Originally Posted by
Chaoscreature
OP,
As you are probably learning on here, there is no such thing as the "Best Tire". What you end up with is the best compromise while trying to meet your objectives :)
I like the Dunlop Star Specs for aggressive driving and a decent compromise street/track tire. The ZII is supposed to be even better, but I haven't driven on them yet.
Depending on how aggressively you drive and how rough your pavement is, those tires can last anywhere from 1,000 to 20,000 miles.
What Spinnetti says about sticky summer tires is all true as well... don't drive on summer tires below 50 degrees or so AND make sure you replace them within about 5 years of the manufacturers date regardless of mileage.
I used to have a ton of fun with Sumitomo HTR ZIII's and GTRadial UHP1's :)
Spinetti, post a review on those General tires when you get them.
Will do.. I run the StarSpec ZII now on my Lexus and they have been a great tire, but I only get a maximum of about 30hrs total run time out of a set. Thinking to switch to the RE71's and see how they do, but feedback seems to be that they won't last as long as the Dunlops.
For those that don't know, the stickier the tire, the shorter the shelf life. Actual competition tires are not rated by miles but by heat cycles, with one heat cycle being run to temp then cooling down. Typically you want to heat cycle once before you run on them, then you've only got a handful of heat cycles before they go off - usually long before the tread wears out. The top "R comps" really aren't any good more than one season regardless of tread (at least for racing). The Star Specs aren't really race tires, but closer than your average street tire. I did a track day on them after not running them for a couple years and they were undriveable.
