Results 1 to 24 of 24
    Established Member Two Rings Cyttorak's Avatar
    Jul 29 2017
    2018 TTRS
    Dallas
    Drive system malfunction
    Less than 5k on the RS no mods, been in the shop for a week. Anybody else had this error?
    Probably just me.
    Nov 03 2014
    BMW i3, Golf 1.4T, TT RS 8S
    Mexico
    No, that really sucks!
    My car’s Start/Stop system has a malfunction.
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Got one similar a few months back, it stated engine output was restricted to 3000RPM. I didn't have my VCDS in the car so I cleared it with the APR feature using the stalk just to see if it would return indicating a real issue. Wish I had been able to scan it to see the code but it never came back. Happened right after I switched from the E85 map to the 91 tune. Got a generic CEL last week after switching from the E85 back to 91, scanned that one and showed a generic P21F4. Just figure both times was a result of the last E85 in the lines going through on the 91 octane tune.
    It's been a week and they don't have a diag yet?
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
    Senior Member Three Rings chrisngrod's Avatar
    Feb 01 2015
    Des Moines, IA
    I had it before with my TTS on track when I turned off the traction control and got a little loose but not close to out of control.
    I think it reset itself or I reset the code
    Sent from my iPhone using Tapatalk Pro
    2017 Audi R8 V10 Plus
    2017 Alfa Romeo Giulia Quadrifoglio - CCM Brakes
    2017 Audi Q7 Prestige
    2016 Audi TTS (Injen Intake, Burger Motorsports JB4, AP Racing 6 Piston BBK, 19x9.5 wheels with tires for sale, Vehicle Sold)
    2013 Audi S4 Prestige - Milltek Valvesonic Exhaust, Roc Euro Intake - Sold
    2012 Audi A7 Prestige (Stasis Exhaust, Injen Intake) - Sold
    Jul 29 2017
    2018 TTRS
    Dallas
    Yeah, restricted RPM and this code showed up on my dash cam which is tied to the obII slot.
    You google it and it’s gives you a lot of potential issues. It’s not a loose wire or anything that they can clear and it doesn’t immediately come back.
    Jul 16 2013
    Ho
    Happened to once on my TTS. Not sure what caused it exactly but perhaps it was due to me changing drive select from one setting to the next too quickly then coming to a stop light and i tried taking off (no launch control). It hesitated during acceleration then that error came on. I pulled over into neighborhood, shut off the car. Did search on Google and most stated that turning off car for few min then back on would clear it. Which thank goodness it did. Car behaved normal since. I did scan with jb4 and ob11 and came back with no codes
    2018 TTRS (Nardo Gray)
    Previous:
    2018 TTS (Daytona Gray Pearl / Express Red)
    2008 TT MKII 2.0T DSG (Ocean Blue Pearl)
    Feb 20 2014
    Port Orange, FL (Daytona Bch)
    You mean like this one? Here's the situation: Did the Bikeweek parade down A1A and toward the end, this happened....never happened before....I'm wondering if the oil temp is too high? Car ran normal other than that. I pulled over after a bit of the traffic cleared and air was going through the radiators and oil cooler....stopped at gas station. Shut off car, restarted....everything back to normal. When I got home, I started the car couple times and all is normal although when I rev'd it, it would only go up to 4,000 rpms...that may be normal but first time I noticed it. BTW, that is with the warning gone and the car rev'd above that coming home after the restart.
    Current: 2022 TTRS Turbo Blue, Xpel clear bra, H&R Sport Springs, ceramic coated.
    Past: 2019 TTRS Turbo Blue, 2018 TTRS Nardo Grey, 2015 Audi TT S Competition Package & 2011 Audi TT S, Black on Black
    Remember: Hit em with the Hein!
    Senior Member Two Rings shifu22's Avatar
    Aug 28 2016
    B8-S4, MK3-TTRS
    Coquitlam
    Had something similar happen one day when playing in the snow. Turned it off. Let it sit for a few mins and then turned it back on and all was fixed. Never seen it again *knock on wood*
    B8-S4
    MK3-TTRS
    Veteran Member Three Rings mossback's Avatar
    Feb 01 2015
    2017 Subaru Outback
    United States
    Ive had this happen a few times:
    Bad 034 93 octane tune,
    Low Oil in high G corner (installed bigger oil pan) and
    Failed Ringland on 2 piston.
    2016 TTS
    Feb 20 2014
    Quote Originally Posted by GaBoYnFla View Post
    UPDATE: Code was fuel rail pressure issue...there is a service bulletin about it and a software update to fix.
    Jul 29 2017
    2018 TTRS
    Dallas
    I just got an update on mine....somehow the rocker arm attached to the camshaft is bent. 7-10 business days for the parts to come in. This is after days of replacing a laundry list of parts pursuant to the advice of Audi TAC to no avail. The dealership happened to come across this while replacing other parts.
    Who knows if this will solve the issue. Pretty disappointed for such a new low mileage car.
    Not a car guru. So maybe this isn’t a big deal but seems serious to me after searching YouTube for replacing a camshaft.
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Yeah, bent rocker arm is fairly serious. Just a risk of owning extremely complicatedly engineered and designed vehicles. Basic manufacturing margin of error, stamp out 100,000 rocker arms and some of them are going to have undetectable fatigue at the subatomic level. It's what warranty's are for.
    Sucks that it happened man but at least it's being taken care of.
    Nov 03 2014
    Mexico
    Quote Originally Posted by BetoQ5 View Post
    At first the guys at the Audi Dealership thought it could be the battery. I’ll see what it is and let you know.
    Jul 29 2017
    2018 TTRS
    Dallas
    For what it’s worth, finally picked up my RS today after a month in the shop. After replacing a bevy of parts, they discovered the rocker arm on the exhaust camshaft had fallen off. Anyways, been driving Audi’s for almost twenty years and first mechanical problem I’ve ever had and of course it had to be the one in a million kinda problem.
    Full write up in picture.
    Senior Member Three Rings Rapture's Avatar
    Dec 14 2006
    Milwaukee
    Wow, it sound like you have a very good tech there. Why a month though?
    Rapture
    2018 Audi TT RS (Gray/Black, Palomino)
    2014 Porsche C4S GT Silver (Sold)
    2011 BMW 1M Coupe AW (Sold)
    2007 Audi RS4 Lava Grey Pearl (Sold)
    2004 VW R32 Silver (Sold)
    Jul 29 2017
    2018 TTRS
    Dallas
    The initial fixes were try one thing, didn’t work, have to order parts, wait a day, try the next item. Then rinse and repeat.
    Until the discovered the real problem.
    The final part parts, the camshaft, rocker arm etc had to come from Germany. Ten business days to get those in. Took three days once the final parts came in to complete the repair.
    A majority of it was just waiting for parts.
    Established Member Two Rings Dr Bill's Avatar
    Oct 22 2010
    2019 TT-RS; 2019 Q8
    Scottsdale, AZ
    Probably some computer glitch!
    2016 Boxster GTS
    2019 TT-RS
    May 01 2016
    Central Florida
    Quote Originally Posted by Cyttorak View Post
    I going to assume that you don't have an aftermarket tune on the car. My experience on a couple occasions albeit different brands is that dealers instantly blame the tune and refuse to diagnose the issue even when it turns out to be something freakish like this that could not possibly be related to a software change.
    2023 Kyalami Green RS3
    2022 Dodge Durango SRT (Daily/Hauler)
    2015 Harley Road Glide
    2024 Aprilia Tuareg 660
    Jul 29 2017
    2018 TTRS
    Dallas
    Quote Originally Posted by HHughes1 View Post
    Yep. No engine mods or tunes of any kind. The dealership said they’d never seen anything like this on a car with so few miles on the engine.
    Jul 29 2017
    2018 TTRS
    Dallas
    Not even a week has gone by since picking up my car and a new problem as reared it’s ugly head.
    Not sure if this is related to any of the repairs made but certainly not confidence building that this is not going to be a recurring thing.
    Established Member Two Rings Sam2's Avatar
    Jan 23 2013
    Bellevue, WA
    Is your gas cap snug? Hopefully that's all it is, or they just forgot to hook up something along the evap system.
    [Ordered] Audi TT RS Nogaro Blue w/ Black Optics
    [Daily] 2005 Audi S4 Nogaro Sedan 6MT
    [Keeper] 1993 Volkswagen Corrado VR6 (Canadian)
    [Track Car] 1984 BMW 325e with Honda F20C swap
    Veteran Member Three Rings Chuckster's Avatar
    Feb 18 2017
    Socal
    I’m assuming the RS is the same as the S and we don’t have gas caps.
    2017 Audi TTS | Sold |
    2019 Audi Q7 | Baby seats |
    Jan 23 2013
    Bellevue, WA
    I would have known that if Audi didn't screw me out of a 2018. Don't mind me.
    Feb 20 2014
    Ironically, I'm getting it on my 2022 now too. It goes away after turning off the car and restarting. I'll try to get it scanned this week to see what it is.
