Results 1 to 16 of 16
    Veteran Member Three Rings GasMan's Avatar
    Jan 13 2019
    Michigan
    RS7 Wheels; Any Issue With +25 Offset?
    I am hunting around for wheels for the RS7. Currently have the 21x9 5 blades with brand new 275/30/21 4S, so I'm not looking to go much wider as I want to reuse the tires. 275 is too stretched on a 10.5, so I'm sort of stuck with 9".
    I'm not having the most success finding the exact same offset. I found a set of 21x9 et25 I liked and the supplier said the 10mm difference in offset isn't a big deal. I called and talked with my local Audi service advisor and he said something that "aggressive" might lead to premature wheel bearing failure. Now he's got me worried.
    I suppose another option if I can't find et35 would be to get something the other way, like a 38-45 and doing spacers. I know we have the lug bolts, so then there's that to consider. Or just give in and buy 10.5 with some wider tires; first world problems.
    What's the max deemed safe to run on our cars? I wouldn't mind the wheel poking out just a tad more but don't want suspension components failing on me either. This is beyond my realm of automotive knowledge.
    Thanks guys.
    2016 RS7 - Gone to car heaven
    2023 Taycan GTS
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by GasMan View Post
    Thanks guys.
    That width and offset will be perfect! (ie 9.0 and et25)
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Veteran Member Three Rings makisupa's Avatar
    Jan 30 2006
    Boston, MA
    Thanks guys.
    While I dont have a RS7, I can tell you that I run 20x10.5 et25 BBS CH-Rs on 255/35/20 pilot super sports. This is on a B8.5 Allroad. Now your SA could be right telling you that this could lead to premature wheel bearing failure. I'm on bags and SPC adjustable upper control arms and have had no issues.
    Sent from my SM-G960U using Audizine mobile app
    4.2L CFSA swapped 2013 allroad
    plus a bunch of other crap slapped on there
    Jan 30 2006
    Boston, MA
    Veteran Member Three Rings 3g_bishi's Avatar
    Mar 03 2016
    07 a6. 13 A7, 13A6, 08 A8LW12, 16A3, 15RS7
    DFW
    It will not prematurely wear out your bearings lol he’s just being “dealership like” and telling you not to
    Veteran Member Four Rings FuchsB's Avatar
    Apr 01 2012
    AZ
    Quote Originally Posted by 3g_bishi View Post
    ^^ This
    I’m running a 21x10 ET33 on 265/30/21 with no problems on an S6. IMG_0684.jpg
    Current-
    2021 Audi RS6 Avant
    2015 Cayenne Diesel
    1986 LS Swapped Porsche 944
    1973 VW Fastback
    1972 C10 3 door LS swapped Suburban on Accuair
    1970 C50 Dually Duramax build
    1968 Suburban LS Swap- For sale soon
    Established Member Two Rings Persuader's Avatar
    Mar 11 2013
    Audi A8 2019, Porsche 992 2019, Range Rover Sport HSE Dynamic 2018
    UK
    Thanks guys.
    The RS7 Blades factory are 21x9 not 21x9.5
    Sent from my ONEPLUS A6003 using Tapatalk
    2016 Audi A8 3.0Tdi Black Edition.
    2016 Audi A7 3.0 BiTDI Black Edition, RS7 Bumper/rear valance/exhaust, CF Rear Spoiler, Black Mirror Covers. Kufatec Sound Booster, DTUK Tuning Box to 360BHP.
    Veteran Member Three Rings infinitereality's Avatar
    Jul 05 2017
    Superlite Coupe (SLC) & CRF50
    Louisiana
    On my ADV.1's, I'm running 21x10 ET+22 in the front and 21x10 ET+28 in the rear. 275/30 tires are stretched, but no rubbing
    2018 Camaro ZL1 - Black
    - OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
    - RotoFab, Forgestar CF5V ZLE offsets, SP TB, Eibach Pro, AeroForce Interceptor, Black GT4 Tow Hook
    - Carbon Fiber: Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
    2019 Superlite Coupe: SLC IR/8 - Grigio Telesto
    - 525HP Crate LS3 & Graziano Transaxle
    - 19"/20" Forgestar F14s, Full Carbon Interior, Brembos
    Jan 13 2019
    Michigan
    Quote Originally Posted by Persuader View Post
    Think you read that funny, I know they're 21x9. It says 21x9 5 blades not 21x9.5.
    Thanks all! Feeling better about this.
    I think I'm set on some Vertini wheels I found yesterday. They custom make the offset so I was thinking of going 21x9 et25. I was looking at my car in the garage yesterday and the stock wheels are tucked in pretty far. That extra offset will look fantastic.
    2023 Taycan GTS
    Mar 11 2013
    UK
    Oh yeah. Sorry. My bad.
    Jan 30 2006
    Boston, MA
    Quote Originally Posted by infinitereality View Post
    Gorgeous. Well done!
    Mar 11 2013
    UK
    As long as you stick to the 275 30 21 tyre size you will be fine. I had 15mm spacers all round on my ET33 wheels (making it ET18 equivalent) and all was fine.
    Jan 13 2019
    Michigan
    After much back and forth, finally ordered wheels!
    I wanted the Vertini RF1.2 in 21x9. Asked for 30 offset, brushed titanium. Shop called Vertini to order, and they said they quit making the 21's in brushed titanium and I'd need 28 offset to clear the calipers. So we ended up doing 25 offset in brushed silver, and they'll do a double dark tint powdercoat.
    Gonna be sexy!
    2023 Taycan GTS
    May 29 2015
    Calgary, Canada
    Gonna be sexy!
    Who did you order from? I'm still shopping for a set of wheels to replace my Niche Misanos.
    I will attest to the bearings wearing out with aggressive wheels. I don't think it was *just* the aggressive wheels though as we don't have the best roads here either. Both my fronts had to be replaced at 18k miles.
    '15 RS7 | Nardo Grey | Sport Exhaust | APR Stage 2 w/ DPs | Roc-Euro Intake | Cete ASC BT Module | Niche Misano 21x10.5 | Eurocode F/R Sways +Alu Kreuz | TAG reflectors | Neidfaktor Carbon Mirror caps | 10" Alpine Type-S Sub
    May 11 2014
    Walnut Creek
    What rear diffuser do you have on there?
    Jan 13 2019
    Michigan
    Quote Originally Posted by mavpsire View Post
    The Niche Misano M116 in gunmetal were my first choice! They quit making those as well.
    I got them from John and Jason over at GetYourWheels. Both very professional and coached me through making sure this was the right call.
    https://www.getyourwheels.com/view-w...-rotary-forged
    2023 Taycan GTS
