Originally Posted by
hilmar2k
So install without removing the headlight assembly is a piece of cake (at least on a B8.5). If not for my silicone intake tube, whole job would have taken 10 minutes. The deAuto bulbs are nice. Haven't gotten them out on the road yet, but they are better match to the DRLs. I also installed the dual color deAuto fogs, and those are an even bigger upgrade. Way better than the yellowish stock fogs. They match the new headlights and the DRLs perfectly.I had already updated the front blinkers to LED previously (also deAuto) Not sure why the car doesn't come from the factory like this. Much more modern look now. Hat tip to deAuto for offering a quality bulb with a lifetime warranty at a reasonable price.
I swap my headlight bulbs without removing the headlights nor the bumper. Just need to remove the airbox. As for the silicone tube, at first I had hard time putting back, but found a trick, now it literally take me couple seconds to put back the silicone tube. You need to put the box in place first, plug the tube to the box and the other end pull away from the throttle body, down and in to the throttle body.
I also swap dual color fog lights, no need to access back of the wheel or remove bumper, I am not a technician that works per hour😅. Just used an Allen key, pop the fog grill, removed the fog holders and change the bulbs. As easy as it sounds, less than 1/2 hour to swap headlights and fogs lights.
