Originally Posted by
Jeff_Jeske
I've run blackstone on all of my vehicles. You won't really get a feeling for the report until a pattern forms. When I built my motor I changed the oil at 500 miles then 1000 and finally 3000. Each time the contaminates were reduced. That was a good sign. If they had gone the other direction I would know bad things were happening.
This makes sense. I plan to do my next oil change/oil report analysis at 6k. Hopefully it'll trend in the right direction. And yes, this was the original oil from the factory, changed @3.1k miles.
Thanks for the replies guys. Good to know I'm not alone in the Anal department
Here is my to do list before even considering getting a tune
1 - first oil change/report analysis - done.
2 - Get car dynoed to make sure is within stock specs & establish a good baseline - Ready for it. Can anyone recommend a good shop in the NY Tri-State area? ideally, I would also use them for future mod installs.
3 - Second oil change report analysis @6k - Fingers crossed for trending in the right direction
4 - Third oil change/report analysis @9k. Just to verify trending.
5 - Wait (Maybe) for Audi to fix the damn Limp mode off idle/Drive Train malfunction warning issue. Audi, how long will this take for Christ sake!?
