Results 1 to 15 of 15
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    Q5 engine shut off/start at traffic stops
    Greetings Q5 friends,
    I'm reaching out trying to get an answer for a friend of mine that has a B9 Q5. The engine shuts off and turns back on at traffic stops, which apparently you can disable, but as soon as they turn the car off and back on the setting isn't saved. Is there a way to permanently disable that engine shut off/on? I appreciate any tips/help as I don't own a Q5 myself so I'm a bit unfamiliar.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    There may be a way to do it in VCDS, but nothing openly available. Sport mode disables it.
    San Francisco, CA
    I figured VCDS might be the only way to permanently fix it. Do you know for certain that it's possible? what are the odds my friend could get a local dealership to make that coding change for him? (I can't help him out myself as I'm about 2500 miles away)
    2019 GT3 Touring
    IG: brandongray
    Apr 26 2014
    DFW
    IDK...sorry
    Jan 01 2018
    Idaho Panhandle
    This coding with ODBEleven will disable the Auto Start-Stop as long as the Climate Control system is on.
    Auto Start-Stop feature - disable
    Air Conditioning (08) > Adaptation > A/C comfort parameter for start-stop function > (default) 5 > change to new value (0 = disable start/stop)
    This tells the system that there is constant demand and so it won't turn the engine off.
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    With the B8 Q5's there is a physical button on the dash you press to turn it off. Once pressed, it does not "reset" even after each time you turn on/off the car til you press the button again to enable it.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Jul 31 2016
    PA
    Most of the new cars have it enabled by default each time you start the car, this allows them to take credit for mileage or emissions from the EPA. VCDS as stated can be used to turn it off, but it is not the same as previous models where it could be disabled once with a button and maintained that way.
    Sent from my Pixel 3 using Tapatalk
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Apr 24 2017
    Hilton, NY
    Quote Originally Posted by djn876 View Post
    Man that would drive me insane, when I had my loaner B9 A4 I experienced it. Definitely felt like the car was gonna die every time I came to a stop.
    Established Member Two Rings DonVitalli's Avatar
    Jan 21 2013
    2018 S4 B9
    Madison Wisconsin
    Disabled mine with OBDeleven. For all intents and purposes it's disabled.
    2019 SQ5, 2018 S4, 2011 S4, 2015 Mustang - Stock? What's stock?
    San Francisco, CA
    Thanks for the ODBEleven tip. Looks like that's the only/best solution (other than driving in Sport mode all the time).
    2019 GT3 Touring
    IG: brandongray
    Jul 31 2016
    PA
    I am glad that the SQ5 didn't even have that as an option, I would also probably disable it by default.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Quote Originally Posted by spindlewood View Post
    Works with Vagcom as well.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Established Member Two Rings ColeQ5's Avatar
    Aug 16 2018
    Audi Q5, BMW F650GS
    Lula, GA
    my B9 has a button to disable it.
    ...See you in the Chattahoochee Natl Forest
    2018 Q5 Ibis White Prestige
    Nov 25 2014
    Alabama
    Quote Originally Posted by ColeQ5 View Post
    The button disables it only until you shut off the car. It defaults to on when the car is started.
    The adaptation tricks the auto start-stop system into thinking the A/C is in high duty cycle and prevents it from functioning, at least as long as the A/C control unit is turned on.
    Sent from my SM-G955U using Audizine mobile app
    2018 SQ5 | Monsoon Gray | Prestige
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    OBD Eleven will do the trick. You can download the app before purchasing load look up your car and look in the garage for the pre configured adaptations to verify it is there first. You can even invert the light so when it's off there is no Amber light.
    Sent from my SHT-W09 using Audizine mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
