    Mar 13 2019
    CA
    C6 allroad Brake Rotor
    hi, i have a C6 Allroad , i think the post was here, because allroad forum says only C5.
    I need to replace the rotor, and manual says is 356 mm Round ones, so, searching on web i saw those 4G8615601 with lobed or flower shape. Is a Rear disc from RS7 2014 in 356mm too,anyone knows if fit plug and play on my front axle?
    Jan 22 2012
    For now Abu Dhabi, UAE
    then you have a C7 not a C6. C6 has 347mm front rotors. If it is a rear one it wouldn't really fit your front ones as rear ones are thinner, for the front one you need 34mm thickness, rear ones are usually at 30-32mm, AFAIK, but you can easily check with ETKA.
    Mar 13 2019
    CA
    Is a 2011 C6
    I gonna to get ETKA
    thanks!
    2006 A3 8P 3.2 Sport Package S-Line Light silver [Sold]
    Milltek Exhaust
    Thypoon Intake
    2011 A6 C6 Allroad 3.0TFSI Gray Lava Pearl
    Cooming soon
    Jan 22 2012
    even if the RS7 rear one would be the correct diameter you'd need to also check the offset, different rotors have different offsets.
    yours is a C6 and front rotors are 347mm.
    Mar 13 2019
    CA
    Quote Originally Posted by mik15 View Post
    Thanks mate
    Milltek Exhaust
    Thypoon Intake
    Cooming soon
