Originally Posted by
beefski
I have heard that changing fluid in a high mileage tranny could be asking for trouble.
Thats bullshit. I've heard that a lot and the thinking doesn't pass muster, and is generally only stated by people who don't know wtf they're talking about. I just changed my 2012 Q5's transmission fluid and filter at 65k miles and its shifts so much better now.
Do it. Do it now. Hell, you should have done it 50k miles ago. It will NOT cause any problems.
Don't get OEM fluid, get ZF Lifeguard 6 or 8, whichever they recommend for the 6-speed. Its the OEM fill, but around half the price (FCP had the best pricing when I was looking a few months back). Get a new filter as well and drop the pan and replace it. You're probably going to need 7L of fluid if you replace the filter (vs 3-4 if you just drain and refill), but a new filter a fluid will make the transmission work so much more smoothly. I changed the fluid in my Q5 for the same reasons you were stating above, hard shifting in 1-2-3, especially when cold. The new ZF fluid and Meyle brand filter made a very noticeable difference in driveability and smoothness. It also seems like the shifts are faster as well, but that could be placebo.
There is a procedure for filling it, you need to monitor fluid temps and shift through the gears. Its all outlined in a DIY on here.
