I went in to get an oil change on 12/14/2018 at 5,000 miles (I took delivery on 7/21/2018). When done the service adviser went over what was done. He mentioned rotated tires (it also shows on my invoice). I stopped him and mentioned the staggered tires on the Dynamic Package. He said that since that is the case the techs would have known not to rotate them. I assumed mentioning rotating the tires was the standard speech and that it was standard to show on the invoice as well. I believed that explanation and went on my way. I started noticing the traction control kicking in really easily and power getting pulled under light highway acceleration and heavy acceleration in dry conditions. I told myself that it MUST have been doing this since I had taken delivery and I just didn't remember. Also, it sounded like what a lot of you describe on here. Even though it really made me rethink purchasing this car at times I wrote it off as an inherent quark and was going to ask them to check things at the next service. I don't know why but this evening I thought to check my tires. Sure enough 235/35/R19 on the fronts and 255/30/R19 on the rears. I called and was just told to stop by sometime and they will re-rotate the tires.
I have some questions for you guys.
- Can this have caused undue tire wear? I'm not the type to demand a new set but maybe a discount on the next set or something if it may have caused extra wear.
- Should I be concerned about drive line components?
Also, consider this a heads up for anyone hating their car because of the frequent inability to pass the random Fusion or being made look like an idiot by a base Mustang on the highway. If you have had it in for service go check your tires.
