So I went ahead and purchased the ECSTuning magnetic drain plug. I have now had a slow drip oil leak from that plug. I removed the crush washer it came with and replaced it. The oil leak still happens. Yes I made sure both times I torqued it to spec.
Has anyone else had this issue with this? I have to go back to the stock oil drain plug because has this has now caused a couple of issues. Bottom plastics are now soaked in oil and the plug is leaking oil. Quite annoyed that this $10 part has cost me at a minimum close to $100 in oil already.
