles, CA
    Quote Originally Posted by mikemailloux View Post
    Roughly $800 all in (including parts and labor).
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Thanks so much for taking the time to edit and share your experiences. Although I may not utilize your info. much due to being DSG, it is people like you that make this forum a wealth of knowledge.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Senior Member Two Rings Turbocoop's Avatar
    Jun 08 2014
    Charleston, SC
    Thanks for the writeup, I took a similar path, wasted some money along the way, and ended up with something I like- magnaflow 11386 in place of baby resonators to a CTS turbo exhaust. A little louder than stock and minimal drone, just what I wanted.
    Sent from my SM-G950U using Audizine mobile app
    Jul 14 2017
    Maine
    https://www.youtube.com/watch?v=MyL75RuNRQQ
    Here's a WOT flyby with Redstar test pipes, AWE touring with resonated DP's........I love it WOT, but I need to be a bit more sophisticated during daily driving lol. Magnaflow resonated xpipe probably next step.
    2015 Audi S4 APR Ultra charger with Dual Pulley 3.18 ratio, APR DSG tune, AWE touring exhaust with resonated down pipes, Red Star Test Pipes, ECS intake, AWE Coldfront (all), H&R sway bars, ECS rear diff mounts, ECS Control Arm Brace, CR-15 Front Brace
    Sep 21 2018
    New Orleans
    So do you still have the stock rear mufflers still? And would adding aftermarket mufflers like magnaflows maybe help with drone and rasp? Or is the rasp and drone created where the j pipes are, which makes the j pipe work where they are?
    Mar 28 2017
    Glad this has been of value for some folks. I do have sound clips from inside the car and I will see if I can get them uploaded.
    I ended up making one more change and I’m very happy with it. I removed the bottle resonators and quad tips (unfortunately) and replaced with straight pipes and resonated ovals. Why remove the bottle resonators? They didn’t do anything to help my drone and they quieted it down a bit. The result was that the remaining drone was eliminated (whether due to the oval, the small resonator within the tips or both I don’t know) and overall a very pleasant sound. So pleasant that I actually took off my CTS intake because I want to hear my exhaust more. Go figure!
    Jun 05 2015
    a few interesting items
    I ended up making one more change and I’m very happy with it. I removed the bottle resonators and quad tips (unfortunately) and replaced with straight pipes and resonated ovals. Why remove the bottle resonators? They didn’t do anything to help my drone and they quieted it down a bit. The result was that the remaining drone was eliminated (whether due to the oval, the small resonator within the tips or both I don’t know) and overall a very pleasant sound. So pleasant that I actually took off my CTS intake because I want to her my exhaust more. Go figure!
    Post clips!
    Sent from my LYA-L0C using Tapatalk
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    LOL +1
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Apr 26 2017
    GLS 450
    Nashville, TN
    Quote Originally Posted by scls4 View Post
    The setup you have plus the Magnaflow 11386 is what I was thinking would be the best setup (of what we have), BUT the packing materiel seems to be burning out of the Magnaflows, because EGT's are so high. Just an FYI.
    Previous
