I’m dealing with this right now too. It’s the drivers side cover (where the sub is). Forward left corner of the grill literally bounces up and down on the rear deck. I had the dealer look at and they put some felt tape under the grill which helped but didn’t stop the problem. I even showed them an A4 B9 TSB that addresses the issue and asked them to perform it on my car. They gave me “that’s for an A4 not an A5” repsponse and used their felt tape on it. I also had them look at the passenger door speaker because it was making errant noises too. They wound up replacing the speaker in its entirety.
It’s been about 3 weeks since they did their work but the sub still rattles over about 1/3 volume. I’m taking matters into my own hands and have ordered the foam tape called for in the A4 TSB. It’s readily available from dealers and ECS tuning.
I have also found that the center dash speaker will make some noise. I have a very early build car and discovered Audi has since added a full layer of felt under that grill. I bought the new part number for around $35 and the problem was solved. Also, pay close attention to the lower door speaker grills. I’m still getting an occasional rattle from the passenger side that I think is the grill. My gut says the speaker replacement was needless. I’m going to start messing with that grill this weekend.
I’ve been in this car for about 6 weeks now and the build quality is nowhere near as solid as my prior A5. I gave my 2013 A5 with B&O to my daughter and have regretted it more than once. I’ll get over the hump eventually with this car, but breaking her in is way more work this time around.
Here is a link to the A4 TSB and the Foam Tape I ordered:
TSB:
https://testing-public.carmd.com/Tsb...111005/A701652
Foam Tape:
https://www.ecstuning.com/b-genuine-...ip/8e0831575a/
Good luck
