Results 1 to 9 of 9
    Dec 16 2018
    '13 S7, '13 RS5, '96 Mustang GT Convertible
    WA
    Normal for backup camera to continue to display few seconds after putting into drive?
    Just 3-4 weeks into my Audi ownership and have noticed on my new to me 2013 S5 that after backing up and then putting the car into drive, the display unit continues to show the backup camera for a few seconds. Is that normal? It's long enough that I can put the car in gear and start moving forward a couple/few seconds before the rear camera switches off on the display. Not a huge deal, I am just surprised at the delay.
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    I do not know regarding the time setting (I have not sat at a stop after putting it in drive) I can tell you there is a speed switch over. I think it may be around 9 mph. Thinking about it, if you are having to do a multipoint turn R and D back and forth a couple of times, the back up camera should stay on so you can see the distance/obstacles.
    Active Member Two Rings thesmoothman's Avatar
    Oct 01 2018
    My S5 does the same, I have a 6MT. Pretty sure it’s normal. Like Neil said, it shuts off after moving forward at a certain speed.
    '12 B8 S5: Phantom Black Pearl | 6MT | Sports Diff | B&O | MMI | RS5 Grille
    Dec 16 2018
    WA
    Okay thanks for the feedback. I’m just used to the camera going away as soon as it comes out of reverse with other makes. Sounds like what I’m experiencing with my S5 is normal.
    Veteran Member Three Rings SixShifter's Avatar
    May 29 2012
    York, Pa
    not only does the rear camera stay on for a few seconds after shifting out of reverse, but the audio level is also partially muted while in reverse prior to shifting to a forward gear … at least in my '13.
    Dec 16 2018
    WA
    Quote Originally Posted by SixShifter View Post
    I saw a setting where you can control the audio sound level when in reverse and mine is also set to reduce the volume when in reverse. Glad to hear from everyone that the rear view camera staying on for a couple seconds even when going back into drive is normal.
    Thanks again to all for the responses.
    Senior Member Two Rings ffearless's Avatar
    May 22 2017
    2007 Tundra, 2017 RDX
    Quincy, WA
    The speed at which it turns off can be set in VAG Com.
    Sent from my SM-G975U1 using Tapatalk
    2014 Estoril Blue RS5, loaded, 034 Motorsport X-Brace and rear anti sway bar, CR-15 strut tower brace, Ecstuning transmission and differential inserts, carbon fiber mirror housings, LED backup lights, VAG COMM mods, mid-resonator delete, true dual exhaust
    Veteran Member Four Rings BuyTheWarranty's Avatar
    Jun 11 2014
    2017 Mythos Black RS7 Performance Black Optics & Titanium Exhaust
    Normal.
    I believe you can switch this in VAG Com as mentioned above, or possible in Carista / hidden menu!
    Veteran Member Three Rings snocat17's Avatar
    May 12 2017
    2016 S5 Cab, 2016 Mazda CX-5, 2012 Ford F-250
    Steel City, USA
    I will echo the same thing, mine stays on until I get to about 9 mph. If you want it to go off faster, you can push "Nav," "Radio," or "Media" to manually get it to switch.
    I think it is a really nice feature.
    -Joe
    2016 S5 Cabriolet Prestige Glacier White Metallic w/ brown comfort seats and piano wire black wood trim. RED Brake calipers holding EBC RedStuff pads, APR Carbonio Intake, ECS carbon fiber back-pipe, VCDS cable
