Results 1 to 4 of 4
    Dec 31 2018
    phx, az
    Fuel filter location on S6
    Hi
    I am replacing my High pressure fuel pumps on my 08' S6. I figured it was a good idea to replace the fuel filters in addition to the pumps in case there is any clogging in the filter.
    Does anybody happen to know where the fuel filter is?
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    Not sure if it’s the same as the A6 but mine is right above the belly pan. I would take your pan off and check. Only takes a minute.
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
    Aug 24 2014
    Newport Beach, CA
    It's in front of the passenger size rear wheel underneath the rear of the passenger rear door. Just take that plastic undertray off and you'll see it, forewarning some of the clips on hoses that connect to it are a complete pain in the rear and very brittle. You do NOT want to break those because the lines are even more difficult to replace.
    2024 M3 Comp xDrive
    Established Member Two Rings haloguy628's Avatar
    Sep 01 2011
    Castle Pines North
    Make sure you get the right filter. The S6 has FPR built into the filter.
    Mahle KL 571 with 6.0 Bar FPR
