Results 1 to 18 of 18
    Dec 28 2017
    Poland
    Exhaust cutout/bypass/valves
    Hello,
    I want to buy a vacuum or electric valves for my S5.
    I just want to know, where to weld it and which valves are better/more durable (electric vs vacuum)?
    Senior Member Two Rings ffearless's Avatar
    May 22 2017
    2007 Tundra, 2017 RDX
    Quincy, WA
    Do you really want to do this, or would installing RS5 mufflers be a more elegant and acceptable solution? I see them relatively inexpensive on eBay occasionally.
    2014 Estoril Blue RS5, loaded, 034 Motorsport X-Brace and rear anti sway bar, CR-15 strut tower brace, Ecstuning transmission and differential inserts, carbon fiber mirror housings, LED backup lights, VAG COMM mods, mid-resonator delete, true dual exhaust
    Nov 03 2016
    CA
    Quote Originally Posted by ffearless View Post
    I don't think RS5 mufflers will give the sound OP is looking for.
    2011 Audi S5
    (GONE) 2011 Audi A5 2.0T [APR STAGE 2] [034 MotorSports HFC]
    Veteran Member Three Rings mikedizzzo's Avatar
    Nov 03 2016
    So Cal
    Quote Originally Posted by brilliant_black View Post
    OP never said anything about sound.
    -MikeDizzzo
    2016 S5 Premium Plus | Florett Silver | Black Optic Plus Package | DSG | ADS | Carbon Atlas | B&O
    Mods: GIAC Stage 2 | TCU | SC Pulley | Bilstein B16 Ride Control Coilovers | AWE Touring Exhaust 90mm | Maxton V1 Front Lip | 034 Transmission Insert | Brakes - Hawks Pro with slotted/dimpled rotors | Relak Paddle Shifters | Ceramic Pro 9H | LED interior | 2 x Audizine 5' stickers | Audi All Weather Mats
    Dec 28 2017
    Poland
    Yup, it is all about the sound ;)
    Veteran Member Four Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 Prem Plus; '13 Q5 Prem Plus S-Line; '09 Honda Odyssey (The Wife's, in the driveway)
    CO
    Quote Originally Posted by Silv3r View Post
    There are fully configured exhaust systems for the S5 with that capability. RCP Exhausts is one example and is made in Poland (Gdansk). I love the sound of their system.
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optic Plus, B&O, Adaptive Damping Suspension. 034 Stage 2 ECU/TCU, RS5 grill, AWE S-FLO Intake, 034 X-Brace, 034 Rear Sway Bar, CR-15, Magnaflow non-resonated X-Pipe
    2013 Q5 Prem Plus S-Line, Moonlight Blue Metallic, 034 Stage 1 ECU/TCU
    Dec 28 2017
    Poland
    It is my daily car and I like the stock exhaust's sound (my wife and small baby as well) but from time to time I want to hear the V8 ;)
    Feb 02 2018
    CO
    One of my employees is regularly in Poland (he's there now) and has an overnight layover in Gdansk each trip. I keep jokingly telling him he needs to pack up an exhaust system from RCP for me and take it home in his bags. :-)
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    If you're doing exhaust dumps and want to hear it without it being too loud, you'll want to add the dumps just before the rear mufflers. If you have an Instagram, message me on there (@Sazexa) and I can send you a video of what a muffler delete sounds like. You'll get an idea of what dumps would sound like. Dumps/cut outs are cool but when you add them like this, usually the only place to direct the sound is right down to the ground and sometimes that sound echos back and makes a little extra noise/drone while the cut outs are open.
    On the other hand, the muffler delete in general is not that loud and I would by no means call it too loud for a daily. I've tried several exhaust set ups, right now I'm running no middle or rear mufflers, but factory cats and resonators. I can send you a video of either if you're interested.
    - - - Updated - - -
    Also, aftermarket solutions with cutouts built in are typical VERY expensive by comparison to a regular aftermarket exhaust... Which in general is usually over priced if you ask me.
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    The only logical solution here is to sell the wife and baby, use the funds to buy a proper high-end valved exhaust.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Feb 02 2018
    CO
    Quote Originally Posted by HazeMyth View Post
    Seconded.
    Dec 28 2017
    Poland
    Well, I tried to find a place where to place the cutouts but there is not too much place left :(
    Based on YT ppl used to place it here:
    Any other recommendations?
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    I have a 2008 Audi TT 3.2 and I installed the valve pictured in OP with the black motor boot. I know its a different motor but loudness should be similar
    I did pre-res delete, mid res swapped for magnaflow, rear muffler is OEM box
    I installed dump valve right before the rear muffler. Its electronically actuated with a remote. When closed its fairly quiet to go under the radar. When open its very loud but sounds great! You really hear that VR6 growl and it turns a lot of heads driving by. I could see it getting annoying on long drives or with company/wife in the car but that's the beauty of being able to close it when travelling with others who do not appreciate the volume level. Personally I drive with valve open nearly 80% of the time even in my 45 min commute
    Only negative I see is the motor might eventually fail. They are cheap enough I bought a spare. Also the flap has a tendency to vibrate when closed at idle which is annoying but it goes away when opened.
    Currently
    2015 Audi Q5 3.0TDI S-Line, Malone stage 2 with Deletes
    Previous:
    -2013 Audi S4 3.0T S-Tronic Teknik
    -2010 Audi S5 4.2L 6MT
    -2008 Audi TT 3.2L S-Tronic
    -2007 Audi A4 3.2L S-Line 6MT
    Dec 28 2017
    Poland
    I've bought the vaccum valves which I hope are more durable but a little bit bigger than the electronically actuated.
    It is not good as I do not find any suitable place to place it :/
    Veteran Member Three Rings SSSSS5's Avatar
    Apr 16 2018
    '85 300TD, '85 500SEL, NA MIATA, Merkur XR4Ti, '99 Cactus Avant, '10 S6, GX470, '16 Outback
    Bangor. ME
    I just bought ECS tuning's bypass setup. I plan on putting the cutouts where the center resonator used to be. Plenty of room there.
    -Casey @CaseyCactusV10 | 1999 Cactus Green B5.5 A4 Slicktop + V10 + 0A3
    Active Member One Ring Kerber Inc.'s Avatar
    Mar 27 2019
    Bay Village, OH
    I just did this to mine a few weeks back. Love the sound (although mine are on an C7 3.0T so yours will be a little better) and was deffinetly worth the money. Like you said I had the center "suitcase" muffler deleted and put the cutouts in its place. I had a local shop weld mine in and they did custom bent pipe from the cats back. For the vacuum source I tapped onto the brake booster line as it's a constant supply of vacuum but you may not receive the initial rev of the engine turning on as the vacuum hasn't built just yet. All said and done all the parts and exhaust work cost around $1000. If anyone has any questions feel free to PM me and I'll do all I can to help!
    Kerber
    Apr 16 2018
    Bangor. ME
    Looks great Kerber! I'm surprised they actually take up most of that space for the resonator. I want to keep mine at an angle, to avoid two 90 degree turns like you have. Looking at yout photos, I am not sure its possible. Minus just using a boost tap, I'll have the same setup beginning of next month.
    Mar 27 2019
    Bay Village, OH
    Quote Originally Posted by SSSSS5 View Post
    The exhaust shop I went to couldn't find a much better way to fit them in unless you move them in front of the cats and move the cats down the line some where. One thing I would suggest with the boost tap is that it won't give you a constant vacuum as when the engine is at a higher RPM the intake vacuum goes down thus closing the valves ever so slightly. It should still work but it's just as easy to tap onto the vacuum pump. If you want a photo on how I did mine LMK. Also here's a video of how it sounds
    Kerber
    2012 A6 C7 Mods: ECS Cutouts | 034 Trans. and Drive train inserts
    CLE native | First time Audi owner
