I have the price and financing locked in along with extended warranty quotes from both Fidelity and Audi Pure Protection from Troy.
My few questions are as follows:
- What should I be looking for on the car? I scanned the car with VCDS and found one fault code that caused me concern (see attached)
- What extended warranty is best? Fidelity or Audi Pure Protection? I know Fidelity used to underwrite Audi's extended warranties but now it's SafeGuard under their new plans. What gives the best coverage? Looking at the top tier plan from both companies.
- Has anyone with either of the warranty companies above had their turbo failure covered by their respective warranty company? If so, which company did you have?
- Has anyone had any air suspension issues with their S6's? If so, did your extended warranty cover it?
- Has anyone with the Lunar Silver interior actually had staining on the seats? I don't see any staining on my current S4 with the Lunar Silver middle seat inlays.
- The car comes with winter tires on it's stock 20" wheels. I'll be in need of summer tires come spring and a second set of 20" wheels - does anyone have a good affordable source for proeprly specced 20" wheels for a winter set?
Here's a link to the car for those interested: https://www.cars.com/vehicledetail/d...1641/overview/
I have the dealer waiting for my decision to pull the trigger or pass tomorrow evening.
Any help you guys can provide is greatly appreciated.
EDIT: Wouldn't let me upload the log text file so I'm copying it in here...
Code:
Monday,04,March,2019,18:58:14:56203 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 18.9.0.2 (x64) Data version: 20180927 DS296.0 www.Ross-Tech.com VIN: WAUFFAFC1HN123611 License Plate: S6 BMW DEALER Mileage: 60079km-37331mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FC-AU57 (4G8) Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42 44 46 52 53 55 5F 62 6C 72 85 8B 8E 8F 90 A9 BA VIN: WAUFFAFC1HN123611 Mileage: 60079km-37331miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1B-Active Steering -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 22-AWD -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 3B-Sensor Elect. -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 85-On Board Cam. -- Status: OK 0000 8B-Adaptive Cruise 2 -- Status: OK 0000 8E-Image Processing -- Status: OK 0000 8F-Pretens. Frt Left -- Status: OK 0000 90-Pretens. Frt Right -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 BA-Motor Mounts -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (------CTGE) Labels:. 06E-907-551-CGW.clb Part No SW: 4G0 906 014 D HW: 4H0 906 014 Component: 4.0l V8TFSI / H63 0002 Revision: NCH63--- Coding: 0A2500326546010E3000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ECM40TFS0114G0906014D 001002 ROD: EV_ECM40TFS0114G0906014D.rod VCID: 23458E6E2A0E7352E8-8076 1 Fault Found: 16629 - Camshaft Adjuster B Cylinder 8 P12B7 00 [096] - Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb Part No SW: 4G0 927 166 F HW: 0B5 927 156 K Component: 0B5 40TFSINAR H06 0007 Revision: --H06--- Coding: 000001 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_TCMDL501021 001022 ROD: EV_TCMDL501021.rod VCID: 306F71226BF8D8CA65-8064 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb Part No SW: 4G0 907 379 S HW: 4G0 907 379 S Component: ESP9 Premium H01 0530 Revision: -------- Serial number: -------------- Coding: 65BED449A67D2B921B00 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ESP9BOSCHAU57X 004018 ROD: EV_ESP9BOSCHAU57X.rod VCID: 418924E6D05241429A-8014 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR Component: BCM2 2.0 H61 0825 Revision: 00002001 Coding: 0DA86F4E000000000000 Shop #: WSC 02391 785 00200 VCID: 000FE1E293D8884AD5-8054 Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C Component: J764 ELV MLB H40 0046 Serial number: 3217000058917005 1 Fault Found: 00955 - Key 1 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 35 Mileage: 58399 km Time Indication: 0 Date: 2019.01.27 Time: 11:36:44 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL Component: KLIMA 4 ZONEN H14 0113 Serial number: 10041700041548 Coding: 688130B84D0000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiComfoUDS 003008 ROD: EV_AirCondiComfoUDS_003.rod VCID: 6ADBA34A8DA4621A6B-803E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: Redir Fail! Part No SW: 4H0 907 063 GM HW: 4H0 907 063 AM Component: BCM1 2.0 H20 0368 Revision: 2102003S Serial number: 00001634331101 Coding: 01050011043C9FF2F90048C780003800CF9CD208AE08022180000894F10017020060002D0B0000 Shop #: WSC 02391 785 00200 VCID: 79F98C06F002D98292-802C Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB Component: WWS57X 170305 H38 0080 Serial number: 170308122743 Coding: 0045F7 Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547 Component: G397_RLFS H06 0002 Serial number: 20190312X81A955547A0 Coding: 02006D Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL Component: E1 - LDS H07 0044 Serial number: 04 04 2017 00000160 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Serial number: 00000000095Z02D5F883 Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C Component: EVLS-SG H08 0300 Serial number: WA127128000031315783 Coding: 020300 Subsystem 6 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B Component: AQ_Hum_Sensor H01 0006 Serial number: 1F384C9800PAG0MUFU03 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb Part No SW: 4G0 907 561 B HW: 4G0 907 561 Component: ACC3 H21 0055 Serial number: 00000000000000 Coding: 7E01010102 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContrAU57X 002015 ROD: EV_AdaptCruisContrAU57X_002.rod VCID: 29599C464822A902A2-807C No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 4H0-959-655.clb Part No SW: 4G0 959 655 B HW: 4G0 959 655 B Component: Airbag10.43 H62 0092 Revision: -------- Serial number: 003G00040A0X Coding: 303331343135303334354A55304C34473053 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirbaAU10BPAAU64X 001014 ROD: EV_AirbaAU10BPAAU64X_VW51.rod VCID: 34677D329FE0E4EA01-8060 Seat occupied recognition: Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B Component: BF-Gewichtss. H10 0046 Serial number: 6940000Y170001L58T0$ Crash sensor for side airbag: driver side: Serial number: 3575HRB404V4D4QC78HX Crash sensor for side airbag: front passenger side: Serial number: 3585HRB40653MROKD0G1 Crash sensor for side airbag: rear: driver side: Serial number: 3515JRB400A599TUJ1U2 Crash sensor for side airbag: rear: passenger side: Serial number: 3525JRB401059716E0PF Crash sensor for front airbag: driver side: Serial number: 3554VRB401A59HKIIA9Z Crash sensor for front airbag: front passenger side: Serial number: 3564VRB400O59GF2P9G/ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4H0 953 568 H HW: 4H0 953 568 H Component: Lenks.Modul H05 0005 Revision: -------- Serial number: 90372QD3000JZ Coding: 0004FC Shop #: WSC 02391 785 00200 VCID: 387F49028B88008A2D-806C Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E Component: E221 - MFL H08 0010 Serial number: 17 02 2017 D0038572 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1 Part No SW: 4G0 920 982 S HW: 4G0 920 982 S Component: TBenUsaAccNv H15 0225 Revision: 15001309 Serial number: 658060417596019 Coding: 0BC70905BF51D705020200 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RBD4K 004060 ROD: EV_RBD4K.rod VCID: 3C775512B7B02CAAC9-8068 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 4G8 907 468 H HW: 4G8 907 468 Component: J533--Gateway H15 0096 Revision: -------- Serial number: 00000002573164 Coding: C0ED074814 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_GatewPkoUDS 002000 ROD: EV_GatewPkoUDS_002_AU57.rod VCID: 3D715816ACAA25A2FE-8068 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B Component: J367-BDMHella H10 9070 Serial number: 0484723504 Voltage stabilizer: Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F Component: J532_DCDCStab H23 0022 Serial number: 170120000000000007B8 No fault code found. ------------------------------------------------------------------------------- Address 1B: Active Steering (J792) Labels: None Part No SW: 8K0 907 144 N HW: 8K0 907 144 N Component: DYNAMIKLENK. H06 0740 Revision: 52001005 Serial number: -------------- Coding: 0E0100 Shop #: WSC 02391 785 00200 VCID: 3A7B530AB584129ADB-806E No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels: None Part No SW: 4H0 857 511 HW: 4H0 857 511 Component: FLA H04 0021 Revision: AA001002 Coding: 04018264747464545425363E00 Shop #: WSC 02391 785 00200 VCID: 67DDDA7E96B65F7274-8032 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels: 4H0-907-163.clb Part No SW: 4H0 907 163 B HW: 4H0 907 163 A Component: 4 Wheel Drive H19 0200 Serial number: 000604170001001 ASAM Dataset: EV_AllWheelDiffeQSPFR 003026 ROD: EV_AllWheelDiffeQSPFR.rod VCID: 285F99425328900ABD-807C No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb Part No SW: 4G0 919 158 R HW: 4G0 919 158 R Component: KLIMA FOND H08 0113 Serial number: 07041700041039 Coding: 20 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ClimaContrUnitRearUDS 003004 ROD: EV_ClimaContrUnitRearUDS_003.rod VCID: 3E735F1AA1AC3EBAE7-806A No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control (J197) Labels:. 4G0-907-553.clb Part No SW: 4G0 907 553 G HW: 4G0 907 553 F Component: LUFE-DAEMPFER H19 0783 Coding: 008006 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirSuspe 003025 ROD: EV_AirSuspe_VW51.rod VCID: 2F6D725E76C6C7327C-807A 1 Fault Found: 403200 - Function Shut-Off Active C10C8 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 149 Date: 2000.00.00 Time: 00:00:00 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4G8 959 760 HW: 4G8 959 760 Component: MEM-FS H03 0157 Revision: AA000000 Serial number: 00000249003276 Coding: 00581B0000006001000001010101102030303232203232 Shop #: WSC 02391 785 00200 VCID: 77FD8A3EC616CFF2E4-8022 No fault code found. ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb Part No SW: 4G0 907 637 L HW: 4G0 907 637 G Component: SARA 6D red H04 0056 Revision: -------- Serial number: EJ1BPA7E02RSYK Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SARA2 005012 ROD: EV_SARA2.rod VCID: 377D4A3E8E960FF224-8062 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb Part No SW: 4G0 907 566 M HW: 4H0 907 566 F Component: SWA Master H08 0070 Serial number: 0437050326 Coding: 040211 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_LaneChangAssis 001028 ROD: EV_LaneChangAssis_AU21.rod VCID: 39794C06B8821982D2-806C Lane Change Assistant 2: Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F Component: SWA Slave H08 0070 Serial number: 0437561974 Coding: 040211 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 4G8 959 793 H HW: 4G8 959 793 F Component: TSG FA H04 0511 Revision: -------- Serial number: -------------- Coding: 011F17015E00628002000013 Shop #: WSC 02391 785 00200 VCID: 458130F6CC7A6D62A6-8010 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q Component: RCevo H54 0202 Revision: 00000001 Serial number: 0000703367 Coding: 011001010001 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RCEPS 106007 ROD: EV_RCEPS_106.rod VCID: 3A7B530ABD84129ADB-806E No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR Component: BCM2 2.0 H61 0825 Revision: 00002001 Serial number: 0438659932 Coding: 0106063A00FA408580B0088402070E470000000000000000000000000000 Shop #: WSC 02391 785 00200 VCID: 000FE1E293D8884AD5-8054 Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719 Component: GTO BF H01 0081 Serial number: 00000000000000393502 Subsystem 2 - Part No: 1K0 951 605 F Component: LIN BACKUP HO H01 0008 Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A Component: J245 PS40.402 H03 0004 Serial number: 0000FST001J9SO900000 Coding: 101F02 Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135 Component: Dachelektroni H10 0100 Serial number: 0000000AP00032101492 Coding: 010000 Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D Component: GEB.F.Heckoef H16 0811 Serial number: 6600316? No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 4G8 959 792 J HW: 4G8 959 792 G Component: TSG BF H03 0511 Revision: -------- Serial number: -------------- Coding: 011F17015E00628002000002 Shop #: WSC 02391 785 00200 VCID: 468337FAF17C667AAF-8012 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 M HW: 4H0 907 801 M Component: EPB-4 H01 0018 Revision: -------- Serial number: 00000002165399 ASAM Dataset: EV_ParkiBrake 001033 ROD: EV_ParkiBrake_VW51.rod VCID: 326B7B2A65F4EADA13-8066 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb Part No SW: 4H4 907 357 E HW: 7P6 907 357 B Component: MxB-ECU 001 0100 Revision: -------- Serial number: -------------- Coding: 04FA0A1122600400 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009 ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod VCID: 34677D329FE0E4EA01-8060 Led Headlamp Powermodule Left: Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB Component: LED LeiMo li. H07 7560 Coding: E01E00 Led Headlamp Powermodule Right: Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB Component: LED LeiMo re. H07 7560 Coding: E01E00 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb Part No SW: 4G1 035 025 D HW: 4G1 035 025 C Component: MU-H-LNS-US 053 0902 Serial number: A741D0H7535971 Coding: 017551020000000013220002041A00102F0007E5F17001047E Shop #: WSC 02391 785 00200 ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115 ROD: EV_MUHig6C3Gen2HBAS_AU57.rod VCID: 1F4D829E066657B2CC-804A Data medium: Subsystem 1 - Part No SW: V03 959 801 GH HW: ----------- Component: NAR 2017/2018 --- 0060 Serial number: -------------------- Display unit 1 for multimedia system: Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B Component: DU8 C7 SV H63 0007 Serial number: AUZ8Z9HY807QK3 Multimedia Operating Unit: Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F Component: E380 BDT C7 H20 0250 Serial number: 90349QD40006F Compact Disc Database: Subsystem 4 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote2--- --- 3011 Serial number: -------------------- No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HL H03 0511 Revision: -------- Serial number: -------------- Coding: 010F17004000628002000002 Shop #: WSC 02391 785 00200 VCID: 49993CC6E062890242-801C No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4H0 907 428 E HW: 7P6 907 441 G Component: TopView H09 0380 Revision: 11001001 Serial number: 82330JG0394023 Coding: 0212000101010000000102000000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_CamerSysteTopViewAUDI 008028 ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod VCID: 2F6D725E76C6C7327C-807A No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HR H03 0511 Revision: -------- Serial number: -------------- Coding: 010F17004000628002000002 Shop #: WSC 02391 785 00200 VCID: 49993CC6E062890242-801C No fault code found. ------------------------------------------------------------------------------- Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb Part No SW: 4H0 907 217 F HW: 4H0 907 217 A Component: DPC-SG H28 0081 Revision: -------- Serial number: 262130025421000 Coding: EA060000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_OnBoardCamerDPC 001007 ROD: EV_OnBoardCamerDPC.rod VCID: 2C57655247D0BC2A59-8078 No fault code found. ------------------------------------------------------------------------------- Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb Part No SW: 4G0 907 541 B HW: 4G0 907 541 Component: ACC3 H21 0055 Serial number: 00000000000000 Coding: 7E01010102 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContr2AU57X 002013 ROD: EV_AdaptCruisContr2AU57X_002.rod VCID: 275D9A7E5E369F72B4-8072 No fault code found. ------------------------------------------------------------------------------- Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb Part No SW: 4H0 907 107 H HW: 4H0 907 107 Component: BV-SG H34 0090 Serial number: 005002450604177 Coding: 04C1BA1B0111 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_BC7 001001 ROD: EV_BC7.rod VCID: 2C57655247D0BC2A59-8078 No fault code found. ------------------------------------------------------------------------------- Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 945 B HW: 4H0 980 945 C Component: RGS-VL H16 0080 Coding: 0066E608031F0376070308014240C0010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_L 002004 ROD: EV_RGS_L.rod VCID: 3169742660F2D1C26A-8064 No fault code found. ------------------------------------------------------------------------------- Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 946 B HW: 4H0 980 946 C Component: RGS-VR H16 0080 Coding: 0066E608031F0376070308014240C0010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_R 002004 ROD: EV_RGS_R.rod VCID: 326B7B2A65F4EADA13-8066 No fault code found. ------------------------------------------------------------------------------- Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb Part No SW: 4G0 907 159 B HW: 4H0 907 159 A Component: SAS-GEN 2 H06 0010 Serial number: 170307200399 ASAM Dataset: EV_SoundActuaGen2AU64X 003010 ROD: EV_SoundActuaGen2AU64X.rod VCID: 2C57655247D0BC2A59-8078 No fault code found. ------------------------------------------------------------------------------- Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb Part No SW: 4H0 907 145 B HW: 4H0 907 145 Component: AEM - LEAR H10 0008 Revision: 00001001 Serial number: 97813008241001 ASAM Dataset: EV_AEMLearAU64X 002016 ROD: EV_AEMLearAU64X_AU57.rod VCID: 285F99425328900ABD-807C No fault code found. End-------------------------(Elapsed Time: 07:00)--------------------------
