Results 1 to 13 of 13
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    PCV, thermostat and water pump replacement
    looking for some advice here - has anyone replaced any or all 3? i'm at about 95k miles with all original parts. i've gotten an MIL 2 or 3 times in the last 12-18 months and my mechanic believes my pcv/oil separator may be the issue. in between my previous 2 oil changes, i did have to add a quart of oil (first time ever), so i'm guessing he's right about the pcv.
    since the s/c has to come off for the pcv fix, i figure i may as well get the thermostat and water pump replaced as well. from what i've read, it appears that the thermostat is a more invasive job than the pcv, but according to my mechanic, whether i do the pcv or thermostat, replacing the other part is no additional work/labor. the water pump also looks like a pain to replace, but he said that it's not, and that i can put off replacing it until it fails if i want since it's not that big a job.
    he's a legit/knowledgeable audi mechanic, so i'm wondering if he's confusing my 3.0t with the 2.0t possibly? regardless, i'm going to get all 3 done and wanted to know what other parts, while they're in there, to also have replaced. i'm thinking the breather tubes for the pcv and the serpentine belt should be replaced, but other than that, anything else i should consider?
    a part of me wants to pull the trigger on a stage 2 tune since swapping out the pulley would take them no time, but the other part of me is trying to be a responsible dad and not drive like a maniac with my 1yo in tow.
    thanks in advance for any advice!
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Senior Member Three Rings KillerQuattro's Avatar
    Dec 15 2016
    Englewood CO
    PCV and T-stat both require having the S/C off. However, the water pump can be done separately. I would address the PCV and t-stat now, since you have experienced some issues. In my case 6 months ago, I had the exact same thought when I could smell coolant when I got home from work. I really thought the pcv and t-stat would be good to do at the same time, but it was not required, and I'm glad I only addressed what I needed to at that time. Pulling the S/C for the PCV and T-stat was going to be 5 hours labor, plus the labor for the water pump and all parts, it is not a cheap service..
    The stage 2 consideration is all yours at that point, depending on what you have opted to do, and how much your wallet has left after all that.
    Good luck!
    Current: 1995 urS6 Avant. RS2 manifold, Stage 1 chip, Apikol FMIC, custom exhaust.
    Sold: 2013 Q5 3.0t- EPL Stage 2, 183mm CP, KW Coils, Eurocode Alu Kreuz, 034 inlet/AWE filter, EBC Brakes w/ SS lines, Hartmann HRS6 20x9, MF #11385 (center res) and Vibrant Ultra-quiet resonators out back.
    Sold: 2007 Ibis Avant- 2.0t 6mt, JHM HFC, TT DP, JHM HPFP, GFB+, B5 perch mod, 19x9 RS6, Hawk slotted rotors and performance pads.
    Sold: 1992 urS4- Garret 3071R, 034 tuning, RS2 goodies, 993TT BBK
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    While the supercharger is off, replace the pulley and have it ported.
    I mean. . .might as well, right? You've already got it off.
    Jun 07 2013
    orange county, ca
    Quote Originally Posted by KillerQuattro View Post
    thanks for that info, KillerQuattro! so did you replace anything else other than the parts themselves? i hear the breather tube should be replaced...can't think of anything else other than that if i'm just doing the pcv and tstat. i don't think the serpentine belt needs to come off for that either.
    as for stage 2, it's not really that much more money. $449 to upgrade from stage 1 to stage 2 with EPL's current sale, and no additional labor. i've gone back and forth with chris on so many different iterations of tcu/ecu tune, ad nauseam, and have always concluded that "i just don't NEED it!" i'm trying to stay strong and keep it that way, haha!
    Quote Originally Posted by SQive View Post
    that thought has crossed my mind, haha! another thought that has crossed my mind is to not fix anything and trade this thing in for a Q7 or RR sport!
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    I recently had the water pump on my SQ5 replaced at about 54k miles. It was leaking about a quart of coolant every 2 days. You could say that the timing was perfect as I had a ported sc being done by Evan Doel and as the sc was off the water pump, thermostat and pcv were replaced. Thermostat and pcv weren’t showing any signs of failure but I decided to replace those as the sc was off.
    Jan 11 2018
    Florida
    Jun 07 2013
    orange county, ca
    Quote Originally Posted by bajan01 View Post
    i want to say that i occasionally smell coolant, particularly when it's cold outside and the heater is blowing inside the car. assuming there's a leak somewhere, would it be from the water pump or tstat, or could it be either one?
    i really don't want these occasional fixes to become motivation to shop for a new car!
    Dec 15 2016
    Englewood CO
    Quote Originally Posted by jomama229 View Post
    Fwiw, I dont think that will be the case. The known failure points on this engine is just about what you have in scope right now, plus the crank pulley failures.. Speaking of, if you havent done the crank pulley, that may be your optimal option for stage 2 anyway, instead of the S/C pulley. 2 birds with 1 stone..
    Otherwise, there isnt a ton of other things that will leave you broke or stranded that is well documented to happen consistently. Since they are somewhat independent jobs, maybe tackle the t-stat and pcv now, and see if that fixes your coolant smell from time to time. If not, move on to the water pump next. The water pump will need to be replaced no matter what at some point so plan for it now or later.
    Veteran Member Three Rings mkasperzak's Avatar
    Jan 16 2014
    Transition Patrol Carbon, Transition PBJ, Commencal Furious
    I was at BW Performance yesterday getting my new Vors mounted to some rubber and had an oil change done while I was in. Tech noticed my coolant levels were below min and noted that it very well may be the PCV failure as there was no evidence on coolant leaking in the bay or on the belly pan. They topped me off and and asked me to keep a close eye on coolant levels. I'm at 65k and went stage 2 at 46k. BW has done a few 3.0T PCV/T-stat jobs recently and thought it was the likely cause.
    Is there a way to check and see if it is perhaps the water pump? They did not mention the water pump being another common cause. NOT too bummed as this will be the first fix for my SQ other than general maintenance and I had read this thread prior so was relatively informed.
    2014 SQ5, BBS CH-R, GIAC DP 183 Fluidampr/57 AWE SC(3.18 PR), AWE Touring, Roc-Euro, Bilstein PSS10, 034 HX/X-Brace/RSB/Inserts, Thule Edge/Flow, Kuat Trio
    Build Thread / IG @thebird_sq5
    Dec 15 2016
    Englewood CO
    Quote Originally Posted by mkasperzak View Post
    Yes. Mine was visibly weeping at the pump gasket. The factory water pump has a plastic housing that is known to fail and has been revised to an all aluminum pump... My mechanic confirmed the leak at the pump when I complained about the smell. He saw dried coolant around the pump and pump seal..
    https://www.audizine.com/forum/showt...herapy-Session
    Jun 07 2013
    orange county, ca
    i was wondering this myself. but my mechanic said, and KillerQuattro confirmed, that the water pump is a separate fix that doesn't require the s/c from being taken off...so i'm going to leave it and see the problem persists.
    same here. other than front brakes, i've had no issues with the car. all 4 upper control arm bushings appear to be worn/cracked, so that may be next, along with rear brakes. i'm just glad i've been able to find a good and relatively affordable indy mechanic close by.
    if it helps any, here's a list of all the parts i ordered for the pcv and tstat replacement. i got it thru fcp euro instead of audi livermore because of the "lifetime" warranty on parts offered by fcp euro. that being said, audi livermore prices are very very competitive for anyone looking to order from a dealer. oh, and you'll need a bottle of coolant on top of all this.
    Jan 16 2014
    Thanks, I'll go check and see if I see any dried coolant around the pump/seal.
    Big Help, they sent me an estimate already and everything looks in line except the Crankcase Vent Valve - little pricey from my shop.. i'll definitely get with them on it if I go through them.
    Jun 07 2013
    orange county, ca
    breather tube was the only item i was thinking "maybe i don't need it." but i didn't want to be penny wise, pound foolish, so $135 for a peace of mind.
    ecs tuning offers an aftermarket option at 1/3rd the price:
    https://www.ecstuning.com/Search/Sit...h/06E103217AF/
