Results 1 to 11 of 11
    Senior Member Three Rings rbish56's Avatar
    Nov 16 2018
    LSX swapped 86 cutlass 442
    chicago
    Oil Inside Turbo!?!?
    hey guys, i just put on my CTS turbo inlet pipe last night (which i love by the way) and i came across a little bit of oil inside of it. is this normal? Or is this cause for concern? it wasnt flooded with oil and the inside was not at all gunked up. just want to make sure this is normal and if it isnt then the saving for a DBV2 TBB turbo begins.
    Jul 14 2018
    Miami
    Same thing on mine, its normal.
    2017 RS3 / 2015 S3 / Instagram: https://www.instagram.com/rs3_skram
    Nov 16 2018
    chicago
    phew, that is good news! i was really worried.
    Dec 25 2004
    Earth
    Its the factory Oil fumes recirc system....black tube connected to turbo intake pipe. Normal
    Its also a reason the engine consumes oil.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Nov 16 2018
    chicago
    awesome, thank you so much for putting my mind at ease! even though the thought of going DBV2 wasnt sounding too bad, haha.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Slightly off topic. How hard is it to pull the PCV hose off to install the turbo inlet elbow?
    -cW
    Sent from my SM-G965U using Tapatalk
    2023 X3 M40i Alpine White
    Dec 25 2004
    Earth
    -cW
    http://bd8ba3c866c8cbc330ab-7b26c6f3...inlet_pipe.pdf
    Nov 16 2018
    chicago
    -cW
    I found it VERY easy to take off and put on. I took out the bolt first then off with the hose. Took me about 10-15 minutes. Also, I just changed the plugs today! All the plugs were tight except #4 that plug seemed very loose. Hope that helps ya out
    2016 S3 UM ecu, tcu and haldex tuned. APR down pipe, Unitronic intercooler, dogbone insert, 034 turbo muffler delete and cts turbo inlet pipe.
    Nov 16 2018
    chicago
    Oops disregard the spark plug comment. It was cool running who was wonder, not cool water. My bad haha
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Thanks for the link. Looks like just a small screwdriver is needed. I’m guessing once the airtight seal is broken, like a Snapple bottle it just pops right off...
    -cW
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by rbish56 View Post
    Thanks and good to know. I will give it a shot this weekend.
    -cW
