Results 1 to 40 of 67
    Dec 26 2018
    Norwalk, CT
    FreedomPop SIM card, which do I get?
    Hello, I have tried to research this myself but am getting conflicting results. I have a 2015 Q5 3.0T with Nav/bluetooth/back-up cam. It does show bluetooth (connected) and 2G (greyed out). I'd like to get a SIM card to be able to use Google Maps. If I'm not mistaken I need a FreedomPop SIM for t-mobile since going to Tel/Settings/DataConnection/StartAutomaticConfiguration it shows APN - "m2m.t-mobile.com" but under Software Version it shows: HN+_US_AU3G_P0814
    I'm confused, do I have 2G or 3G????
    Which SIM card do I get? Any links would be much appreciated.
    Established Member Two Rings Mythdoc's Avatar
    Jan 28 2017
    Knoxville, TN
    Your car receives 2G and 3G. And yes, a FreedomPop sim works on the GSM protocol which will work with your vehicle.
    2024 A5 Prem+ Chronos Gray/Black
    Former:2021 A4 allroad Prestige Glacier White / Okapi Brown, JB4
    2015 Q5 TDI, Chipwerke, RSNav
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    yup just got one its a 4g card and works fine on my 3g system 2014 SQ5 just about to finish up the trial an downgrade to the free version. I think you need to have a $20 hold though to switch to the free99 one
    ordered directly from freedompop so it came pre activated.
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Dec 26 2018
    Norwalk, CT
    Quote Originally Posted by Mythdoc View Post
    Quote Originally Posted by ILVTRANCE View Post
    Thanks for your help! Ordering one now =)
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I went through this and ultimately ditched the “free” version. But primarily because I was going to incur a $3.49 per month fee by the city of San Francisco. Instead I ordered a prepaid 1 year card that provides 1GB per month for $45 on amazon (ie less than $4 per month).
    I had $27 into the “free” experiment anyways... (1 cent card, 9.99 shipping, $10 top up to downgrade, 2x 3.49 monthly charges). The prepaid card eliminated the song and dance of the “free” service for a nominal fee, in my opinion. I got them to refund the $10 top up but had to ask several times. I have been exceeding the 200mb cap each month, which would have caused even more fees.
    Any freedom pop 4g lte card (with voice/data or just data) works with the 3g+ mmi (except some 2013’s and earlier with incompatible modems).
    Junior Member One Ring
    Feb 07 2018
    Beaverton, OR USA
    Hi all,
    Does anybody know if this is an option for the MY18 SQ5? Read somewhere it doesn’t use SIM cards for the current AT&T setup.
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Quote Originally Posted by Boriaudi View Post
    Hi all,
    AT&T's network is GSM; therefore, a SIM is required. The B9 does use a SIM card, it's just not accessible and replaceable as on the B8's.
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    Feb 07 2018
    Beaverton, OR USA
    Thanks for the info. Does than mean I only have ATT as an option? The car does have an empty SIM slot in the glove box.
    Sep 07 2018
    Colorado
    The only option you have in the B9 is to sign up with Audi Connect
    Active Member One Ring rev_jim_jones's Avatar
    Feb 01 2019
    mendocino ca.
    My 2013 3g mmi + did not work with freedompop sim, unless i did something wrong. I had to use a t mobile sim.
    Established Member Two Rings Carbines's Avatar
    Mar 14 2012
    Warrenton, VA
    Quote Originally Posted by PNW Avant View Post
    Any chance you can share a link to that SIM? I'm looking to do exactly what you did, but admittedly, i'm not up to sped on all of the nuances of GSM SIMs nowadays.
    Also was there any type of activation process that you had to do to get it to work in the car?
    Any APN settings we need to change in the car?
    I appreciate the help if you have the time!!!
    Feb 15 2007
    Is it worth it for $14 (3-in-1 SIM kit and shipping)?
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by Carbines View Post
    Looks like amazon is sold out, but target also sells it.
    You need to update the APN settings to what freedompop says to use in the box.
    Then you also need to activate audi connect to get the audi connect features. This just involves creating a free account, adding your VIN, and retrieving the audi connect pin from their site. No additional or on-going fees. There is a thread in the B8 A4 forum that walks through the process. I'll find the link.
    Quote Originally Posted by zachf88 View Post
    I don't think its worth $14 for the free SIM - gets you 200MB a month, and you have to pay $10 to "downgrade" to the free service. THEN you have to watch your usage to make sure you don't exceed to the 200MB per month. It started to feel like a song-and-dance to prevent them charging my card every month so i canceled and went with the prepaid.
    If you are going to pay 20-something, I'd go all the way to the $45 full year SIM.
    The features you get are: 1) google maps overlay to your nav and 2) Audi Connect features (the primary useful feature of which I think is the "send to car" for address input via the audi app. Much better than the MMI typing interface).
    I guess you used to get google street view for your destination but that doesn't work anymore. And the googlemaps overlay is supposed to be dead in 2020, too.
    May 08 2018
    San Diego CA
    I've been looking into getting one for my 16 SQ5. I found prepaid ones for $40 at Best Buy. When you mention creating a free account, you mean with FreedomPop, or Audi Connect?
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    The free account (to get your Audi connect pin) is www.audiusa.com/myaudi#/
    The only thing you need to do at freedom pop is activate the sim.
    Freedompop also has a “free” service which provides 200mb per month for no cost. But there are some hidden fees and such. I don’t recommend it, after trying that route for 2 months.
    Mar 14 2012
    Warrenton, VA
    Thanks much for the information! By the time I saw your reply, Amazon had restocked, and I’ve got that SIM coming tomorrow. I’ll follow the directions for the APN settings.
    I’m hoping that my AudiConnect is still valid - I activated the free 6 month trial after buying the car.
    Again, many thanks for helping us all out in this thread!
    //carbines
    Senior Member Two Rings TheSchwa's Avatar
    Mar 08 2013
    B9 SQ5, 25quattro #99
    Bellevue, WA
    Quote Originally Posted by 2018_SQ5 View Post
    For now... Several features go away Dec 31, 2020. They're blaming a Google update and hardware incompatibility, but I have a feeling it's a licensing thing.
    B9 SQ5 / Monsoon Gray / Prestige
    25quattro #99/250
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    //carbines
    Remember Audi connect is FREE once you have the freedompop sim (on Mmi 3g+). The Audi connect pin is retrieved in myaudiusa with a free account and your VIN
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Def. agree that if you can can monitor your usage, the 200MB "Free" plan is not bad at all.
    When I initially bought my SIM I did the $.01 promo for the "3 in 1" LTE card, but didn't realize that to downgrade my plan to the free one you have to add "Top Up" credits. Also to take some features off you gotta add others, so you end up getting charged immediately for stuff you don't even use.
    My initial break down was:
    $.01 - Initial Setup Fee
    $6.99 - Safety Mode F-Up
    $3.99 - Data Rollover F-Up
    $20 - Top Up to Downgrade
    All in all, the $9.99 total of screw ups on my part could have probably been avoided. But it was just a $10 mistake, since Jan. when I signed up I have not been overcharged etc. However I only enable my SIM when I need it, which hasn't been at all because I haven't been traveling.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I believe the $6.99 "safety fee" is a monthly recurring fee. This is something that has changed over the last year or so. Have you checked that?
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by rev_jim_jones View Post
    Only certain 2013's worked. They changed the modems in the 2013 MY to enable att. There's a replacement modem you can get, I believe.
    Apr 24 2017
    Hilton, NY
    Since I was initially charged the one time I have not been charged again and it's been about 2+ months since.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I would check your account. They might be eating through your $20 downgrade credit.
    Its advertised as a monthly fee. Some users used to report the ability to enable saftey mode, disable top-ups, and then re-disable safety mode and the disabled top ups would stay disabled. But others struggled recently.
    "FreedomPop offers a new service called Safety Mode for $6.99 per month"
    May 08 2018
    San Diego CA
    Just so I know I got this right. Buy this:
    https://www.amazon.com/FreedomPop-Le...ireless&sr=1-1
    Then go onto my AudiConnect account and retrieve the pin. Input the pin, etc. into my MMI and then should be good to go for a year? At 1GB a month?
    Apr 24 2017
    Hilton, NY
    I checked my "Services" section where the Safety Mode is added/disabled and have nothing selected, literally says "No Services Found". My top up credits were un-touched, albeit they expired but none of it was used for anything.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by choppstixxx View Post
    Interesting. For your credits, they expire after a period of time but there is a button to “restore” the credits somewhere. I can google it later and find the link.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by mowse View Post
    That’s right, and it looks like the discount is even sweeter now at $35!
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Note that data connectivity (3G) and Audi connect are completely separate services in MY2014-16 MMIs that use a SIM to provision mobile data on the AT&T network (that is, you don't need AC for 3G, but you need 3G for AC).
    Once you have your FP SIM configured and it connects to the network, the Google Earth map overlay and Google point-of-interest searches should work (more-or-less) immediately, no AC PIN needed for these.
    The AC PIN gets called when you try to retrieve on-line destinations (or telephone contacts) from your myAudi account the first time -- once this works, you shouldn't need to enter the PIN again for a while (the PIN appears to be added to the current BT phone profile, so if your paired phone isn't connected when you try to access your myAudi destinations, the MMI will ask for the AC PIN again).
    We have the free FP SIM in our MY2014 A4 MMI and keep the Google Earth overlay on, and rarely see more than 200MB of data per month, unless we make several out-of-town trips of over a couple hours in different directions (the overlay caches, so our 12 hr trip out east & back only fetches data on the outbound drive).
    If you don't have your Google Map ID setup to use the Send to Car feature of Google Maps (from a browser), note that the instructions on the myAudi site are incorrect and will cause Send to Car to fail. While I haven't seen this from an official source, the ID should be only alphanumeric characters -- no special characters like '@'.
    If you do opt for the "free" FP plan, add your name to our AZ FP friends thread over here: https://www.audizine.com/forum/showt...twork-Check-In
    @PNW Avant: What is your experience with the annual plan that offers 1GB data each month so far?
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    The 200MB just wasnt enough for me. I was making short trips in the bay area and the data usage was going up fast. I expect SF bay area has more map data than OH?
    Annual plan is great. FP doesnt have any of my financial information so no risk of auto top ups or extra charges. I have been averaging 300-400MB the first two months. For me it made sense because there was no way the "free" plan would be "free" with a SF address, because I would be hit with a $3.49 fee (imposed by city). No such fee for a "prepaid" plan like the annual card.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by DrGER View Post
    If don't have your Google Map ID setup to use the Send to Car feature of Google Maps (from browser), note that the instructions on the myAudi site are incorrect and will cause Send to Car to fail. While I haven't seen this from an official source, the ID should be only alphanumeric characters -- no special characters like '@'.
    Also, i did set up the Google "send to car" (from google browser) functionality and confirmed it worked. However, the My Audi app got re-released (or updated?) and the send-address-to-car from that app is much more seamless. And can be done from a phone now (not desktop browser).
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    I just pulled the trigger on the 12 month pre paid plan from Amazon. At 34.99 for 1gb a month it seems like a great deal.
    Sent from my SHT-W09 using Audizine mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Mar 14 2012
    Warrenton, VA
    Quote Originally Posted by RoofRails View Post
    Please let us know how things go.
    I rec’d my FP SIM yesterday, and used the URL to activate the SIM. The website tried to up-sell me first, which I declined. Then, I was presented with several plan options, none of which were even close to the one clearly described on the Amazon listing (1GB/month data), and on the front of the FP SIM package.
    I bit the bullet and called FP activation support, and after 25 mins on hold, I was told that the SIM I purchased from Amazon was a mistake, and that I should return the SIM to Amazon. I asked what was wrong. I was sort of blown off; the guy just kept saying that the SIM (and the plan?) was wrong. Very unsatisfying answer to say the least. I never got a complete story about how the SIM can be ‘wrong’ or ‘a mistake’. If it’s a bait and switch kinda thing, maybe he just blew me off because I called him on it. I have no idea.
    Support guy also told me to go to either BestBuy or Target to get another FP SIM. Since I have both of those stores relatively close to one another, I followed his advice. Ha! No FP products sold at either of those stores. Anyway.
    I hope things go well for you, and I’m definitely willing to give it another try if you can get yours to work. I’d love to have a reasonably priced 1GB/month plan.
    Apr 24 2017
    Hilton, NY
    That's pretty shady that they somehow don't offer what you bought. IDK for me I don't need to utilize enough where it would even justify buying a yearly plan even at $35-$50. It's something that for now I just enjoy it being free with no real strings attached.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Interesting. Did you buy it directly from amazon, or from another reseller on their site?
    As of a few months ago you could buy FP SIMs at Target and BestBuy. I almost bought mine from target before I got mine from amazon for $5 cheaper. Maybe not the case anymore...?
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    same annual prepaid card for $34.99
    https://www.target.com/p/freedompop-...a/-/A-53511519
    May 08 2018
    San Diego CA
    I bought mine yesterday as well, lol.
    Interesting info. I will keep this in mind when I get mine next week. Hopefully it's just a fluke and everything works out ok.
    Aug 31 2014
    NW OH USA
    I'm curious about the data use you cite. My understanding is that the Google Earth overlay caches images for the immediate region and zoom level (or whatever the setting is called). We have our map set to automatic zoom level, so on highways we see less detail than when driving in our neighborhood. Even a 5+ hour drive across OH/PA/NY doesn't use much more than 100MB or so (and is cached for the return trip). The only other big consumer of 3G data in our MMI is the WiFi hotspot when devices connect to it. Is your WiFi hotspot enabled?
    Still, it's good to know that someone has figured out how to make this FP annual plan work in our MMIs (so far, we tolerate their occasional $0.01 "account maintenance fee" charges to our CC to keep the "free" service active).
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I take a photo every month to track usage. This is from feb 28. I don’t know if we are on “auto zoom” or not but I will check. We drive the car on average once or twice a week but February did include some driving around the city and a 3 hour trip down south and back (slightly different return route). Hot spot is not enabled as my iPhone hotspot is better anyways.
    Mar 14 2012
    Warrenton, VA
    Bought it direct from Amazon.
    My cynical nature makes me think it’s a bait-and-switch kinda thing. But believe me, I want 1 GB/month for 12 months for $35 to be true :-)
    I’m hoping to read about success stories from someone here, because I want to try again!
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I don’t know, I highly doubt it. Mine worked fine from amazon at the $45 price. Are you sure it wasn’t possible for you to decline all plans and stick with your prepaid service? FP is all about the up-sell and sometimes their user interface makes it misleading what your true options are. I don’t recall what workflow I used to get mine activated - if there were hiccups I would have remembered though.
